Old 06-23-2012, 09:40 AM   #3781
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Trivial question.
Do u guys use the carbon fiber battery mount? And how do u strap the battery down on this car? I see the instructions in the kit has Velcro straps with the std battery mounts, but it looks like it will slide out. With the carbon fiber battery mount, how do u keep it mounted?
Thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 06-23-2012, 05:51 PM   #3782
Strapping tape, cheap and reliable.
Serpent America l Picco l Desoto Racing l Leisure Hours Hobbies & Raceway
RC Addiction Products l Nitropro Fuel
jsorwell is offline   Reply With Quote
Old 06-23-2012, 08:09 PM   #3783
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by teeforb View Post
Trivial question.
Thx
Use good tape. Your in the US so i suggest you invest in some of this
http://www.nexusracing.com/product_i...products_id=49
This is as good as the Hudy tape at a third of the price. Just change it out every race day
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 06-23-2012, 08:58 PM   #3784
cwoods34's Avatar
Trivial question.
Thx
I've been running with tape only for awhile now (on bumpy asphalt). No issues losing the battery...... One big looped piece and a couple on the side keep it secure.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 06-24-2012, 08:05 AM   #3785
teeforb's Avatar
What's the roll center spacers?
Old 06-24-2012, 11:34 AM   #3786
teeforb's Avatar
I'm running a 47t pinion. It seems that I have to take the spur gear off just to get the motor screw on. And it seems that I need to take to spur off just to tighten the motor screw. I'm running 96t spur. The motor screw does not seem to align with the hole in the spur.
To add to my questions. I am using the airtronics mt4 with spectrum low profile servo. It seems that to get close to full steering, i need to set my EPA to 150 (max of the controller). Is this right? and my servo is like 0.08 secs. It doesn't seem that fast. I am thinking because it has to go full throw (almost 180 from left to right).
Am i doing anything wrong?
Old 06-24-2012, 07:06 PM   #3787
cwoods34's Avatar
What brand spur are you using? Not all will line up properly. I will check what I am running tomorrow..... I use 94 and 96 with pinions up to 50 and can always reach the screws.
Be careful what you determine as "full lock". I add EPA until the tires are about 1-2mm from the lower shock mount..... If you add EPA based off the knuckle touching the caster block you may add too much and rub the shocks.
I don't know about those electronics, but with my DX3R and KO servo I get maximum steering with the left/right EPA's at around 120, and my overall steering rate turned down to 85%...... i could dial a lot more in but it would rub.
Old 06-24-2012, 07:14 PM   #3788
I'm using the TC6 spurs, has large cutouts for tightening the motor screws. Fits the S411 hub fine.
red7fifty is offline   Reply With Quote
Old 06-24-2012, 08:08 PM   #3789
teeforb's Avatar
It's around 1-2 mm away from the caster. My DR is at 100% and EPA is max at 150 both left and right. And the horn is tilted 10Deg as the manual states.
Old 06-25-2012, 04:57 AM   #3790
orcadigital's Avatar
Trader Rating: 61 (100%+)
Trivial question.
Thx
Strapping tape as others have said. I am down the street from Nexus and their tape works great. I double layer it, then go mount to mount over the top of the battery. With the battery holders on the outside and the stops on the inside, I am only worried about keeping pressure down. I have never lost a battery, and I am able to reuse the same tape for a good 4-5 spur/pinion changes. I charge the battery in the car, so do not remove it unless I am servicing something.
It depends what brand spur gear you are using. I have Xray, RW, Core RC and Serpent. All seem to work, but I also cheated and bought a ball-end 2mm wrench specifically for that motor screw. I see too many DNF's from stripped spurs, that I am over cautious on my gear mesh and anything I can do to make it easier. I am running a 92t spur currently without any problems with a 50t pinion.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 06-25-2012, 10:40 AM   #3791
pcar951's Avatar
Trader Rating: 19 (100%+)
You have a Serpent 96T spur gear fitted on your S411. Install the front motor screw into the slot from in front of the gear then use a ball drive to thighten it through the access holes in the spur gear (leave the front motor screw in place when changing motors). That's how I did it... FYI, in 17.5 blinky I ran 96/48 had good rip.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 06-25-2012, 10:59 AM   #3792
teeforb's Avatar
thanks! i think i have it sorted... i'm running 96/47. i think this should be good!
Old 06-27-2012, 05:42 AM   #3793
TryHard's Avatar
So my 411 is all built and ready for Sunday now, and I have to say so far that my over-riding impression is very good. Build went together very well, only had a few small issues.
I did take the opportunity to add some of the choice parts (hard wishbones, DCJ's, one piece motor mount) whilst building, as in most of the setups I've seen these are run.
So thoughts from the build.
Everything seems to drop together nicely, although the manual could do with some more detail in places (e.g. Where's the internal ratio?). Have to say that using grease on the turnbuckles turned out to be a must, as the plastic seems hard to thread. Thankfully still have my tamiya turnbuckle tool that the serpent ball joints fitted in nicely, making the turnbuckles easier to build.
Some of the anodising on my car seemed a bit different on the motor mount compared to the axle bulkheads, but no biggie.
I do like that the suspension brackets have a decent amount of meat to them, having had tamiyas before that would regularly bend with looking at them...
Diff.. With the v2, dropped together fine. Still not sure what to build it with just the two gears, so I do have a spare diff that I've built with four gears, to try out (before filling it with 500k for the front to test later still!).
One area that I was aware of when building was the steering, seems that the level of slop has caused some issues with other drivers. Well, I have to say that with my car, built as kit, and whilst there is a bit of play, it certainly nothing to be concerened with, and is less than on my previous Tamiya's! Actually, whilst setting the car up, I was impressed with the accuracy of the steering, made it very easy to get it straight and with same throw side to side.
Now it wasnt all positive... my worst part of the build was the shocks. I seriously struggled to get them all to build the same (even to get two too match!) in terms of rebound. I ended up switching out the bladders for some black tamiya ones, as the clear ones seemed to be a bit variable, some collapsing sooner than others, and affecting the damping rate. Even with the different bladders, still struggled to get them to match up, and I think that this is coming from the double o-rings in the bottom. Hopefully these will break in a bit after the first run, but if I still struggle... Well, that's in the future, want to give them a chance first. If anyone's got any tips or special code for building them though, happy to listen!
As I mentioned before, Ive already put the car on the gauges, and again was impressed with the fact that it all trimmed up pretty much straight and tweak free from the get go... Too easy!
Anyway, first run will hopefully be this Sunday, in modified, if the weather clears up! Looking forward to getting it on the track and contributing to this thread when I get a chance!
Regards
Ed
Old 06-27-2012, 01:10 PM   #3794
Johnny Wishbone's Avatar
Welcome to the Serpent gang Ed, definately let us know how your maiden run goes.
I finally got all my shocks built and installed, so I should have some feed back here in the next day or so.........also trying a couple of other things out that are out of the window so to speak......i'll keep you posted.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-27-2012, 01:20 PM   #3795
rdlkgliders's Avatar
GL with your maiden run., I hope you like a lot of steeeing the steering is what really impressed me on my first run.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
