Old 05-06-2012, 08:53 PM   #3556
Serpent Guy's Avatar
Originally Posted by Martin Crisp View Post
Sorry I took so long to get back to you
dont worry about it i appreciate your help
i will give you setting a try on tuesday, do you recommend changing them one at a time or just doing it all at once?
Serpent Guy is offline   Reply With Quote
Old 05-06-2012, 09:51 PM   #3557
Default S411 Limited Edition #001
Question:
LE #001, appears in ad photos......so what car is in the photo?
Was Car #001 assembled, or is it a "Clone" shown in the photos of the assembled car??? (Did they make an "extra" chassis for the prototype?)
Weird....
red7fifty is offline   Reply With Quote
Old 05-07-2012, 12:25 AM   #3558
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Johnny Wishbone View Post
I have about 6 months of parts to test on carpet and now that crazy mod class, should be fun. Although the Island race really sounds interesting.........are there any others in the works? We are always up for racing.
Only the "Driven" car show at the Olympic Oval here in June (9th I think). Usually a great race day, you may have been. Watch our thread for updates.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-07-2012, 04:38 AM   #3559
Martin when you get a chance can you give a detailed explanation of camber link outboard shimming and it's effect on the car.. IE what you expect from 3mm in an 3mm outboard shimming..
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 05-07-2012, 05:47 AM   #3560
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Not to answer for Martin but in my experience; I use to run the 3mm in and out on the rear link. I now run the 3mm out and 4mm inboard. raising the inboard link should lower the RC giving you more grip. I believe it is do to an increase in roll. (leverage on the car)
Dr Crisp can explain why.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-07-2012, 06:03 AM   #3561
celt's Avatar
I really like the snake the more I run it, and the more I run it, the more others start asking about it.
Mr. Wishbone...
Ran your 17.5 blinky setup this weekend and the car was faultless, and corner speed maniacal.
Awesome setup for anyone running this class.
http://www.petitrc.com/reglages/serp...401/index.html
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-08-2012, 03:18 AM   #3562
Celt....
That's the funniest avatar in your I.D. lol.... We've all had those days!
Old 05-08-2012, 05:47 AM   #3563
celt's Avatar
Originally Posted by red7fifty View Post
Celt....
Thanks...
I'm a UNIX / Network admin by profession. The avatar is more fitting than I would like to admit.
Stan Garvin
Old 05-08-2012, 04:18 PM   #3564
Johnny Wishbone's Avatar
Question:
Weird....
That might be a question better asked on the Serpent site, as we don't get the main factory guys from Europe on here very often if ever.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 05-08-2012, 04:22 PM   #3565
Originally Posted by celt View Post
Mr. Wishbone...
Thanks, hope it works well for you.
I've used that setup now for several tracks, only changing ride height (same droop) and springs, and it feels nice.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 05-09-2012, 09:01 PM   #3566
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
the guy in my place tested this and their car run quite well.
Steering Brace
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-09-2012, 09:46 PM   #3567
Martin Crisp's Avatar
As rdlkgliders indicates, having more shims inboard will lower the RC. Conversely if you have more shims outboard you will raise the RC. However to clarify, when you lower the RC you typically get less grip at that end of the car because that end of the car rolls more reducing the over grip of the two tires at that end of the car. The greater the difference in vertical load on the two tires at that end of the car (ie. more lateral weight transfer) the less overall lateral grip the car will have. This is due to something called the tire performance curve, which is explained in more detail in my app (http://www.setupworkbench.com).
What is interesting here is that a high roll center on one hand reduces the vertical load on the outside tire by reducing roll, but it also increase vertical load on the outside tire by increasing roll resistance. From the research I did, it seems determining which causes the greater difference in vertical load between the inside and outside tire, is very complex to calculate and in some situations can go one-way or the other. Given that, I rely on my testing results to tell me what is likely happening with our RC cars. From my testing a low roll center has less lateral grip than a high roll center, so I conclude from this that the roll has a greater impact on the difference in vertical load on the inside and outside tires. I think this is the case with our RC cars, because they tend to roll a lot for scale, compared to say full scale touring race cars.
Thus with a higher roll center causing the car to roll less and thus the more evenly the vertical load is spread across the inside and outside tire, you will have more lateral grip.
On high grip carpet I run a lower RC than on asphalt, because I am trying to reduce the chance of traction roll with a high RC causing too much lateral grip. On an asphalt track I run a higher RC to generate more lateral grip. That's why when you look at the asphalt setup I posted over the weekend the RC is a fair bit higher than the setup I run on carpet.
I hope this helps
Cheers
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 05-10-2012, 02:17 AM   #3568
Robert_K's Avatar
Martin,
Superb piece of explaning. And as far as I know, I expierence the same. But How can you connect this with cornerspeed. As far as I understand with a lower rollcenter the car has the highest cornerspeed. But am I correct?
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 05-10-2012, 07:35 AM   #3569
Benzaah's Avatar
Thumbs down
I hope this helps
Cheers
Martin, some questions regarding your asphalt set up. Interesting to see you end up with 3mm of shims on the V2 steering. Did you work up to this? How was your front tyre wear(ring of death)? I'm keen to try it this weekend at practice but there are a few gaps Im hoping you can fill. what brand oils are you using? what holes are your shocks running on the towers? What wheelbase shims were you running in the rear? and how much EPA did you run on the transmitter?
Regards Benzaah
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 05-10-2012, 02:40 PM   #3570
Martin let me better explain myself.. If you run 3mm inboard and 3mm outboard at the same time what does that actually do? It would seem that the RC would be the RC at that point as the link angle would be the same just higher right? Or is that just a fractional change? Just trying to figure out how shimming both up does for the car..
TEAM Black Ops.
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
