Old 08-20-2012, 09:04 PM   #4036
thachowman's Avatar
Trader Rating: 28 (100%+)
Is anyone else having troubles with the CVD pins coming loose ? I had nothing but trouble on the weekend with mine , every run I had to clean reset the pin and tighten them again, both front and rear , I also broke three of them as well . I'm running modified with a 4.5 t boosted and the track is bumpy technical asphalt with medium grip . The track is known for breaking CVD's as I used to chew up X Ray ECS shaft pins like they were goIng out of fashion . I also built new shafts using all new parts and still had a problem. Other than that the car was awesome just the driver let it down
Cheers
Andrew "Chow" Clough
_____________________________________________
Fraser Coast RC Car Club/FCRCCC :President
Yokomo - Futaba - LRP - Paint Made Special - Muchmore
thachowman is offline   Reply With Quote
Old 08-20-2012, 10:00 PM   #4037
Geberit's Avatar
Did you use lictite on the screw? That helps but you should clean the shafts first as the grees or oil prevents the loctite to work. So clean the shafts then loctite the screw and then oil or grees the shaft.
Geberit is offline   Reply With Quote
Old 08-21-2012, 12:37 AM   #4038
Holmenkollen's Avatar
Use this:
http://www.rc-mushroom.com/product_i...n-8pcs-p-24719
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 08-21-2012, 12:50 AM   #4039
Originally Posted by Holmenkollen View Post
Correct - or flatspot the Serpent pins with a Dremel. Takes about 5 minutes for all four pins. That is what I have done, and since I never had any issues.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 08-21-2012, 02:28 AM   #4040
Benzaah's Avatar
Trader Rating: 21 (96%+)
Flat spot pins are a must but You can use these pin locators from TOP if you have the standard drive shafts.
http://www.rc-mushroom.com/product_i...d-4pcs-p-19026
They do a titanium version if you can find them in stock anywhere. There is also a 3racing version of the same as well. I dont even use grub screws on my shafts anymore and cleaning and relube after a meet is easy.
On another note i put the 1.6 sway bars on the car over the weekend and using the 1.8 inserts could not get the bars free and they would bind up. I shimmed them up at the time and will try and get them working with the 1.6 inserts when i rebuild this week to see if this works but Has anyone else experienced this? I did not have this issue with the 1.4 bars at all. It was frustrating at the time but the set up change was well worth it. We have our state titles coming up this weekend and if i can drive it under the pressure i think ill do alright.
Originally Posted by fasteddie d View Post
This is one cool car .
Seconded
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 08-21-2012, 02:46 AM   #4041
My rear hub broke in half when I was driving on the straight. I think the pin hit the hub in full speed and shattered the hub. So assuring that the pin is well secured is very important, especially when you´re driving modified.
Old 08-21-2012, 05:15 AM   #4042
thachowman's Avatar
Thanks guys , I'll try grinding a flat as I have a heap of spare pins, I would have done it on the weekend but didn't have a dremel with me. I did loctite the grub screws and cleaned thoroughly beforehand, and left it to dry as well , and the grub screw was still tight in the insert, just the pins worked their way out. I also shattered a rear hub as a result of the pin comming free, so I'm also going to try heat shrinking the cvd as well .
Cheers
Old 08-21-2012, 05:16 AM   #4043
cwoods34's Avatar
I'm running a 1.5 swaybar in the 1.6 inserts and it moves freely. I tried a 1.6 in the same inserts and it would barely bind.... It worked fine in the 1.8 inserts, so perhaps you just need to lightly sand yours to open them up a hair? The swaybar setup on this car works find but it could be a bit more simple IMO.
The pins in the axles are 10mm I believe.... I kept having issues with them popping out of the stub axle as the couplings wore. I bought the 2x12mm pins and Dremel'd them down to just under 11mm so they barely stick out of the stub axle but not far enough to rub on the knuckle...... I haven't had one malfunction yet! I only occassionally retighten the screw and add grease.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-21-2012, 05:33 AM   #4044
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
These are great.. Serpent needs to come out with a captured pin cvd.
Seconded
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 08-21-2012, 05:46 AM   #4045
The team durango 2x10mm drive pins with a flat spot are a direct fit( sorry, don't have the part#)
Also a drop of ca on the outside of the heat shrink will help to harden it, for extra security, just apply carefully.
Serpent America l Picco l Desoto Racing l Leisure Hours Hobbies & Raceway
RC Addiction Products l Nitropro Fuel
jsorwell is offline   Reply With Quote
Old 08-21-2012, 07:10 AM   #4046
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
I did once , I put locktite on the screw then I used a shrink wrap around it. Never had any issues again
Old 08-21-2012, 11:01 AM   #4047
dameetz's Avatar
Will Serpent come out with the floating steering servo system like the current trend of top brands car?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-21-2012, 11:27 AM   #4048
Geberit's Avatar
And what's up with the split mounts for the A-arms?
Old 08-21-2012, 11:27 AM   #4049
They don't need to, the servo already floats, just make sure it's not sitting on the chassis. I just put a piece of double stick tape under it, but leave the backing on. Chassis flex seems equal.
Old 08-21-2012, 11:28 AM   #4050
This is what I use they are awesome. not even a need for set screws.
Alston Kelso
Destiny USA•SMC Batteries•Reilly Paint•CEFX
Detroit Racing Team
"Let's See, Open it up" -Chris Goetz
98tahoeboy is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
