Serpent S411
#3181
anyone running this chassis?
http://www.exotekracing.com/s411-s4x...is-extra-flex/
need to try something to get some grip back in the rear of the chassis (have tried springs/laying down shocks/different oils etc), wondering if this may help
#3182
That chassis only came out this week so it might be a couple more days before anyone has had a chance to run it.
Have you tried the 2.00mm serpent chassis and the 1.75mm top deck? How about running a ball diff over a gear diff? Maybe post your setup and we can try to see if there is anything else that might help.
#3185
I am also going to experiment with the ball diff, I will report back weather permitting on my findings. I also have not found enough rear grip and I have tried just about all the setup tips that have been offered. The car is pretty good now though, I just need a little bit more rear grip for my liking. I do not think you will get much feedback on the ball diff, I have asked a couple times but I do not think anyone has run it.
#3186
thanks jonny and gliders
Haven't tried the 2mm chassis, will need to get $$ to get one.
Setup is out of the box, tried suggested springs etc.
Was running this in 21.5 blinky class, technical track, med grip track. It was always a bit loose (out of the box), so a little while ago shelved it and ran 2nd hand trf chassis. Really want to try and get it going again. Reading all the posts takes a bit of time though. Other issue is i'm only one at local track running s411 in this class, so nothing really to compare it to at moment (hopefully that will change)
#3187
#3188
I was just looking at the exotek site and saw that they list 82mm wide and 2.25 thick for dimensions. The serpent 2.0 chassis is appx 82mm wide also and 2.0 thick. The Exotek does have diamond cutouts for flex, it will be interesting to hear comparison feedback on the 2 chassis. I am glad to see 3rd party companies making parts, that is always a good sign.
Stormer has a couple 2.0 serpent chassis left at $60.00
#3189
State titles
Just had had the state titles here qualified 4th and in the finals finished on a podium with a second place it was on a small technical carpet track which I have not raced on before I had to make quiet a few changes it was actually the first time I had used the 2.5mm chassi I will post the final set up for any one who is interested but in he end the nd the car was pretty fast not a bad result for some one who didn't turn up to the practice and used the qualifiers for the tuning of the car. . What a. Great TC
#3190
Martin crisp
Martin crisp your set up station app was awesome it reall assisted me in dialing in my serpent on the rug in the end my Carla's hooked up and very consistent
I used it to make my changes through out the qualifying heats to get my car dialed for the finals and it work
I am happy how easy it is to understand you have really put it together in a way that anyone could under stand besapp ever
#3191
Anyone know what springs/swaybars will come with the team edition car? Gonna order one, but I'm switch over from a cyclone to the S411, so I need to know what spare/tuning parts to order with the car.
#3192
Thanks for taking the time to write this. I love it when my setupworkbench app helps other drivers get more out of their cars. I still refer to it myself from time to time as I am old and sometimes forget things
Cheers mate!
Martin.
#3193
#3195
Cheers Martin, tried a few combos on the car today and settled on 1.5mm, also on a gripped up track used the 2.5 rear block, worked very good, also tried the one piece motor mount and found there to be very little difference between that and the two piece mount, just my opinion.
Rhys
Rhys
