Old 09-18-2012, 12:22 AM   #4216
ForzaVeloce's Avatar
Originally Posted by Johnny Wishbone View Post
I looked at those as well, interesting design, the only advantage I see with them is the support at the top and bottom so there is very little rod deflection during the extreme stroke of the shock. I think those would be a good application if one where getting into some very heavy shock oil setups, where the drag force of the piston begins to put uneven pressure on the shaft, or different sized holes in the same piston.
You seem to miss the whole point of the design. The biggest advantage with the design is that you have no preassure build up by the shaft. The shafts displacment is constant and you do not need a bladder or anything else to compensate for displacment build up. Just so you know.. ! ;o)
___________________________
HP Racing - Hobbyprodukter.com
Serpent Cobra SRX8 - Serpent s411
ForzaVeloce is offline   Reply With Quote
Old 09-18-2012, 12:44 AM   #4217
JAM Racing's Avatar
Default Thats not all
as the rod at the top displaces the same amount as the bottom that leads to the ball joint their is no need for a bladder at all. (except for heat)
The only reason we have the bladders/foam is due to the unequal displacement of the rod side to cylinder side.
Serpent early shocks with their foam collar work fine but i wouldn't call them an emulsion shock but the tricks you can play with them are more than standard shock
if you build them closed you can preload the shock itself..in the compressed position ..when it extends it opens the foam opens up on the collar closed cell rubber
this leads to it carrying a rising rate on the spring which you are running
This is the best forum by the way and is possibly why we changed to serpents
regards Andrew
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 09-18-2012, 02:38 AM   #4218
TryHard's Avatar
Gary, in terms of damping, what feeling are you trying to achieve? Admittedly I haven't run the original serpent RCXX shocks, but there are quite a few tweaks that you can do to the RCM's to get them working much better. Just as a list, I've done the following;
Tamiya Bladders - Standard Serpent ones were, IMO, to inconsistent part to part)
Tamiya blue o-rings in the bottom - white supplied o-ring had too much shaft stiction.. however, these o-rings do need a bit of spacing as they are thinner. Currently have 0.6mm inside the bottom of each shock, no leaks.
Drilled top - This is a usual feel thing, run mine this way regardless now.
Also this past weekend, I experimented with using more holes/harder oil, and very much liked the feel of the shocks this way. Took away some of the initial pack in the shock, and better over the ripples we have out here.
I've got a load more thoughts from this past weekend, but I need a bit of time to process and write them down, so will post again later.
Ed
Old 09-18-2012, 06:38 AM   #4219
gearhead_22's Avatar
Send a message via AIM to gearhead_22
my buddy Irvin cole wins the tc mod race at the sweeps challange at bluediamond rc in new castle delware.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 09-18-2012, 01:50 PM   #4220
Can I get this car down to 1,350gr?
Without all kinds of expensive solutions....?
SP13.5MMM
SP Cirtix
Orion Carbon Pro 6500mAh weight 290gr
Lightweight body LTC-R
If not, HMX M1 it's gonna be.......
Kensei is offline   Reply With Quote
Old 09-18-2012, 03:05 PM   #4221
Toughbeard's Avatar
SP13.5MMM
SP Cirtix
if its not controlled class get the wires as short as possible.
use a light weight battery.
servo???*
titanium screws on top deck (or alu if you trust your driving )
alu rear shaft.
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 09-18-2012, 03:13 PM   #4222
cwoods34's Avatar
servo???*
alu rear shaft.
I have only added aluminum screws (all over) to mine.... with 2 gear diffs, a fan, standard electronics, and a 6000mAh battery it weighed at 1340. Team Associated's aluminum screw packs from Tower Hobbies are priced decently.... that can knock up to 30 off the car.
The nylon spool weighs 10g or so less than the stock steel piece. Aluminum rear shafts would shave 5-10 more, and replace all 7 turnbuckles with aluminum ones (about 2g a piece).
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 09-18-2012, 03:16 PM   #4223
Toughbeard's Avatar
Sounds about right. I am running 25gr on my car to get to 1354
and that was with the old car. the new one I recon I ll need to put more weight or more fans
Serdar Aytemiz
Old 09-18-2012, 03:22 PM   #4224
cwoods34's Avatar
Are aluminum shafts available from Serpent?..... Or you guys using a different brand? I'll be switching to the nylon spool this week, and new shafts would be great. I think I have as much fun shaving weight as I do racing! One thing I like about mod is you can ditch the fan and run a smaller battery.... which can save up to 30g also!
Old 09-18-2012, 03:26 PM   #4225
Toughbeard's Avatar
http://www.evilhobbyshop.com/Drivesh...2,PR-1021.html
Serdar Aytemiz
Old 09-18-2012, 05:53 PM   #4226
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
1313.7g with a 5600mah, viper vtx 10, savox 1251 low pro
2.0MM chassis
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 09-19-2012, 04:00 AM   #4227
These?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJHB0
Or these?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSG34
Old 09-19-2012, 04:22 AM   #4228
Ok, thank you guys
So I am gonna get me:
SER401470 Alu driveshaft
SER401533 Nylon spool
SER401429 Trackrod alu
SER401430 Camberlink alu (2 sets..?)
What about the seventh one?
Partnumber?
And then the Asso screwset? Partnumber....?
Old 09-19-2012, 05:08 AM   #4229
Holmenkollen's Avatar
Ok, thank you guys
Partnumber?
My standard 411TE weighs 1350 with just some alu. screws, the rest stock. Savox LP servo, HW120A, KO rx, IP5800 mah, SP-motor, LW body. I donīt think I could tell the difference between 1390g or 1350g on the track...
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 09-19-2012, 05:11 AM   #4230
cwoods34's Avatar
Ok, thank you guys
Partnumber?
The aluminum screw set for the TC6 will give you a lot. The TC3/4 sets are standard and won't work. Tower also sells "packs" of aluminum screws (10?) in a variety of sizes. I bought 3x6/3x8 countersunk for chassis pieces, 3x6 buttonhead for the upper deck and other parts, and an assortment of the cap head screws that use a larger hex for rhe bulkheads.
If you can wait till this afternoon I'll link you to each type (PITA to do on my phone).
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
