Like Tree7Likes
Old 07-29-2012, 06:44 PM   #3931
TryHard's Avatar
Originally Posted by Eddie M View Post
Ed, is it the hpi silver spring that you are using in your setup? If not, do you know their spring rate?
Yup, HPI silvers (original silver coloured ones at that). I played around a lot last week with springs and roll bars, especially on the rear, and the silver silver combo, for me, gives the best feel. I origianlly settled on harder spring, softer roll bar, for better forward traction, but with the diff change I've been able to go up again on the roll bar.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-31-2012, 12:49 PM   #3932
Geberit's Avatar
HiH
Ed
What's the spring rate of the HPI Silver? Cant find it ...
Geberit is offline   Reply With Quote
Old 07-31-2012, 02:44 PM   #3933
Johnny Wishbone's Avatar
16.90 lb/in
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 08-01-2012, 02:38 AM   #3934
thachowman's Avatar
Trader Rating: 28 (100%+)
Got my Exotec chassis in the mail today, Thanks to R.A.B. Hobbies for their super prompt service. Will be installing tonight for this weekends club meet, I'll post some feed back when I've tried it out .
Cheers
Andrew "Chow" Clough
_____________________________________________
Fraser Coast RC Car Club/FCRCCC :President
Yokomo - Futaba - LRP - Paint Made Special - Muchmore
thachowman is offline   Reply With Quote
Old 08-01-2012, 05:52 AM   #3935
Geberit's Avatar
If I go from 2ff/1fr to 1,5ff/1,5fr to have the same ackerman I should take away the shims on the steering links? How much?
PS: where in the set up sheet is the ackerman setting listed?
Old 08-01-2012, 06:38 AM   #3936
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
The Serpent Black springs are 16.5, I would like to see if someone has both ( I probabaly do, but have to find them). Which ones are actually stiffer, and which spring is more linear.
Originally Posted by Johnny Wishbone View Post
16.90 lb/in
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 08-01-2012, 07:42 AM   #3937
Hi Tim and others.
Because the Serpent and the HPI spring have nearly the same rate, you can't say, that they are equal. The Serpent springs are 23 mm high, the HPI 26 mm. The Ride springs are 25 mm and the Tamiya springs 27 mm.
Many racers uses the HPI or Ride outdoors and the Tamiya indoors. I like the Ride outdoors, as the spring rates are pretty close. You can fine tune your car. At the WC we used Ride red in the front and Ride blue in the rear - rated 16,9 and 16,1.
I have made a spring and gearing chart. You can find it in the Serpent forum - page 4 under S411.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 08-01-2012, 08:01 AM   #3938
TimPotter's Avatar
Nice... did not even know there was forum over there.. The website is kind of clunky...
Old 08-01-2012, 06:48 PM   #3940
TryHard's Avatar
No, you should add shims, as taking away the sweep moves the front outer axles forward, relative to the steering.
The other option is to move the arms back in the car (more shims in front of the wishbone) to keep the wheelbase the same, and run the same ackerman.
2.0/1.0 gives 1deg of arm sweep, so going to 1.5/1.5, which is straight arms (0deg), means losing a degree of hinge pin angle. It's not exact, but I figure on 0.5mm per 0.5deg of angle removed... So going from 2.0/1.0 to 1.5/1.5 either add 1mm of shims to the steering Ackerman, or add 1mm in front of the arm and leave the Ackerman alone.
HiH
Ed
Old 08-01-2012, 08:31 PM   #3941
i know this is a rookie question so please bear with me.i tried the longer shock spring thing and i was able to get ride height[barely], but now the springs are always bound up. i dont know but i dont think this is a good thing.what is the diff. between springs that are [for lack of a better term] always bound to those that are not
S411LE#63,eryx 2.0,kyosho ultima sc,B44.1,futaba.the short list. Ricky Bobby body club,member #4
atmeearacing is offline   Reply With Quote
Old 08-01-2012, 09:56 PM   #3942
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
is there a U.S retailer for the ride springs?
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 08-01-2012, 10:04 PM   #3943
Answered My own question http://www.tqrcracing.com
Team Waldorf Racing
Old 08-01-2012, 11:58 PM   #3944
Geberit's Avatar
No, you should add shims, as taking away the shims moves the front outer axles forward, relative to the steering.
The other option is to move the arms back in the car (more shims in front of the wishbone to keep the wheelbase the same, and run the same ackerman.
2.0/1.0 gives 1deg of arm sweep, so going to 1.5/1.5, which is straight arms (0deg), means losing a degree of hinge pin angle. It's not exact, but I figure on 0.5mm per .5deg of angle removed... So going from 2.0/1.0 to 1.5/1.5 either add 1mm of shims to the steering Ackerman, or add 1mm in front of the arm and leave the Ackerman alone.
HiH
Ed
Great, thanks for the answer!
Old 08-02-2012, 02:39 AM   #3945
Hi.
Attached find my gearing and spring chart. For those, who can't find it on the Serpent forum.
File Type: pdf Serpent S411 Gearing Spring English.pdf (92.8 KB, 155 views)
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
