Old 03-23-2012, 11:57 AM   #3241
Thanks Martin & cwoods34.
Sydewynder is offline   Reply With Quote
Old 03-23-2012, 06:12 PM   #3242
Martin, Johnny and Don massive thanks for the help the car was alot more settled last night on un-prepped concrete. Started with the white springs all round and just found it to be way to lazy in the front and very tail happy in the rear through the infield so i went to grey springs all round and this settled the car as well as more steering. I also went to 600cst rear diff from 900cst and that helped alot as well.
All in all a lot better i will post my setup later today it will be a great starting point for a low traction setup and then fine tune from there.
I was alot more competitive last night then a fortnight ago the car was quicker and alot more consitent to drive. i was placed in 2nd through the beginning of the A final till i made an error and was on my roff for roughly 15 sec roughly 1 and i bit laps but cant wait till next week to go again.
Again thanks.
Mike Schroder is offline   Reply With Quote
Old 03-23-2012, 09:21 PM   #3243
Looking for some input on the VS2 rack!
First have you guys found that the 2mm of shims gives you the most mid corner steering?
Second how does this effect entry with the spool and do you feel the mid corner steering is at its best with the spool at 2mm?
Third how many shims are the equilivent to the VS1 rack?
Finally how different is the steering with the spool and VS2 rack when using the inside holes on the steering blocks and is there a gain in entry or mid?
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 03-23-2012, 09:36 PM   #3244
Martin Crisp's Avatar
Again thanks.
awesome!!
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 03-23-2012, 09:41 PM   #3245
the 2mm will give you more mid corner steering than 1mm shims.
as to it being the best....well that depends too much on the surface and grip levels. I have yet to run the car on asphalt...but my guess is that I will run closer to 2mm on asphalt to get more mid corner steering compared to the 1mm I run now on carpet.
You really can't have exactly the same as the V1 rack as the ball cups are a little closer together on V2...but I think the closest to V1 from a feel point of view is 0.5mm on the V2.
Using the inside holes on the steering knuckles will take away steering as it furhter increases the ackerman.
Martin Crisp
Old 03-23-2012, 09:55 PM   #3246
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Again thanks.
Great to hear Mike, I have found that on the outdoor low traction tracks you can go very light on rear diff fluid in search of traction.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 03-23-2012, 10:42 PM   #3247
Benzaah's Avatar
Again thanks.
What track are you racing at?
How low have you tested with diff oils? I have not bothered going lower than 600 as I have found that nice.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 03-23-2012, 11:11 PM   #3248
Castle Hill
No last night was the first night started at 1200cst (good for a track with a little bit of traction) then 900cst a little better then 600cst and that felt the best so far.
Old 03-24-2012, 12:17 AM   #3249
Won't be able to setup sheet till next week guys as the editable Serpent one doesn't allow you to save it. So i will do one and print and scan early next week.
Old 03-24-2012, 04:53 AM   #3250
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Mr Schroder driving a serpent ! Nice.........
an option you have is to download Bull Zip PDF printer. what this does is prints to file a PDF. so you can rename this file to Castle Hill and date it. then just open the File and press Print. !
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-24-2012, 07:25 AM   #3251
Ran my serpent for the second time last night. I am very pleased with the car now its very easy to drive and goes where its pointed. Wished I would have had better luck but there's always next time.
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 03-24-2012, 09:05 AM   #3252
pcar951's Avatar
Is anyone using spacers under the links at the steering knuckles with the V2 rack? There seems to be a little bump steer I'd like to get rid of.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 03-24-2012, 09:14 AM   #3253
I have ran 300cst and 2 gears on a sssslippery asphalt track.
Mike I can edit, save and print right from here using the editable sheet.
http://www.petitrc.com/reglages/serp...rpentS411.html
Team Waldorf Racing
Old 03-24-2012, 02:04 PM   #3254
Thanks i will give it a try later. Hey Patto how you going what's happening over in the land of the forgotten ???
Old 03-24-2012, 02:59 PM   #3255
I tried 1mm and 2mm and settled with 0.5mm. Anything more numbed the steering response too much for my liking. This car reacts so well to little changes, in most cases less is more with the S411.
duckman996 is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
