Like Tree7Likes
Old 04-18-2012, 01:36 AM   #3466
Talking about spurs, what is the bigger one that you can use with the s411? One friend give me a 64P 113T spur and it is very close to the ground so in only 5 runs has been ripped. Ok it get ripped because I run over some kerbs but the distance between chassis and spur is near to zero. I was thinking about buying 64P 108T Does it have more clearance?
regards
javier
jimjav is offline   Reply With Quote
Old 04-18-2012, 01:57 AM   #3467
regards
javier
I have the same problem with a 87T 48P , i think i gonna use the dremel and create more space for the spur.
But i dont think this is a normal way
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 04-18-2012, 02:46 AM   #3468
funs's Avatar
Send a message via MSN to funs Send a message via Skype™ to funs
funshobby
funs is offline   Reply With Quote
Old 04-18-2012, 09:24 AM   #3469
DeLaSoul's Avatar
regards
javier
From memory the kit spur is 84 (48dp), which for me is as close as I want to go to the spur going through the chassis. The same diameter in 64dp is 112 (84/48 * 64). 113 is bigger so probably just too close to the bottom of the chassis to be safe. 108T should be fine as this is the same as a 81T 48dp
HTH
Slikks Graphix - Model Cars Reading - Akula Racing - Serpent UK
DeLaSoul is offline   Reply With Quote
Old 04-18-2012, 09:30 AM   #3470
DeLaSoul's Avatar
Originally Posted by whoopass View Post
Serpent S411 clean up at the BRCA clubmans... 13.5 boosted and 17.5 blinky
http://www.redrc.net/2012/04/brca-cl...als-r1-report/
Video's of the mains are here...
http://www.youtube.com/results?searc...78.702.13.13.0.
enjoy!
As Rob said, the S411 drivers made up top 3 in 13.5 open and 2 of the 17.5 blinky classes at the weekend. This is only my second meeting with the S411 on tarmac (and by working with the other S411 drivers at the meeting) it is already coming up to pace. Looking forward now to the rest of the outdoor season!
Old 04-18-2012, 10:56 AM   #3471
whoopass's Avatar
same as Dave, I ran the car for the first time on Sat. It needed 'calming' down a bit on the steering as it has too much, then spoke to chris and Mark who steered me in the right direction on setup. So a big thanks to the Serpent UK boys.
PS. did not like the cut/flexi top deck. too wallowly in corner entry for my liking, but would suit a damp/low grip circuit more for me!
other than that the car was fast and easy to drive.
whoopass is offline   Reply With Quote
Old 04-18-2012, 12:24 PM   #3472
whityboy's Avatar
Any chance to share the setup tips.
thanks
whityboy is offline   Reply With Quote
Old 04-18-2012, 03:12 PM   #3473
Martin Crisp's Avatar
thanks
what do you want help with?
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-18-2012, 03:40 PM   #3474
oh i want that!
paulmayfield is offline   Reply With Quote
Old 04-18-2012, 03:47 PM   #3475
Johnny Wishbone's Avatar
Default Martin Crisp
Hey Martin, good luck in that next upcoming race.
Did you get my e-mail about speed controls?
Gary Lanzer
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-18-2012, 05:03 PM   #3476
erchn's Avatar
I'll hijack this question. :-)
I've looked around and haven't seen much on the subject, so wondering your thoughts on front to rear weight balance. My current car is about 47% front/53% rear. I assume each car/track likes a little different balance, but there's probably a range of JustRight (tm).
Your thoughts?
Thanks,
Ethan
erchn is offline   Reply With Quote
Old 04-18-2012, 05:15 PM   #3477
Trader Rating: 30 (97%+)
Hi guys have some stuff left over from the s411, outdrives 401414 plus diff rubber o ring the large one, and the two small white ones as well as the large shims, 0.5mm suspension spacers 401426, spacers 3x2 amd 3x1 in anodized orange, everything is new, selling for 19.99 usd shipped in canada or lower usa, just the diff outdrives are 25 and you cannot even get the small diff o rings the white ones seperate, thanks
zaraz is offline   Reply With Quote
Old 04-18-2012, 05:37 PM   #3478
Gary Lanzer
Sorry I missed the email...oopss
Anyway..the best place to get ORCA products in North America is Much Hobby. www.muchhobby.com
Patrick Chan is the owner...good guy.
Martin.
Martin Crisp
Old 04-18-2012, 05:43 PM   #3479
Fred Hubbard's Avatar
Hi Martin Crisp
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 04-18-2012, 05:45 PM   #3480
Your thoughts?
Thanks,
Ethan
Hey Ethan.
Weight balance is a very important aspect of car setup for sure.
From my testing when moving weight forward the car will push more on high speed corners and on corner entry of low speed corners. However on low speed corners as you finish the apex and start grab some throttle I find it can sometimes give a little more steering and forward bite. It will also overheat your front tires more and they will loose grip through the race causing the car to push more as the race goes on.
If have found that moving the weight to the back of the car tends to give the car more steering in both high speed and low speed corners. I think you loose a little bit of forward bite...but it might just be my imagination It will also cause the rear tires to overheat causing more oversteer later in the race.
I still think it is best to get as close to 50/50 weight balance. The balance you have is perfect I think.
I hope this helps.
Martin.
Martin Crisp
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
