Old 06-24-2011, 11:16 PM   #406
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by skypilot View Post
Are they gonna send you a new one??
Hey Ritchie
Jb still can build his car,he just needs to grind a pocket the area where the bottom of the servo saver hitting .or he could remove the carbon fiber piece out and put the shim spacer one side under the servo mount....will that works JB
OVA is offline   Reply With Quote
Old 06-24-2011, 11:21 PM   #407
OVA
OVA's Avatar
Originally Posted by Jamison R View Post
Not many servo savers fit. The extra carbon fiber piece holding servo in, is in the way. I have tried several servo savers with none of them fitting.
can you just remove the carbon fiber and get a different set of servo holder instead the stock one?
Old 06-25-2011, 12:53 AM   #408
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I just use Shoo Goo to hold the servo down.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-25-2011, 02:07 AM   #409
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JayBee View Post
I can't start my build yet
Originally Posted by OVA View Post
you don't need the stinky servo ...just don't hit the pipes....lol
Hey Ritchie
Hey buddy, what makes you think I'm talking about silly servo-savers
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-25-2011, 02:57 AM   #410
Trader Rating: 54 (100%+)
just needs to grind a pocket from the area where the bottom of the servo saver is hitting .
This will work.
Jamison R is offline   Reply With Quote
Old 06-25-2011, 07:41 AM   #411
OVA
OVA's Avatar
Old 06-26-2011, 02:59 AM   #412
Will you didn't said why ..Oh I get it ,,,okay I will shutup...
This stuff coulda been through PM.
Back on track with the S411. Has anyone run stock set up on high bite yet? I drove the car a little Thursday on our med to low bite track. We treat with coke syrup on race day. The car felt good and easy to drive, just a little loose coming into corner. Im thinking its from the dust from offroad track right next to it. And has anyone broken any parts? If so, which ones? Last question. When will Amain and Stormer start stocking parts????
Old 06-26-2011, 03:05 AM   #413
Have been doing a bit of running with this car now and have learn't quite a bit. The gear diff is still a bit of a question mark for me though... I now have 3000cst in there and it keeps feeling better and better to drive the heavier I go BUT I can feel the steering drop away. Has anyone tried running 4 bevel gears instead of the kit 2? What did you think?
Also... have played with kit springs a bit and I strongly recommend changing out the rear spring for something more progressive. I have been playing with the Hara springs personally but it seems a necessity to get a solid rear end. A harder front bar (or softer rear) gives the car better balance mid corner too so try a 1.6 front or 1.2 rear.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 06-26-2011, 03:22 AM   #414
Ok thanks. Im dont wanna buy Hara springs. I have too many springs as it is. If there was one set of hara springs to buy, which ones would they be? I really like the car right out of the box. Im gonna go up on diff oil and see if that helps my loose in isssue. It might be lifting the inside rear tire causing diff-out. We will see.
BTW_ I threw it on the rug to check servo, had hard tires and no sauce(didnt even have body on) Car felt rediculously good. I sure hope its that good this winter!!!
Old 06-26-2011, 03:33 AM   #415
If you have plenty of springs then run what works well for you... My only spring kit I have at the moment is for my Losi JRX-S type R which uses short springs that don't fit the S411 very well. I like the look of the Hara springs plus they have about 1.2lbs spacing which makes fine tuning better. I am currently using hard and medium but for mod I thing I will drop to soft and medium for the feel I prefer.
Powered by Falco
Old 06-26-2011, 04:25 AM   #416
RC MARKET's Avatar
Today S411 in HK Race Won again !
RC MARKET is offline   Reply With Quote
Old 06-26-2011, 07:32 AM   #417
diesel's Avatar
Bro, when got stock for S411?
diesel is offline   Reply With Quote
Old 06-26-2011, 08:01 AM   #418
OVA
OVA's Avatar
This guy is my buddy..I was just messing with him...everything is cool....
Old 06-26-2011, 09:02 AM   #419
RC MARKET's Avatar
today MOD. Class 1st & 3rd !
S411 Kit instock !
Old 06-26-2011, 09:14 AM   #420
jensen123's Avatar
S411 Kit instock !
Good Job!
jensen123 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
