Old 03-28-2012, 07:24 AM   #3301
gearhead_22's Avatar
Send a message via AIM to gearhead_22
ok people the weather is gettin nice here in philly so i am ready to go outside and run tc mod, I wil have an 8.5 lrp in the 411, so anyone have a starting point for gearing the pics of the track is here http://www.rctech.net/forum/racing-f...season-22.html I have never run mod only 17.5 stock so I am lost.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 03-28-2012, 07:31 AM   #3302
DeLaSoul's Avatar
Originally Posted by Martin Crisp View Post
LOL!
Until 2012 I really did not play around much with the rear diff oil and always ran a light 800cst to give lots of rotation off power. However since the snowbirds this year I have been eperimenting a lot more with rear diff oil and could slap myself for not doing this sooner. The rear diff oil has a very big impact on balance of the car. I only run a spool, so I don't have any data on running a front diff. What I have found is that on higher grip surfaces, running a thicker oil in the rear diff makes the car more stable going in and better on-power steering. However on lower grip surfaces a thick rear oil tends to make the car loose on entry as well as exit. So for medium to high grip carpet I seem to like betwen 1000 and 1600 cst. For low grip carpet I like 800cst. I have not run the car on aslphalt yet, but I suspect something in the 800cst to 1200cst will be good with the 800 for lower grip and the 1000 to 1200 for higher grip surfaces....but just a guess at this point.
I hope this helps.
Cheers.
Martin.
Hi Martin,
I've been testing on tarmac over the last few days getting ready for the outdoor season here in the UK. I build up 5 gear diffs ranging from 700cst to 2000cst to try, and found that when the grip was low the 700 cst diff was the best and didn't want to go any lower. It allowed to the car to be stable going into the corner without locking it down too much. As the grip came up over the weekend, I ended up on 900cst. Thicker oils just felt too sluggish on corner entry and could be quite wild oversteer on corner exit.
Dave
Slikks Graphix - Model Cars Reading - Akula Racing - Serpent UK
DeLaSoul is offline   Reply With Quote
Old 03-28-2012, 07:44 AM   #3303
dawgmeat's Avatar
That track is way too big for 17.5 blinky or boosted
dawgmeat is offline   Reply With Quote
Old 03-28-2012, 08:56 AM   #3304
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Jewan,
The speed controller and programming have a lot to do with gearing.... That being said, for large tracks, you may want more motor.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-28-2012, 09:07 AM   #3305
Originally Posted by TimPotter View Post
Jewan,
so what motor should I go with,I am using a tekin rs esp
Old 03-28-2012, 09:09 AM   #3306
I am using a lrp 8.5, I ran blinky in doors for the winter.
Old 03-28-2012, 10:12 AM   #3307
cwoods34's Avatar
RS, or RS Pro? The regular RS can only handle down to 7.5 I think. For motors, nothing will outrun the LRP X12 4.0 (my fave)..... or the Reedy Sonic 5.0 is good, and very smooth.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-28-2012, 11:55 AM   #3308
not the pro and you are right 7.5 is the lowest, I have the lrp 8.5 so should I run boost or just gear it
Old 03-28-2012, 12:11 PM   #3309
Johnny Wishbone's Avatar
Got this from Paul Lemiux a while back, but still applies.
"Hi.
This is a rule of thumb for non timing speedos and any motor manufacture. depending on the track size and motor it could be a tooth or two on the pinion different. for timing speedos it depends completely on the speedo setting and their is many different gearing options based upon the timing settings on the speedo.
Everyone needs to take notice of motor temp at 3min when trying a new set up to ensure not to blow a motor. any manufactures motor will taper off in on track performance around 190deg (magnet gets weak) and most manufactures will not blow up untill 210-230 deg or more. if at 3 min your motor exceeds 170deg you are most likely too aggressive on gear or timing for a 6 min run.
Again this is for non timing speedos and just a good rule of thumb for a starting point.
21.5 turn, 3.6 overall
17.5 turn, 4.2 overall
13.5 turn, 5.1 overall
10.5 turn, 5.7 overall
5 turn, 8.1 overall
4.5 turn, 8.4 overall
4 turn, 8.9 overall
hope this helps a little. Thanks "
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-28-2012, 12:32 PM   #3310
cwoods34's Avatar
LRP's usually run a little hotter, and I don't know how much boost they like.... I always run Duo-based motors with Tekin. You could sell the RS and for 15-25 more (used) get a Pro!
Old 03-28-2012, 12:42 PM   #3311
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
"Hi.
5 turn, 8.1 overall
4 turn, 8.9 overall
nice cheat sheet.
Gearhead I shelved my Tekin for viper and am very happy, Adjustable bec and field programmer.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 03-28-2012, 12:47 PM   #3312
"Hi.
5 turn, 8.1 overall
4 turn, 8.9 overall
thanks just what I was lookin for
Old 03-28-2012, 08:46 PM   #3313
Tekinpro's Avatar
hi ... anyone here ever tried .... gft tires can share the settings you use to me ..
tr417+orca mk2.1+rx2+futaba 4pk+huge 70c..main depan rumah jer
Tekinpro is offline   Reply With Quote
Old 03-28-2012, 09:48 PM   #3314
Hey Don, sorry mate i just got a chance to send through that setup sheet. Let me know how you go with it mate.
Cheers,
Michael
Mike Schroder is offline   Reply With Quote
Old 03-29-2012, 04:48 AM   #3315
No problem, Thx Mike
I am curious to see what people are doing to get the car fast out doors on a low traction surface. Your setup is not a lot different than mine although you run more tow out shorter wheelbase and a shorter rear camber link.
I am glad both our cars are working well. I am probably going to shorten my wheelbase 1mm to 4mm this week and let her rip, I don't want to do to much because the car was great last time out.
Team Waldorf Racing
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
