Like Tree12Likes
Old 09-14-2012, 02:16 PM   #4186
Originally Posted by Toughbeard View Post
Errrrr Serpent
Okidoki. Gonna get me those.
Serpent has only 64DP pinions (as I see it on their website).
Any suggestions as to 48DP pinions?
Or isn't it a big deal and can I use almost any brand?
Are these any good? Do they work on Serpent S411 and spur 48P 72T Serpent part number 120016?
http://www.robinsonracing.com/catalo...tchpinion.html
I mean the Black Aluminium Pro Pinions?
I would want pinion 48P 32/33/34/35/36/41?
Can these be meshed with spur 48P 72T in the S411?
Kensei is offline   Reply With Quote
Old 09-14-2012, 03:18 PM   #4187
cwoods34's Avatar
Those should work. Associated 48p work fine and are priced the same, also. I've gone to mid-7's for FDR with an 84t (20's pinions), so although I don't have a 72t to test for you, it should fit fine with 30's pinions.
What specific FDR do you want?
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 09-14-2012, 04:43 PM   #4188
Toughbeard's Avatar
The following are the Serpent Part numbers for Spurs and Pinions which you can find at Evil Hobby Shop (95% at worst case scenario )
Part Number - Name -------------Price Euro------
120005 Spur gear 64P / 92T 2,76
120006 Spur gear 64P / 96T 2,76
120007 Spur gear 64P / 100T 2,76
120008 Spur gear 64P / 104T 2,76
120009 Spur gear 64P / 108T 2,76
120010 Spur gear 64P / 112T 2,76
120011 Spur gear 64P / 116T 2,76
120012 Spur gear 64P / 114T 2,59
120015 Spur gear 48P / 69T 2,76
120016 Spur gear 48P / 72T 2,76
120017 Spur gear 48P / 75T 2,76
120018 Spur gear 48P / 78T 2,76
120019 Spur gear 48P / 81T 2,76
120020 Spur gear 48P / 84T 2,76
120021 Spur gear 48P / 87T 2,76
120022 Spur gear 48P / 86T 2,59
120105 *Motor-pinion alu hard *64P / 18T 3,45
120106 *Motor-pinion alu hard *64P / 19T 3,45
120107 *Motor-pinion alu hard *64P / 20T 3,45
120108 *Motor-pinion alu hard *64P / 21T 3,45
120109 *Motor-pinion alu hard *64P / 22T 3,45
120110 *Motor-pinion alu hard *64P / 23T 3,45
120111 *Motor-pinion alu hard *64P / 24T 3,45
120112 *Motor-pinion alu hard *64P / 25T 3,45
120113 *Motor-pinion alu hard *64P / 26T 3,45
120114 *Motor-pinion alu hard *64P / 27T 3,45
120115 *Motor-pinion alu hard *64P / 28T 3,45
120116 *Motor-pinion alu hard *64P / 29T 3,45
120117 *Motor-pinion alu hard *64P / 30T 3,45
120118 *Motor-pinion alu hard *64P / 31T 3,45
120119 *Motor-pinion alu hard *64P / 32T 4,14
120120 *Motor-pinion alu hard *64P / 33T 4,14
120121 *Motor-pinion alu hard *64P / 34T 4,14
120122 *Motor-pinion alu hard *64P / 35T 4,14
120123 *Motor-pinion alu hard *64P / 36T 4,14
120124 *Motor-pinion alu hard *64P / 37T 4,14
120125 *Motor-pinion alu hard *64P / 38T 4,14
120126 *Motor-pinion alu hard *64P / 39T 4,14
120127 *Motor-pinion alu hard *64P / 40T 4,14
120128 *Motor-pinion alu hard *64P / 41T 4,14
120129 *Motor-pinion alu hard *64P / 42T 4,14
120130 *Motor-pinion alu hard *64P / 43T 4,14
120131 *Motor-pinion alu hard *64P / 44T 4,14
120132 *Motor-pinion alu hard *64P / 45T 4,14
120133 *Motor-pinion alu hard *64P / 46T 4,14
120134 *Motor-pinion alu hard *64P / 47T 4,14
120135 *Motor-pinion alu hard *64P / 48T 4,14
120136 *Motor-pinion alu hard *64P / 49T 4,14
120137 *Motor-pinion alu hard *64P / 50T 4,14
120138 *Motor-pinion alu hard *64P / 51T 4,14
120139 *Motor-pinion alu hard *64P / 52T 4,14
120150 *Motor-pinion alu hard *48P / 12T 3,45
120151 *Motor-pinion alu hard *48P / 13T 3,45
120152 *Motor-pinion alu hard *48P / 14T 3,45
120153 *Motor-pinion alu hard *48P / 15T 3,45
120154 *Motor-pinion alu hard *48P / 16T 3,45
120155 *Motor-pinion alu hard *48P / 17T 3,45
120156 *Motor-pinion alu hard *48P / 18T 3,45
120157 *Motor-pinion alu hard *48P / 19T 3,45
120158 *Motor-pinion alu hard *48P / 20T 3,45
120159 *Motor-pinion alu hard *48P / 21T 3,45
120160 *Motor-pinion alu hard *48P / 22T 3,45
120161 *Motor-pinion alu hard *48P / 23T 3,45
120162 *Motor-pinion alu hard *48P / 24T 3,45
120163 *Motor-pinion alu hard *48P / 25T 3,45
120164 *Motor-pinion alu hard *48P / 26T 3,45
120165 *Motor-pinion alu hard *48P / 27T 3,45
