Serpent S411
#3393
I found the exoteck chassis actually added steering to my surprise given the cut-out should have made the chassis more flexible than the standard serpent 2.25mm chassis. But I think the weave of the fiber in the exotek is stiffer than the standard serpent chassis resulting in similar lateral stiffness, but in my opinion more longitudinal stiffness.
I don't know if they have released the upper decks yet that I tried, but they had some interesting designs that gave the rear of the car much more flex than the current available upper decks, which made the car very stable.
I am looking forward to trying these out on some asphalt surfaces.
cheers.
martin
#3394
If you wanted to use the stock top deck but have a little more flex, I use another stock top deck but have cut the back so it has two long rails, but its cut so that the center screw hole stays intact to avoid the flex/spur gear problem. Its basically cutting along the right rail only and keeping that center section attached to left rail. Its a nice alternate deck option over the flexi deck.
Also on my setup, the shock pistons are all three hole, one of them is incorrect, so just make sure you run the 3 holes.
Hope you like the setup.
#3395
Can't say what A-mains kit status is, but the supplier has a hold on the kits they have waiting for Serpent to get the fixed issues into the kits and then out.
#3398
From a performance standpoint, I found flipping the rack allowed for a more direct feel in steering feedback vs. the traditional position.
#3399
Duckman is correct, although I use a long ball end wrench and don't even have to remove the bumper to make the adjustments. You will have to trim some material of your battery hold down if you run it in the forward position. Put it together and you'll be able to figure how much and at what angle you have to trim the part.
Also on the LE the flipped arms is the normal assembly now.
#3400
i not sure u guys feel the same?? my te save tire even with -1.5 chamber all round. compared to my others car. does the soft arm cause this?
#3401
I did trim a pinch from the plastic tape retainer to get full steering, pretty simple mod.
Often times when building a new touring kit, everything is compared to "Xray" quality, for a long time that was the standard. Not sure what others have found, but this kit at least is as good in terms of materials quality and design for that matter, than anything I've built from Xray. Also, I can't see durability being an issue at all.
#3402
Durability seems to be very good. I have been running outdoors for 2 months plus and taken my share of impacts with both other cars and barriers. I have not broken anything (yet). I too like a lot of other guys on this thread used to run xrays, I still have a couple in fact and the Serpent holds up very well in comparison, both in durabiity and quality. I do like the Exotek bumper brace thougn as an option for the one potentially week spot especially when running the 2.0 chassis
#3403
how much ground clearance do you run on your body vs. the chassis ground clearance? for example: if your chassis has 5mm ground clearance, does your body have 5mm ground clearance? more clearance? less clearance? front and sides?
the reason i ask is i was looking at some racing photos of ets and ats tc series and the front splitter seems to be very "thin" compared to the cut lines that are molded in the bodies. it looks as though the sides may be cut in the right places but the front has been cut higher for more ground clearance.
what's your thoughts?
#3404
I have a probleme with my s411 TE on the left side my wheelhex and CDV getting really hot after 1 min, it's like the bearing sits a bit to deep in the steeringblock and after fixing the wheel the hex is rubbing the steeringblock.
is there any quick fix or is it better to just replace the steeringblock or can it be another problem.
thanks
thanks
the steeringblock are defective and that does not happen you need to put a siim Whaser betwen a bearing steeringblock of 0.30
I have received here in Spain 4 s411 TE all have the same problem
#3405
