Old 07-11-2012, 05:52 AM   #3871
rave1010hk's Avatar
My S411 SPORT
Serpent S411-dsc00883.jpg   Serpent S411-dsc00884.jpg   Serpent S411-dsc00885.jpg   Serpent S411-dsc00886.jpg
MUGEN MTX5、MTX4-R、NR FLASH 12.PTS/MRX5、NR FLASH 21.PTS/MBX6、NR BONITO 21-7XLBS/SPP 966、733、811、411、120、120L、240、100/TAMIYA 417、F104X1、M05/XRAY RX8、T3/FUTABA 4PKS
rave1010hk is offline   Reply With Quote
Old 07-12-2012, 05:54 AM   #3872
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Nice...
I have few of these sold to locals.. waiting for them to be in stock. Can you take some closer pics, and give us your feedback on the car ?
Originally Posted by rave1010hk View Post
My S411 SPORT
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 07-12-2012, 06:55 AM   #3873
gearhead_22's Avatar
Send a message via AIM to gearhead_22
deleted post
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is online now   Reply With Quote
Old 07-15-2012, 07:03 AM   #3874
Benzaah's Avatar
Trader Rating: 21 (96%+)
Average day with the car today. I picked up some plant matter during an off track excursion and chewed up both belts and the alloy center pulleys. Amazing how quick you can do this major repair under the pump
I'm wondering peoples opinion on running belts loose or tight with modified motors.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 07-15-2012, 11:23 AM   #3875
cwoods34's Avatar
I always run tight front/loose rear belts regardless of motor!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 07-15-2012, 04:00 PM   #3876
cwoods34's Avatar
Ready for Nationals......
Hopefully will have a color-appropriate battery by then
KO servo, Spektrum receiver, SXXv2, and 2 capacitors crammed in there.... weighs about 1388 with a lightweight body!
Old 07-15-2012, 06:04 PM   #3877
Default front diff
ran my car last weekend with the front diff with diff lock and the car pushed in the sweeper so this week I put 300,000 in the the diff and the car is so smooth in the turns and didn't push at all. I could ease the throttle all the way though the sweeper. lovin my 411 more and more each weekend.
Old 07-15-2012, 06:08 PM   #3878
[quote=Benzaah;10975710]Average day with the car today. I picked up some plant matter during an off track excursion and chewed up both belts and the alloy center pulleys. Amazing how quick you can do this major repair under the pump
I run mod and I run my rear belt one notch loose from center and haven't had any problem. by the way where did you get the alloy center pully?
Old 07-16-2012, 01:07 AM   #3879
Benzaah's Avatar
http://www.serpent.com/product/401427/
I got mines from Walter Rc but im in australia. Any good serpent dealer should be able to get these. There are a waste of money IMOand i will not be purchasing them again.
Adelaide RC
Walter Rc Hobby
Old 07-16-2012, 02:05 AM   #3880
Pattojnr's Avatar
Trader Rating: 19 (100%+)
for Mod , you want to run these. if you like DNF then go for the plastic ones. the pins hammer the plastic, and there is no real re-enforcement in the plastic surrounding the pin locator. after a few runs, especially if you are a hard braker, your car will do funny things. the alloy pullies are worth running in Mod. one less problem to look for or worry about.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-16-2012, 05:42 AM   #3881
that the problen I am having , the middle pully wares out where the pins sit.
Old 07-16-2012, 05:45 AM   #3882
TimPotter's Avatar
Old 07-16-2012, 06:05 AM   #3883
Hi.
We are running modified, and we have the alloy pulleys built in right from the start - almost one year ago. We are still running the first pulleys, and they are still in good conditions - only a scratch from a little stone, when driven outside. We installed the alloy pulleys, as we had bad memories with plastic pulleys and gear diff. in our older car (Tamiya 416X). Several DNF because of pulleys melted down.
A little tip. When you install the alloy pulleys, put in a tiny(!!) ball of cleaning gum, where the pin are seated. Then you have no noise (like tic-tic-tic), as the pin now are seated well.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 07-16-2012, 06:17 AM   #3884
rave1010hk's Avatar
Originally Posted by TimPotter View Post
Nice...
My S411 SPORT closer pics
Serpent S411-dsc01111.jpg   Serpent S411-dsc00025.jpg   Serpent S411-dsc00026.jpg   Serpent S411-dsc00029.jpg   Serpent S411-dsc00050.jpg
Old 07-16-2012, 06:21 AM   #3885
MikeXray's Avatar
Trader Rating: 73 (100%+)
You're pitboard costs more than the kit
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
