Old 04-05-2012, 12:58 AM   #3376
daleburr's Avatar
Originally Posted by Adrean View Post
Hi Guys i just have a little question with tires , here there are a new track with Synthetic Grass , i always run in asphalt so i dont know anythithing about running in this type of surface , can you help me with the selection of the tires ? i always run Foams on Asphalt so i dont know what to use in the synthetic grass
This is the type of grass
Thanks in Advance
Cheers
You'll probably want spikes, Schumacher still make some I think:
http://www.wheelspinmodels.co.uk/i/24767/
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 04-05-2012, 11:05 AM   #3377
RC MARKET's Avatar
New RCM Shock Set
RC MARKET is offline   Reply With Quote
Old 04-05-2012, 02:15 PM   #3378
Originally Posted by RC MARKET View Post
New RCM Shock Set
My LE is slowly starting to turn half grey.
JETT is offline   Reply With Quote
Old 04-05-2012, 03:52 PM   #3379
Same here
C'mon Serpent make all the upgrade parts etc to suit the LE car.....
Otherwise i will have to buy a TE
Mike Schroder is offline   Reply With Quote
Old 04-05-2012, 05:55 PM   #3380
Garry aka Johnny W provided his latest setups and are available on petit.
HTH
Arn0 is offline   Reply With Quote
Old 04-05-2012, 06:38 PM   #3381
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
new whip.. will post pics during the build. And yes they are on hold, I got one that sneaked out. Better Serpent fix the issues then send something out that is not 100%
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-06-2012, 05:42 PM   #3382
Martin Crisp's Avatar
just like the color of my hair
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-06-2012, 06:02 PM   #3383
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
i would run a foam tire, like a carpet track thats blown out a bit...LOL
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 04-06-2012, 07:50 PM   #3384
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Me too, both car and hair. I think I am going for the creamsicle look on the car, a few more strategically placed parts and it should be there.
No Racing this weekend.....BIG BUMMER!!!!!
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 04-07-2012, 06:25 AM   #3385
celt's Avatar
Default reality check...
Building the TE with the new gear diff. The assembly comes with two smaller shims that appear to go behind the two planetary gears. The diagram does not mention them, so I didn't put them in. I did a dry fit and it seemed tight when I did use them. I didn't see any reference to them in the manual addendum either.
Just want to confirm that they aren't used, or what might they be used for.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-07-2012, 06:55 AM   #3386
Questions??
I didn't use the small shims either since the instructions didn't show them as being used. Maybe they are used when the diff starts to get worn and develops slop.
Old 04-07-2012, 07:20 AM   #3387
Really starting to love my Serpent. BTW yes the shims ,are used for when the diff starts getting some slop in it.
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 04-07-2012, 08:02 AM   #3388
Mike or Martin, any word on the Exotek top decks or a comparison of the Exotek chassis and the 2.0 serpent chassis?
Team Waldorf Racing
Old 04-07-2012, 02:44 PM   #3389
whityboy's Avatar
I have a probleme with my s411 TE on the left side my wheelhex and CDV getting really hot after 1 min, it's like the bearing sits a bit to deep in the steeringblock and after fixing the wheel the hex is rubbing the steeringblock.
is there any quick fix or is it better to just replace the steeringblock or can it be another problem.
thanks
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 04-07-2012, 05:11 PM   #3390
Johnny Wishbone's Avatar
thanks
Could you sand the face of the steering block down till you get clearance for the hex. I'd still be looking at getting a new one, but the sanding should get you going.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
