Old 08-03-2012, 07:16 AM   #3961
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by BCDK View Post
Hi.
Nice - you will not be disappointed. S411 is a lovely car. Look forward to the race in Glostrup. We will start with the setup from the WC - maybe change the suspension block in the rear to 2,5 or 3,0. We will see how it work. You can find the setup on the Serpent site. It worked great in Heemstede.
A 64 dp chart for modified you can find either here some pages back or on the Serpent Forum site under S411 pages 4.
Yes 411 is very nice , i have been out of racing for over 9 months and after a couple of packs or practice i was back on pace
Old 08-03-2012, 07:31 AM   #3962
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
www.gearchart.com
Make a chart for your most commonly used ranges. I have been running 13.5 blinky recently... so I created one for that.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 08-03-2012, 07:35 AM   #3963
whityboy's Avatar
Sure - I could do it, but I will not search for the rates. If you give me them, I will fill them into my chart.
You could also send me a PM with your e-mail address, and then I will send you the Excel file. You can then fill in the rates, you want.
D'OH forgot to post the link
http://www.jaro-racing.nl/downloads/spring%20chart.pdf
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 08-03-2012, 08:18 AM   #3964
Originally Posted by whityboy View Post
48 or 64 dp? Spur gear sizes? Pinions from ? to ?
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 08-03-2012, 08:40 AM   #3965
Super Moderator
Marcos.J's Avatar
For mod I'm going to be using a 80t - 81t spur 48pitch
Old 08-03-2012, 08:49 AM   #3966
TimPotter's Avatar
Umm, I may be wrong, but with any gear chart, numbers are numbers, does not matter the pitch.
88x35 = 4.97 in any pitch.
Old 08-03-2012, 11:20 PM   #3967
TryHard's Avatar
So after my first few meetings with the S411TE, I thought it time to post up some thoughts on the car, in terms of on track, and working on etc.
First up, the biggest thing, handling... So far I've been very impressed with the car, especially the amount of steering it has. Now, I won't say that it's been perfect, and it has been tricky to drive on occasion. However, it's generally been fast, and has always responded well to changes, and can see them both in terms of laptime and feel. Even after just three meets, I feel I'm at a point where I'm very happy with the base settings now, and will be taking them wherever I go, and doing fine tuning as needed... no massive sweeping changes to stay on top of track and conditions like previous...
In terms of durability, I've been even more impressed. So far, I've only been running mod, with 4.5t + boost, and the list of broken parts is as follows; One rear belt, one set of driveshaft blades, and... nothing else! Given I'm also still running the plastic centre pullies (which are holding up pretty good having had a detailed look last night), I am very pleased. Everything now feels nicely bedded in and free to boot.
Negatives? Well, they are few and far between. I guess my biggest grudge is the position of the screws that hold the upper bulkhead caps in place... in that they won't fully come out without hitting the shock tower screws. Not a massive issue, but that's the only real issue I have (countersinking the shock towers would solve that!)... oh that and the shocks, but solved those issues happily
Looking forward to running the car some more, very happy with my choice
Cheers
Ed
Old 08-06-2012, 11:04 PM   #3968
Holmenkollen's Avatar
Started building my LE yesterday and Im impressed by the quality. Everything goes together really well and well designed solutions. Only "problem" is one of the steering arms hit the lipo plastic holder in full lock. Also the gear diff feels a little notchy but I think it will settle in after a run or two.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 08-06-2012, 11:20 PM   #3969
scribbler's Avatar
When I was interested in purchasing my first touring car I wanted the S400, now that they have come out with this car and I'm definitely very keen on it.
Is there north American parts support. Will I be able to find a dealer in Canada. I'm tired of have to order parts from Japan and hope they arrive at the last moment. Have the issues that killed the Serpents previous touring car been resolved? If I'm looking at purchasing one for the 2013-14 carpet season am I going to be able to find one next year? Is Serpent into Touring Car for the long haul? or is this just something they're trying out?
scribbler is offline   Reply With Quote
Old 08-07-2012, 02:01 AM   #3970
F1 driver's Avatar
I had the same "problem". Solved it by placing 2 lower bushes (1mm instead of 3mm) under the lipo holder.
On the ohter hand, while riding the the car, it turned out that it has lots of steer, so you don't need the maxium travel of the steering arms...
F1 Competitionline MF Benetton B195/F1 Sportsline Benetton B192/SerpentS411TE/Shumacher Mi4/3Racing TT01/Team Associated SC10
F1 driver is offline   Reply With Quote
Old 08-07-2012, 02:43 AM   #3971
Should I use the top deck screw into the motormount? Have read something about stripping spur gears if you dont.
Old 08-07-2012, 04:42 AM   #3972
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i am normally around the 74-78 % Dual rate, always set end points so nothing binds, then turn down dual rate till you have just enough steering, then go one more click on the dual rate.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-07-2012, 05:02 AM   #3973
TryHard's Avatar
I don't use the LiPo holders, just the plastic tape parts, as I really don't like the carbon hooks. This drops the plastic parts to the deck, below the steering. I haven't had any issues with batteries ejecting without them, either on this car or previous ones.
As for the motor mount, I've been using pretty much only the V2 one-piece, so can't comment on stripping gears with the kit mount... however, I have some ideas in mind to test out next time out that'll involve a bit of mucking around with motor mounts
HiH
Ed
Old 08-07-2012, 05:37 AM   #3974
HiH
Ed
Great tip!
Ive read that some people are using a set screw instead so the top deck can flex a little bit more.
Old 08-07-2012, 06:14 AM   #3975
cwoods34's Avatar
Great tip!
Use a long thread-locked setscrew, then put an o-ring on the upper deck and tighten a nut onto the setscrew until it just begins to put pressure on the o-ring. This will prevent spur stripping while allowing flex.... And you can always remove the o-ring and fully tighten the nut if you wish to remove flex.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
