Old 04-18-2012, 04:47 PM   #3481
Martin Crisp's Avatar
Originally Posted by Fred Hubbard View Post
Hi Martin Crisp
Freddy my man! great to hear from you. Are you going to the ready race?
ummm...looking at all the sponsors you have below your name...my list seems a little small.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-18-2012, 04:51 PM   #3482
erchn's Avatar
Hi Martin Crisp
Smart ass. ;-)
erchn is offline   Reply With Quote
Old 04-18-2012, 04:51 PM   #3483
Fred Hubbard's Avatar
LOL, I had to stretch them out a bit to make me look more important Yep I'll see you there, I think the weather will be a lil better than NJ, no need to worry about flash MONSOONS!
EDIT: True story, for the life of me I can't seem to win at getting your app. I called myself being smart and since I don't have an apple or android device I'd just find a good emulator and run the app from in there...no dice! I just can't win
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 04-18-2012, 04:52 PM   #3484
erchn's Avatar
Hey Ethan.
Weight balance is a very important aspect of car setup for sure.
From my testing when moving weight forward the car will push more on high speed corners and on corner entry of low speed corners. However on low speed corners as you finish the apex and start grab some throttle I find it can sometimes give a little more steering and forward bite. It will also overheat your front tires more and they will loose grip through the race causing the car to push more as the race goes on.
If have found that moving the weight to the back of the car tends to give the car more steering in both high speed and low speed corners. I think you loose a little bit of forward bite...but it might just be my imagination It will also cause the rear tires to overheat causing more oversteer later in the race.
I still think it is best to get as close to 50/50 weight balance. The balance you have is perfect I think.
I hope this helps.
Martin.
Sure does, thanks.
Old 04-18-2012, 04:54 PM   #3485
Originally Posted by erchn View Post
Smart ass. ;-)
ROFL, thanks Ethan.
Old 04-18-2012, 05:46 PM   #3486
Does anyone know when the new shocks will be avalible?
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 04-18-2012, 06:33 PM   #3487
They are available now.
http://www.rc-mushroom.com/product_i...411966-p-24464
http://www.rc-mushroom.com/product_i...411966-p-24443
Simon
Team_Krusty is offline   Reply With Quote
Old 04-19-2012, 02:39 AM   #3488
DeLaSoul's Avatar
Originally Posted by whityboy View Post
Any chance to share the setup tips.
thanks
I have driven both standard and flex top decks, each have there own place but I prefer the flex deck outdoors in 13.5T boosted. I've not run 17.5T blinky so don't know what Rob was up against but his car looked good in the finals. I do prefer the standard top deck on carpet
My Setup:
Front-
Hard c hubs
Spec-R 2.7 Spring
600cst oil, 4 hole piston
1.4mm Roll bar
Hole 2 on tower, outer hole on wb
2mm wheel base, Brackets 2 (FF) 1 (FR)
0.5mm shim on outer link, 5mm inner link - Long link
0.5mm shim (FF), 3.5mm shim (FR)
5.5mm ride height, 5mm droop
1.5 camber
Spool
Rear-
Spec-R 2.5 Spring
1.2mm roll bar
Hole 4 on tower, outer hole on wb
5mm wheel base, brackets 0 (RF) 3 (RR)
3mm on outer link, 2.5mm inner link - kit link position
0.5mm shim (RF), 0.5mm shim (RR)
6mm ride height, 4mm droop
2 camber
1300cst diff oil, 2 gear
2.25 chassis, 2mm flex top deck
WLRC's new surface is good on tyres so I ran 1 set all day, although it is a bit bumpy (hence the ride height)
I think that covers everything
Dave
Slikks Graphix - Model Cars Reading - Akula Racing - Serpent UK
DeLaSoul is offline   Reply With Quote
Old 04-19-2012, 05:49 AM   #3489
celt's Avatar
Default Serpent sour gears
Some time ago, I saw an awesome array of Serpent spur gears (both 48P and 64P) that were to be released or were released.
Anyone know what happened to them or where they can/might be purchased? Looked on http://www.serpentamerica.com, and didn't see any reference.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-19-2012, 06:19 AM   #3490
I picked some up a rcmarket
JETT is offline   Reply With Quote
Old 04-19-2012, 06:38 AM   #3491
Which one Spec-r DJC shaft fits better to S411? Yokomo or Tamiya?
valtsu23 is offline   Reply With Quote
Old 04-19-2012, 09:16 AM   #3492
Originally Posted by Kevin E. View Post
I have the same problem with a 87T 48P , i think i gonna use the dremel and create more space for the spur.
But i dont think this is a normal way
To quote my own post
Am i the only one with this problem ?
The 48P 87T spur dont fits , the spur is blocked complete on the chassis.
But the strange thing is , that i use the original spur from Serpent.
Really dont get it .
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 04-19-2012, 12:05 PM   #3493
time to buy an android or iphone device my friend so you can get my app
Martin Crisp
Old 04-19-2012, 12:58 PM   #3494
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Martin on the website it shows pics of the app, In some of the screenshots it looks like there are added options if you get the app for the Iphone/pad products over the android products. Am I seeing things?
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 04-19-2012, 01:21 PM   #3495
Johnny Wishbone's Avatar
Post a pic if you can so we can see the problem. Secondly if you have a TE you might not get a response since they aren't out for distribution here yet.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
