Old 05-04-2012, 04:23 AM   #3526
Originally Posted by Team_Krusty View Post
I think what Johnny means is that instead of using the 4mm spacers he uses 3mm spacers + a 1mm slide in shim. This means that roll centre changes can be made by easily removing the sliding shim rather than unscrewing the whole front end to change the spacer length.
Simon
When I first saw that upside down block on r/f I was confused because Ive never seen it done. Would he use a 3mm shim and two. 5 shims.? If you change front to a .5 wouldn't it be 3.5 in rear?
JETT is offline   Reply With Quote
Old 05-04-2012, 09:49 AM   #3527
Johnny Wishbone's Avatar
The r/f block when flipped uses a 4mm spacer so that, from the factory setup, that uses a 1mm shim in the f/f, gives the car level arms, ie. no front kickup. The r/f block when flipped require a 3mm spacer for a 0 lower roll center setting, as long as you take the 1mm shim out of the f/f bridge. so this would give you level arms again but the arm pin would be lowered but still level with the chassis.
So yes, if I would leave the 1mm shim in the f/f, I would use two .5mm shims to equal 1mm and be level. If I run a .5mm shim in the r/f I would change the f/f shim to .5mm as well to keep the arm level. Of course if I wanted to run kick I would add or subtract shims to get the adjustment I'm looking for.
The point of this, is using the 3mm spacers in place of the 4mm spacer in the r/f, and then just using the shims to set the lower roll center is a lot easier and faster to do than actually having to remove screws and spacers.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-04-2012, 10:34 AM   #3528
Martin Crisp's Avatar
Originally Posted by fasteddie d View Post
Hey Martin
We need to find a way to get you out here on the westcoast (Victoria and Vancouver ) I think you will be pleasantly pleased with the competition level out here .
I know that you have probably met keith from ocra and possibly Blake from Victoria . I think it would be a great way to promote the car . Maybe we could even get you in to a nitro touring car one day . Keep up the great work the info you provide really helps .
I would love to race out there...have heard great things. I pay my own way to races and with the reedy race, the worlds and vegas coming up I really can't afford another trip
Originally Posted by Benzaah View Post
Martin, Have you tested running the diffs in high and low positions? if so what were your findings?
I have not played around with this on the serpent. I have tried it before with other cars and always seemed to like th ehigh position, but did not notice a huge difference.
Originally Posted by duckman996 View Post
Looking forward to getting this car onto the tarmac tracks this summer. Last year - with less experience on the car, it seemed very planted. Learning what I have over the winter with the S411 - I can't wait to see what it will be like.
Corey, Steve, Andrew and I are heading to Ottawa this weekend to do some asphalt testing/racing. You should join us.
Cheers.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 05-04-2012, 04:07 PM   #3529
Serpent Guy's Avatar
i need alittle help
the rear of my car is really lose with almost no rear traction even using light throttle on asphalt
im running my s411 box stock (with exotek 2mm chassis) im using the stock set up with an Orion 17.5 and sweep 32 premounts
thanks for any ideas
Serpent Guy is offline   Reply With Quote
Old 05-04-2012, 04:55 PM   #3530
Originally Posted by Serpent Guy View Post
i need alittle help
Give this a try.
http://www.petitrc.com/reglages/serp...331/index.html
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-04-2012, 04:56 PM   #3531
i need alittle help
how much droop are you running on the front and rear of the car? Are you running 3.0 degrees rear toe-in. Also what are you running for shock oils, pistons and rear diff oil?
Martin Crisp
Old 05-04-2012, 05:03 PM   #3532
i need alittle help
how much droop are you running on the front and rear of the car? Are you running 3.0 degrees rear toe-in. Also what are you running for shock oils and pistons and rear diff oil?
Martin Crisp
Old 05-04-2012, 07:13 PM   #3533
Originally Posted by Johnny Wishbone View Post
thankyou i will try it sunday and report back
my rear diff oil is 1200cst
im running 3 degree rear toe
1.4mm sway bars
50k front and rear shock oil
3 hole pistons
orange front spring/yellow rear
i will be honest, i have seen droop measured so many different ways that have different out comes that i would prefer to keep it out of the equation for now (also im under qualified to get it right lol)
Old 05-04-2012, 07:20 PM   #3534
6mm ride height
light weight mazdaspeed6 body
Old 05-04-2012, 08:14 PM   #3535
I've got one on it's way!
BTW, is this car called "S Four Eleven" or "S Four One One" ?
red7fifty is offline   Reply With Quote
Old 05-04-2012, 10:36 PM   #3536
1.4mm sway bars
3 hole pistons
Hi,
I don't have Martins level of knowledge but I think that the diff oil is too heavy for your track surface. I would suggest dropping this to < 800cst
Simon
Team_Krusty is offline   Reply With Quote
Old 05-05-2012, 02:25 AM   #3537
Aza088's Avatar
1.4mm sway bars
3 hole pistons
Hi Serpent guy,
Droop is very important as this will effect how much weight is over the rear wheels either on power or off power.
Place the car on a setup board push the suspention in the front and rear down a few times then holding the rear wheels down lift the shock tower to see how much droop you have. There is no correct droop measurement every driving style is different i run very little droop like 2mm up travel front and back.
The rear diff to way to thick oil.
I'm running 800cst Xceed on medium grip asphalt even thinking about 600cst!!!!
One more question did you mention you have 50k shock oil as in 50000cst shock oil???
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 05-05-2012, 11:39 AM   #3538
Cheers.
I would have loved to but a new future RC racer decided this weekend was his time to make his presence be know to the world. Look forward to the feedback when you get back.
duckman996 is offline   Reply With Quote
Old 05-05-2012, 12:21 PM   #3539
Originally Posted by Aza088 View Post
Hi Serpent guy,
i will see if i can figure out the droop, sorry the shock oil is 50 weight
Old 05-05-2012, 02:18 PM   #3540
Yes droop has about half a dozen different ways of doing it. How are you setting yours, or at least, are you using Hudy droop blocks and droop gauge? Or just the over ride height method with a ride height gauge?
I prefer the method Martin Crisp showed me, using a Tamiya droop guage and going off the bottom of the chassis. Its quick, accurate and consistent.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
