Old 06-01-2012, 10:58 PM   #3661
Johnny Wishbone's Avatar
Originally Posted by rdlkgliders View Post
I made a quick change in between heats and lowered my inboard rear camber link to 1mm not remembering that the screw will protrude to far down through the shocktower mount and into the blades on the cvd. Needless to say I did a number on the blades but managed to finish the heat.
A friendly reminder when making roll center adjustments 1mm= bad
Yup got a set of nicely grooved outdrives myself, lol.
For the rear of the car, I run one car with the Xray balllinks that have the screw going thru them, just so I can use a screw and if its too long the I can put washers on the top side to space the screw end up and out of the outdrive. I also like the screw option on the outer that screws into the rear hub. Ran on one track that used a 5mm spacer setting which with the stock ball link left little thread going into the hub, so when ever I smacked the board it would pull the ball stud out and strip the hub. Going to the screw setup really gets more screw into the material. Now if they made a 10mm or longer ball stud, well that would be a different story.
I see that Fisher is well seated at the ETS race, really looking forward to see if he ended up with the forward arm sweep setup he had posted from a previous run.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-01-2012, 11:07 PM   #3662
pcar951's Avatar
Trader Rating: 19 (100%+)
Forward arm sweep...He's trying to take a little edge off the steering??
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 06-02-2012, 06:44 AM   #3663
Benzaah's Avatar
Trader Rating: 21 (96%+)
Fischer TQ round 3 at Apeldorn. Yeah Yeah.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 06-02-2012, 08:39 AM   #3664
Thats what it looked like to me too, steering edge off, little more rear traction, its that crazy asphalt stuff, makes you do crazy things to stay hooked up. LOL
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 06-02-2012, 10:35 AM   #3665
rdlkgliders's Avatar
The car is pretty challenging on the asphalt, making tire choice and tire treatment really important. I have been running 2mm FF and FR blocks.
I am really interested in testing Fischer's front block setup.
I would love to see him on the podium, The car has that kind of potential and deserves to be recognized for it.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 06-04-2012, 01:30 PM   #3666
tomracing's Avatar
I just looked at the setup sheets but the fischer sheets are not a reversed arm sweep they are 1.5 and 1.5 just the font in the pdf is to big to show the .5 text.
if you highlight the text you can make the .5 appear to show it is actually filled in as 1.5.
just so you guys know.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 06-04-2012, 10:26 PM   #3667
Default my new baby #063
S411LE#63,eryx 2.0,kyosho ultima sc,B44.1,futaba.the short list. Ricky Bobby body club,member #4
atmeearacing is offline   Reply With Quote
Old 06-04-2012, 10:45 PM   #3668
pcar951's Avatar
Really...a typo! I'm making my own Koolaid from now on!
Jim Chapman
Old 06-05-2012, 11:12 AM   #3669
RC MARKET's Avatar
Originally Posted by atmeearacing View Post
good !!
RC MARKET is offline   Reply With Quote
Old 06-07-2012, 06:36 AM   #3670
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
What do you mean it is challenging on asphalt ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-07-2012, 08:07 PM   #3671
I am referring to the rear grip on low traction tight tracks. My club track is a small and tight track with rear grip at a premium.
I am able to turn a pretty fast lap, however you do have to be on top of your game driving very smooth. I am sure that my situation is somewhat out of the norm do to the conditions.
Team Waldorf Racing
Old 06-08-2012, 01:33 AM   #3672
Benzaah's Avatar
I'd like to see your current set up and see how much steering epa you're running on your transmitter? I run low to medium traction and Im running the 2.5 rear block with a long link and still have enough traction, until i put the steering up past 80% to accomodate the lack of steering with older rubber. New rubber and steering around 65% and my car is weapon Only wish i had more disposable income for new tyres every meet
Adelaide RC
Walter Rc Hobby
Old 06-08-2012, 04:41 AM   #3673
Originally Posted by Benzaah View Post
I'd like to see your current set up and see how much steering epa you're running on your transmitter? I run low to medium traction and I'm running the 2.5 rear block with a long link and still have enough traction, until i put the steering up past 80% to accomodate the lack of steering with older rubber. New rubber and steering around 65% and my car is weapon Only wish i had more disposable income for new tyres every meet
I hear you I wish I had unlimited tire funds as well, In my original post I said tires and additive are a key factor. I do use a lot of steering, without it you won't get back and forth through the tight sections on our track. I will play with the EPA t again next time out. Thanks for the tip
Team Waldorf Racing
Old 06-08-2012, 06:44 AM   #3674
orcadigital's Avatar
Trader Rating: 61 (100%+)
Hehe I know where that car came from. It used to pit next to me before he joined the Xray dark side.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 06-09-2012, 03:34 AM   #3675
Hoot RC's Avatar
Whats your setup Benzaah and what tyres are you using? I am running on similar track conditions as you are and it sounds like you have your car dialed in. I am running Ride red tyres with Fischer Geilenkirchen setup. My car runs well but always looking to improve it.
Hoot RC
sales@hootrc.com.au
www.hootrc.com.au The shop for RC Racers.
Hoot RC is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
