Old 04-09-2012, 03:59 PM   #3406
Johnny Wishbone's Avatar
Originally Posted by Ovcloock View Post
the steeringblock are defective and that does not happen you need to put a siim Whaser betwen a bearing steeringblock of 0.30
I have received here in Spain 4 s411 TE all have the same problem
Can you post a pic of the problem and the fix? Thanks
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-09-2012, 04:30 PM   #3407
LOW ET's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Johnny Wishbone View Post
Most of the time I have the body trimmed to the cut lines and mounted, I make sure the nose is solid and has little flex, use a third mount to keep the hood from sagging. Then with the tires on the car (ride height set) I run a sharpie around the body to see how far out it is, which by all accounts is about 4mm more trimming.
that's just it, if the ride height is set at 5mm and you run a sharpie around, which is @ 6mm. the body is 1mm above the chassis ride height. now my next question is would this be illegal because the body has been cut above the cut lines? i thought the cut lines have to be used to meet the body specs for competition?
LOW ET is offline   Reply With Quote
Old 04-10-2012, 11:19 AM   #3408
beaim's Avatar
Trader Rating: 8 (90%+)
Send a message via MSN to beaim
after tie up the wheel. its feel like bearing jam, so i rebuild all 4 upright. before tie up the wheel, its smooth..tie up again problem occur.how to solve it??? my te is almost new. my experience tell me is the pin hole of wheel adaptor too deep yet it lock up both bearing after tie up the wheel..really upset on it.
beaim is offline   Reply With Quote
Old 04-10-2012, 01:04 PM   #3409
Never been to a race where they tech the cut line, its always minimum roof height and deck spoiler cant be higher than the roof. The IIC only did the spoiler check, but I would think a ROAR sanctioned race would do both. Cut lines may be a tech for BRCA though, can't say for that.
After I do a trim like that, if you take the wheels off the car and put it on your setup board there is little to no gap between the body and the board. (When the body is pinned on the chassis). You could slam the body but first you wouldn't make the minimum body height measurement and chances are real good that the front wheels would rub the upper front fenders causing even more problems.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-10-2012, 01:10 PM   #3410
If you could post some pics we could maybe come up with a fix.......but I would contact Serpent to let them know about the problem so they could fix you up. This could be another known issue as to why the LE is on hold.
Tim Potter you have a LE kit, have run into this problem??
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-10-2012, 01:53 PM   #3411
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I have not finished bulding it, but was informed of an issue with the front wheel hexes/axels that bind when tightened. They are working on a fix.
I am putting the front end togther today, so when I get it done, I will check it out and report back.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-10-2012, 02:20 PM   #3412
Default S411te
//img36.imageshack.us/img36/8943/lafotoxn.jpg
Here you hace a photo of the temporary solution, serpent appears to have recognized this problem or defect and a rear differential q the new covers are wider and that makes q the Rear back will not get soft if more than 2 degrees or plate convergence less than 3 degrees
Ovcloock is offline   Reply With Quote
Old 04-10-2012, 07:27 PM   #3413
So once again,could you not sand the face of the steering hub down so the bearing pocket is not as deep thus not letting the hex rub the outer portion of the steering hub?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-11-2012, 05:40 AM   #3414
celt's Avatar
Johnny,
You're talking about simply rolling the outside bearing face of the hub like a diff ring on sandpaper to give the bearing more reveal? Easy enough...
Luckily, I put my TE together without this issue...no bind at all.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-12-2012, 05:12 AM   #3415
dameetz's Avatar
Just to share with you guys, last weekend's race I TQed and won in one of the big race in my neighbouring country. It was a controlled motor class race (using Dualsky 10.5t) in an indoor carpet med size track. My car was flawless all weekend.
Here are the videos.....my car starting from pole (Fluorescent Yellow/Green + Blue) Final Leg 1 @2:15 had a bad moment with the back markers but managed to climb back to win the round.
http://www.youtube.com/watch?v=iBS5SPQipeQ
Final Leg 2
http://www.youtube.com/watch?v=Qbb504XzU2w
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-12-2012, 06:37 AM   #3416
Final Leg 2
Man, looked good. Mine sharing your setup?
JETT is offline   Reply With Quote
Old 04-12-2012, 07:32 AM   #3417
celt's Avatar
Final Leg 2
Very nice...
The red car was dogging you for some time. Good job in holding it together.
Stan Garvin
Old 04-12-2012, 07:57 AM   #3418
TimPotter's Avatar
I finished the front end build on the TE, I could eyeball that the outer bearings on the hubs seemed a little recessed, so I added a shim, and it looks good. When I run the car, I'll report back ( this weekend )
Old 04-12-2012, 07:30 PM   #3419
Default TE fixes
So, is there an estimated time Serpent will have the Team Edition "fixes" sorted out and have the kits shipping again?
I am looking to get one but would like to wait until the issues are sorted out.
bdortch is offline   Reply With Quote
Old 04-12-2012, 11:20 PM   #3420
WD40's Avatar
What issues are they having with the team edition right now? I am looking to maybe get one too.
WD40 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