120166 *Motor-pinion alu hard *48P / 28T 3,45
120167 *Motor-pinion alu hard *48P / 29T 4,14
120168 *Motor-pinion alu hard *48P / 30T 4,14
120169 *Motor-pinion alu hard *48P / 31T 4,14
120170 *Motor-pinion alu hard *48P / 32T 4,14
120171 *Motor-pinion alu hard *48P / 33T 4,14
120172 *Motor-pinion alu hard *48P / 34T 4,14
120173 *Motor-pinion alu hard *48P / 35T 4,14
120174 *Motor-pinion alu hard *48P / 36T 4,14
120175 *Motor-pinion alu hard *48P / 37T 4,14
120176 *Motor-pinion alu hard *48P / 38T 4,14
120177 *Motor-pinion alu hard *48P / 39T 4,14
120178 *Motor-pinion alu hard *48P / 40T 4,14
120179 Motor-pinion alu hard *48P / 61T 4,83
120180 Motor-pinion alu hard *48P / 62T 4,83
120181 Motor-pinion alu hard *48P / 63T 4,83
Send an E mail to me if you need any help with gears at [email protected] as the pinion gears are not added to our database yet. and yes we have the 61 62 and 63 T in stock...
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 09-15-2012, 02:33 AM   #4189
Pinion
32 FDR 4.50
33 FDR 4.36
34 FDR 4.24
35 FDR 4.11
36 FDR 4.00
41 FDR 3.51 (preferably FDR 3.50, as to regulations Nats)
All with spur 48P 72T
Old 09-15-2012, 02:35 AM   #4190
Toughbeard's Avatar
Pinion
32 FDR 4.50
33 FDR 4.36
34 FDR 4.24
35 FDR 4.11
36 FDR 4.00
if its hand out tires not problems... but if not check your tire daimeters as well for rollout.
Serdar Aytemiz
Old 09-15-2012, 02:39 AM   #4191
Tyres rubber Sorex XG-32RY as to regulations.
Old 09-15-2012, 02:45 AM   #4192
Toughbeard's Avatar
then not much can be done. still look at rollout rather then fdr. it will give you a better picture. here its modified do not regulated at the moment. So I see people using a 63 mm diameter tire then they switch to a 65 and wonder why it started to over heat.
Serdar Aytemiz
Old 09-15-2012, 02:55 AM   #4193
I also need 41T. It's not in the list!
I would need 32/33/34/35/36/41.
Old 09-15-2012, 02:57 AM   #4194
32 FDR 4.50
33 FDR 4.36
34 FDR 4.24
35 FDR 4.11
36 FDR 4.00
Does Asso48P have
32/33/34/35/36/41?
Retailer?
Partnumbers?
Thanks!
Old 09-15-2012, 04:21 AM   #4195
Toughbeard's Avatar
We have Serpent and Zeppin in stock and both end at 40T in 48P.
the closest I can get you to 3.5 is 92/52 or 69/39 with our items.
at the mean time you may look for a 70T spur for 70/40
in the mean time I ll talk to the guy is Serpent let them know about it. 3.5 is a real low ration I think noone ever though of in EU side. in the ETS its run at 4.0 flat.
Serdar Aytemiz
Old 09-17-2012, 03:26 AM   #4196
hello
any one have test nylon gear diff from de yokomo BD5???
do you know if its the same size???
thank's...
Redbull is offline   Reply With Quote
Old 09-17-2012, 06:11 AM   #4197
Toughbeard's Avatar
Originally Posted by Redbull View Post
hello
thank's...
One of my friends have the BD5 and he tried Serpent gear diff. I think he said it was loose about 0.8mm I ll give him a call see if he remmebers
Serdar Aytemiz
Old 09-17-2012, 06:17 AM   #4198
TJames987's Avatar
Trader Rating: 10 (92%+)
Default driveshaft tech questions
Just got back from Sweeps race a blue diamond Delaware with the s411.
Is there any other CVD pins that have a flat spot for the set screw from other manufacterers so they dont fall out??
Also, any thoughts or problems with the upgraded serpent front driveshafts (I think they are called DJS?) ?
TJames987 is offline   Reply With Quote
Old 09-17-2012, 07:10 AM   #4199
Toughbeard's Avatar
with a dremel make a flat spot on the pin.
do not over tighten the set screw
make sure you clean every part with brake cleaner before assembly.
once you have assembled the drive shafts let the loctite dry then put some sort of non sticky oil to the joints.
once done correctly it never comes loose.
The Serpent DJC is probably one of the best you can buy. I use it in Modified and only broke a pin once. I didnt even break my DJC when I totalled my car in ETS
41 Evil Euros
Serdar Aytemiz
Old 09-17-2012, 10:06 AM   #4200
StevenOlsen's Avatar
hello
thank's...
The xray geardiff works if you trim the Bearing holders alittle
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
