Old 06-20-2011, 09:35 PM   #346
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by corallyman View Post
Are you a 64p or 48p guy? The max spur size that will fit is a 112t 64p or an 84t 48 pitch gear. With these sizes, the spur teeth is right next to the chassis. When the car flexes during cornering there is a chance that the teeth may hit. So go a little smaller if you have not purchased spurs yet.
Steve
nvrmd
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 06-20-2011, 09:48 PM   #347
venom54's Avatar
Default INTERNAL
Originally Posted by Team STPN View Post
What is the FDR for this car???
2:1
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 06-20-2011, 11:25 PM   #348
Steve
Thanks for the info Steve I've found this hudy 81t/48p in my LHS:
http://www.modellismogianni.it/catal...=72&cerca.y=13
And what about the pinion?
sirio76 is offline   Reply With Quote
Old 06-21-2011, 12:25 AM   #349
RC MARKET's Avatar
Sepent will ready release new Spur Gear !
Last Sunday HK Race S411 Won
used 2mm Carbon Chassis & 1.2mm Roll Bar !
Serpent S411-19june-race-2.jpg   Serpent S411-19june-race-3.jpg   Serpent S411-img_0342-1.jpg
RC MARKET is offline   Reply With Quote
Old 06-21-2011, 12:52 AM   #350
jensen123's Avatar
Very nice car with good result! Congratulation!
jensen123 is offline   Reply With Quote
Old 06-21-2011, 03:05 AM   #351
corallyman's Avatar
Trader Rating: 97 (100%+)
Try a 19t pinion, that will give you a 8.53 fdr which should be ok. Make sure you temp the motor and don't run for 10 minutes or anything like that. Make sure that the motor runs at a safe temp. How big is the track? Tight or flowing?
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 06-21-2011, 04:55 AM   #352
JayBee's Avatar
Trader Rating: 31 (100%+)
So what different spur gears work with this car? This is a rather dumb issue to have.....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-21-2011, 04:57 AM   #353
Trader Rating: 54 (100%+)
xray gears work fine. The center belt pulley has 3 holes instead of typical 4. Therefore, xenon, xray and several others will fit.
Jamison R is offline   Reply With Quote
Old 06-21-2011, 05:46 AM   #354
Steve
Ok, I'll start with 81t spur / 19t pinion. I'll check the temperature after 5 minutes, I suppose the temperature limits it's about the same as 1:8 brushless motors, I'll also use the rs-pro onboard temperature led to check everything it's fine.
The track doesn't seems too tight, the straight it's about 55m(180ft).
Old 06-21-2011, 07:30 AM   #355
Team STPN's Avatar
Originally Posted by venom54 View Post
2:1
Cheers
Ren
That is what I thought, Thanks
Team STPN is offline   Reply With Quote
Old 06-21-2011, 07:41 AM   #356
Akhor's Avatar
What are the crash test results on this?
If canada post would quit striking, I'd have mine already.. Sheesh.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 06-21-2011, 08:13 AM   #357
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i Tboned a T3 neither car broke, but my steering went out of alignment, i feel it turned a spline on the servo horn, so i am on to that now ! anotehr had a brush wiht the back wall, no damage done. so so far so good, no broken parts, bumper holds up well, i glue in the insert in the foam, i didnt take mine out.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-21-2011, 08:42 AM   #358
rendcool's Avatar
http://www.amainhobbies.com/product_...ouring-Car-Kit
they stock them now.
Itami o shitte ..
rendcool is offline   Reply With Quote
Old 06-21-2011, 10:32 AM   #359
corallyman's Avatar
Ok, that straight is a good length so I would guess that my suggested gearing would be on the very safe side of things, try it out anyways but you might end up gearing a tooth or two taller (bigger) on the pinion. If you can get some locals to help you out even further than that would be the best solution. The rest sounds good.
Our tracks around here are probably less than 120 feet in length and they are tempory tracks too.
Steve
Old 06-21-2011, 01:41 PM   #360
gearhead_22's Avatar
Send a message via AIM to gearhead_22
already winning that's what's up workin on gettihg mine
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
