Old 03-25-2012, 02:00 PM   #3271
cwoods34's Avatar
Originally Posted by RugRunner View Post
My S411 is a little slow reacting after braking for corners and I have developed a small push. Any suggestions low to med grip carpet. For the push would a stiffer sway help?
Spool or gear diff up front? Gear diff in rear?
You could reduce rear droop, go lighter oil the rear gear diff, go stiffer on the front spring.....
Also.... are you hitting the brakes while turning the steering wheel? This will cause a push of some amount regardless of setup. Try grabbing the brakes quickly right before you begin turning.
I found a really good setup with lots of steering for our low-bite carpet track.... I will try to fill out a setup sheet in a bit if you want.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-25-2012, 02:21 PM   #3272
I think you want to go softer on the front end rather than stiffer. What you are describing sounds like there isnt enough weight over the front wheels under breaking. Try either a softer spring in the front, lower the front roll centre or add a little more rear droop to help with the weight transfer.
I'm still learning all this myself so hopefully I'm on the right track here
Simon
Team_Krusty is offline   Reply With Quote
Old 03-25-2012, 02:21 PM   #3273
Spool up front,gear diff in rear 60wt...your Cody right? I'm runnin Steve's Aka crptracer's setup it's modified from yours I believe he said. It's pretty money I brake with the wheels straight it just seems to be flat after braking.
RugRunner is offline   Reply With Quote
Old 03-25-2012, 02:31 PM   #3274
cwoods34's Avatar
I can't remember exactly what he's running, but I found a few more changes I like from running yesterday in Winthrop (pretty different from RCAR) that should translate decently back in Indy. Filling out the setup sheet now!
Old 03-25-2012, 03:08 PM   #3275
cwoods34's Avatar
AHHH computer is having issues.... I have a printed copy of the setup sheet however. Sorry!
Old 03-25-2012, 03:11 PM   #3276
ok i have done the setup sheet but unable to upload to here as it says the file is to big on a 200kb over i have tried to shrink the file no luck any other suggestions, thanks in advance.
Mike Schroder is offline   Reply With Quote
Old 03-25-2012, 03:29 PM   #3277
Rug.. I went to 1.75 or so on the droop in the rear it seemed to help. Also I switched to jaco blues and the car was even better. I am gonna give the 1.4 a shoot on the rear again I think with the traction we have had as of late may help with transitioning a bit, but the setup is still solid I think your better off just trying one thing at a time and run about 3 min or so... You can get opinions and advice all day bro but in the end u gotta wheel it! After my long 2yr vacation I'm just now getting my head in the setup it's suprising how much you forget!
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 03-25-2012, 04:19 PM   #3278
cwoods34's Avatar
I think I'll keep the 1.2 on mine, but go to 1500cst in the rear diff. I think it'd smooth out rotation a bit. I've been running with 8-15 clicks off the steer rate anyway and it still has lots of entry steering.
Old 03-25-2012, 04:37 PM   #3279
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
I am glad to see people starting to chime in with outdoor setups, good info.
My car was pretty awsome today, best setup yet. I am finally all over the low traction tight asphalt track setup.
Today I went to the white rear gray front spring setup with a minor 1mm inboard rear camber link increase from 3 to 4mm and increased the ackerman spacing to 2mm over 1mm, front downstop of 5.5 and rear of 4.8 setting no other changes from a week ago. The snake was hunting....
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 03-25-2012, 05:05 PM   #3280
I finally got Martin's Canada setup to open on my PC and I think i must have reached the pinniacle of my RC career as my setup almost matches Mr.Martin's to a "T"..Minus a spring rate and gear diff oil....Now if i could match his smooth driving style i might have something!!!
TEAM Black Ops.
Old 03-25-2012, 06:07 PM   #3281
Martin have you found the heavy gear diff oil plays a larger role with the spool? Every time I run the thicker oil the car really snaps around but that was with the gear diff but normally with the spool you don't have the entry steering you do with the gear diff.
TEAM Black Ops.
Old 03-25-2012, 08:19 PM   #3282
jag88's Avatar
Martin, I always thought that the camber links and how you shim them, had a greater effect on camber gain and a lesser effect on roll center. If I want to change roll center I would raise or lower the hinge pins. It seems that you shim the the camber links with the purpose of changing the roll center with camber gain not mentioned.
Could you please elaborate a little on this as I've have read it both ways and would be very interested in what your take is.
Also your book says (if I remember correctly) that the length of the link determines when the camber gain happens. Short links, the gain happens quicker but not as much and with long links the gain happens later in the corner but lasts longer. Is this still true ?
Thanks for your time.
jag88 is offline   Reply With Quote
Old 03-25-2012, 10:45 PM   #3283
Aza088's Avatar
New TE went together perfect, Everything was in the box not one thing missing.
From the first batch of kits it seams the parts quality is better and the new shocks are a breeze to build look forward to this car's first run tomorrow.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 03-25-2012, 11:07 PM   #3284
Go back to nitro you punce...
Old 03-26-2012, 04:16 AM   #3285
Aza088's Avatar
scared a nitro driver is going to beat u at your own game haha
www.bluerc.net
www.hootrc.com.au
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
