Serpent S411
#3196
Hi guys
It was a great weekend for me and Serpent in Denmark. I managed runner-up in the 3. Round Of Danish Touring Car Championship (DMSU) and became runner-up in the overall championship This indoor season.
#3198
i received my exotek chassis yesterday
my first impression is it looks great, im going to install it tonight, i cant wait to go test it out!
#3199
I purchased a the 2mm soft chassis (Mingnon Walter RC has stock of these) to use at a low traction track and one piece motor mount just waiting on the local supplier to get the flex top deck in and i will get one of these as well. I ran the LE in std config 2 weeks ago and struggled big time for grip so hopefully this will help. I also removed the servo holders and taped the servo so as not to loose flex through the front of the chassis also went to a softer shock oil as well as orange springs all round.
The box setup and parts in the LE work great on a gripped up track just struggled with a low grip track first time out.
I guess i will see what happens on Friday night
#3200
Well I ran the 2.0 and flex top deck today for the first time. Unfortunately we got snowed out before the second heat. I really liked what I felt for the short time I ran, I practiced a lot, much more than usual. The setup was strong on rear grip for the first time since I have ran the car. I am just not sure how much the ball diff had to do with it, I tightened the diff down pretty tight and still had great rear end grip. I am definetely the closest I have been for low traction asphalt.
This weeks changes pre race were v2 rack, chassis top deck and ball diff.
I actually tried droop settings and ride height settings to get more forward bite as the above changes gave me a mild push from apex out.
#3201
If I remember correctly, way back in this thread, someone actually narrowed the rear section of the chassis, cutting it in a bit to get even more rear traction. I don't remember if it was pre 2.0 chassis or post, though. I think the waist was reduced to about the same distance as the front of the car is done in stock form.
#3202
#3203
Front
std toe blocks
3mm shims under top arm
1deg toe out
V2 steering rack with 2 shims (with flipped arms)
Orange springs
350 cst shock oil
locked diff
2nd hole from top shock tower
outside shock holes on lower arms
2mm shim behind bottom arm and 2mm infront
Std sway bar
Droop 5mm
Hard arms and knuckles and Chub
1.5mm camber r/l
5.5mm ride height
Rear
std toe blocks
900cst shock oil
3rd hole from top shock tower
orange spring
Std sway bar
1mm shim infront of bottom arms 5mm behind
droop 5mm
Hard arms
Medium upright
1.5mm camber r/l
6mm ride height
Std top deck for know and 2mm soft chassis
1 peice motor mount
SP GT2.0 esc
SP 17.5 motor
Orca 6500mah 70c batteries
Savox low profile servo (taped to chassis)
Sanwa 441 receiver
I think thats all
#3204
Just my opinion and there are others that are more infomed, you have very heavy oil in your rear shocks also the springs could be softer try the yellow rear with the orange up front. The higher ride height in rear plays into this also making weight transfer to the rear end for traction not easy. I would run the same or lower cst shock oil in rear, softer springs and lower rear ride height.
I also run 4-5 mm spacing in front of rear arms.
hope that helps
hope that helps
#3205
The track is concrete medium length low traction -
Front
std toe blocks
1deg toe out
Orange springs
350 cst shock oil
locked diff
Std sway bar
Droop 5mm
1.5mm camber r/l
5.5mm ride height
Rear
std toe blocks
900cst shock oil
orange spring
Std sway bar
droop 5mm
Hard arms
Medium upright
1.5mm camber r/l
6mm ride height
I think thats all
Front
std toe blocks
1deg toe out
Orange springs
350 cst shock oil
locked diff
Std sway bar
Droop 5mm
1.5mm camber r/l
5.5mm ride height
Rear
std toe blocks
900cst shock oil
orange spring
Std sway bar
droop 5mm
Hard arms
Medium upright
1.5mm camber r/l
6mm ride height
I think thats all
I agree with rdlkgliders... way to stiff...make ride height the same etc. Also the front roll center is too low at ony 3mm spacers on inboard upper arm. Also the front shock oil is too light for the springs you are running, an the rear shock oil is waaaayyy too stiff.
Can I make a suggestion.. I would start with my setup listed here
http://serpent.com/file.php?FileID=5367
,,,and just play with spring rates I think the white will be a good spring rate for a low grip asphalt, but you may want to try a gray,..but nothing harder.
If you want more rear grip you can a) use the 3.5 rear toe in block b) use 3mm instead of 4mm on inboard upper link. I would try (b) before (a) to reduce the chances of the rear tires overheating later in the run due to too much slip angle.
You may also want to checkout my setup app available for android and for apple devices at www.setupworkbench.com, to help you learn more about how to setup your car so you can enjoy that serpent more!
#3206
#3207
Cheers Martin, tried a few combos on the car today and settled on 1.5mm, also on a gripped up track used the 2.5 rear block, worked very good, also tried the one piece motor mount and found there to be very little difference between that and the two piece mount, just my opinion.
Rhys
Rhys
#3208
Do you prep the concrete at all ? That has to be a pretty slippery surface. I wonder if the car is far to aggressive in the front end. Maybe changing the castor and eliminate the arm sweep, just throwing that out there as I have had no experience on concrete.
#3210
I hear you re: the cheat sheet in my app lol. I just wear bi-focal glasses
