Old 08-21-2012, 12:44 PM   #4051
BAD007SUZUKI's Avatar
Trader Rating: 93 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default mounts
split mounts allow for additional flex of the chassis.
Originally Posted by Geberit View Post
And what's up with the split mounts for the A-arms?
R/C Fun Park 12990 SR23 Granger, Indiana 46530
BAD007SUZUKI is offline   Reply With Quote
Old 08-21-2012, 01:40 PM   #4052
Geberit's Avatar
Oh i know what the mounts do I wanted to know if Serpent is maybe working on something like that. Just curious nothing else
But thanks for the reply!
Geberit is offline   Reply With Quote
Old 08-21-2012, 07:01 PM   #4053
TJames987's Avatar
Trader Rating: 10 (92%+)
Default Carpet setup
Hi. Y'all. What's the best s411 setup for carpet track 100 x 60 size?
Anyone tested it on carpet how does it do compared to tamiya and X-ray cars?
Thank
TJames987 is offline   Reply With Quote
Old 08-21-2012, 07:15 PM   #4054
S411 SE, box stock, great starting point for carpet. Running dual gear diffs.
red7fifty is offline   Reply With Quote
Old 08-21-2012, 08:42 PM   #4055
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
I always groove the pins use loctite and heatshrink or the top holders.
I am really liking all the new blood on the thread.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 08-21-2012, 08:56 PM   #4056
Originally Posted by Marcos.J View Post
I did once , I put locktite on the screw then I used a shrink wrap around it. Never had any issues again
Me too
Pickthall is offline   Reply With Quote
Old 08-22-2012, 12:14 AM   #4057
StevenOlsen's Avatar
Serpent should be in the progress of making the split blocks. But it takes time to develop, and with so many big races at the moment both EC and WC, it could take 1-2 month before it is ready.
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 08-22-2012, 12:58 AM   #4058
Holmenkollen's Avatar
I was rebuilding my shocks a while ago and changed one of the standard o-rings for a green Much More o-ring. Much better. This together with 1 mm hole in the cap resulted in very little rebound. On track the car had way more grip, almost to much roll. Much better over the bumps.
Anyone else having trouble with the rear damper ball cups hitting the rims? Im using 1 mm washers and it still rubs (under load I presume).
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 08-22-2012, 01:20 AM   #4059
JAM Racing's Avatar
same here regarding the rear damper cups so much that it sometimes shakes the poor little threads loose and as for the O,Rings I have been using orings form our local o'ring supplier( you guesed it im a hydraulics tech)
i will be trialing viton orings in the near future as they are harder and LOVE SILICON OIL
trick will be getting the size abolutely right but we are talking cents not dollar and i buy them by the 1000
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 08-22-2012, 03:58 AM   #4060
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i find certain rims flex more than others. the speedmind rims are quite stiff, and i dont have any rubbing. where as the Sorex schumacher rims flex more, and yes they rub.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-22-2012, 04:49 AM   #4061
Nearly every Serpent drivers (and other brands too!!) has that problem, if you use the outside hole in the wishbones. Only very stiff dishes don't touch the cup.
I suggest, you cut the cup and check the inside of the dishes after every race. If you have black spots on the rims, you have to cut more of the cup.
If you don't, you rear tire may brake a little while cornering, and then you can get a loose rear end.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 08-22-2012, 05:14 AM   #4062
I also had problems with the new dampers. Not with the o-rings but with the membrane.
Now I do the dampers this way: I use the standard o-rings, but I use Tamiya damper grease (the blue one) while assembling the bottom parts. The membrane I put into the top, where I have drilled an extra 1 mm hole in the plastic like Holmenkollen and others too. I fill the damper body with oil, put the top on, press the piston slowly up as high as I want the rebound. Oil will come out of the standard hole in the aluminium top. While I still hold the piston in the correct position, I finally screw the top on the damper body. The rebound can be almost like zero that way if you want.
I have no binding in the dampers. I have not tried other o-ring brands, as I have not felt any need yet. I have some new Tamiya blue competition o-rings in my bag. Maybe I will try them.
Old 08-22-2012, 05:38 AM   #4063
TryHard's Avatar
I've been using my shocks for a while with two tamiya blue o-rings in the bottom of the shocks. Makes the action much smoother, as they have a lot less friction than the standard serpent O-rings. However, as they are a little thinner, they don't quite seal the shock as well. To rectify this, I've added 0.7mm worth of shims between the shock body and the upper o-ring, which helps to squeeze them onto the shaft.
Had the same issue first time out with a set of Much-More tires, so I just cut the ball cup back a bit. 3 meetings later, no rubbing, and no issues
HiH
Ed
Old 08-22-2012, 06:04 AM   #4064
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
For those of you that use heatshrink around the end of the CVD to stop the pin from coming out.... Why are you also using the grub screw ? If the pin is contained, why both with the grub screw at all ?
I would think without the grub screw the entire assembly would be more "free". That is the reason I started running the TOP rings..
Thanks in advance...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 08-22-2012, 06:10 AM   #4065
TimPotter's Avatar
We have been running Solaris tires as a spec here and the rim is chamfered . With previous wheels we used a deburring tool to chamfer it .
One or two rotations around the wheel and it has a nice bevel. ( it will be fine as long as it is within the rules you race with, some rules will not allow you to touch the rim at all )
http://www.homedepot.com/buy/brasscr...tool-t090.html
HiH
Ed
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
