Old 03-15-2012, 08:33 AM   #3166
snoopyrc's Avatar
If I was interested in this car coming from an S400 what should I expect to be differrent? Specifically how will it handle compared to the old ride?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 03-15-2012, 08:41 AM   #3167
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by BAD007SUZUKI View Post
go on their website and look at the picture of the chassis with the battery. it looks like rubber o-rings under the button head screws on the steering arms. i understand that it may not be. but it might be a good idea for those with steering slop.
Its just a simple shock o-ring. Wouldn't it bind on the bearing if you tighten the screw too much? I would prefer to use small shims on the inner race of the bearings instead if need be but I think the Exoteck CF steering brace will most likely take care of any steering slop.
YR4Dude is offline   Reply With Quote
Old 03-15-2012, 12:04 PM   #3168
Adrean's Avatar
Guys Just one question please , what is the recommended Final Drive Ratio for 10.5 and 13T with 5000mah Lipo Batteries ?
Thanks !
Cheers
Adrean is offline   Reply With Quote
Old 03-15-2012, 12:41 PM   #3169
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
It will be a great upgrade for you. The car steers a bunch more.. at least out of the box.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-15-2012, 01:20 PM   #3170
snoopyrc's Avatar
Thanks Tim. I would be happy with the S400 if I had parts for it. All I do is VTA and now Im interested in USGT. I still like nice stuff so I may pick up the 411 even if its overkill for what I plan to do.
Old 03-15-2012, 01:54 PM   #3171
TimPotter's Avatar
You will love the car... get the team kit.. and the additional spring/sway bars.. and you will be set. My S400 suited my driving style, I hated to see the part situation happen. But from what I understand.. these parts are sourced from the same place they get the parts for the other cars... so we should not have that problem again.
The aluminum is much better the the 400's It really will be an upgrade for you. Bummer though, the toe blocks will not work from the old car.
I really do not have the time I would like to spend on the car, but we have bunch of people here that are running, great support.. great car.
Old 03-15-2012, 02:16 PM   #3172
StevenOlsen's Avatar
Hi guys. I just Got an email back from smokem, they are Working on a chassis and they expect a release in about 2 months. I hoped it Would have been earlier :-(
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 03-15-2012, 03:17 PM   #3173
Thanks !
Cheers
We'll need a little more info...
i) Track size (length of straight).
ii) Boosted or Blinky Speed controller setting
13T as in 13.5 turn brushless?
duckman996 is offline   Reply With Quote
Old 03-15-2012, 03:22 PM   #3174
Originally Posted by Johnny Wishbone View Post
Hi Martin, just to confirm.......on your setup is that serpent white springs? or some other make?
Hi - I'm Martin... just not Martin Crisp. LOL.
Since I was pitting across from him at the Canadian Nats I can help out with this question.
At the Canadian Nationals Martin was using Serpent white springs on his car. I know that he has been trying different springs however, the serpent springs seem to yield better lap times on the tracks that we race at.
Old 03-15-2012, 05:32 PM   #3175
Johnny Wishbone's Avatar
Thanks. A couple other questions about that setup that the sheet doesn't show........what where you (either Martin, lol) running for ackerman, which steering rack, if V2 rack, where the arms flipped or normal, V1 or V2 motor mount.
Its a shame that we have so many options for the car, but the setup sheet doesn't allow for some, guess its time for a V2 of those as well.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-15-2012, 06:20 PM   #3176
LOL - with the different arms, steering, motor mounts etc, no wonder this car is becoming so popular.
Since I run pretty much the same set-up as MC I can help you out.
V1 motor mount
V2 rack with the arms flipped. MC actually pointed out that by flipping the arms it makes it much easier to change the ackerman since you you only have to take the front bumper off and use a longer 2mm driver.
I believe that MC was running 1mm total shims on the ackerman behind the ball-studs- personally I ran .5mm on my car to reduce the steering a slight bit since it suited my driving style a little more.
Being able to borrow set-ups from Martin Crisp always makes tuning a lot easier. Glad that he's running the Serpent chassis - considering he wrote the book on set-ups, LOL.
Old 03-15-2012, 07:55 PM   #3177
Martin Crisp's Avatar
Thanks Martin P (duckman) from answering those questions. just to confirm...just I was running the white serpent springs front and rear....and yes I was running the v2 steering with 1mm of spacers on the ball studs and also with the steering arms flipped over.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 03-15-2012, 11:17 PM   #3178
Adrean's Avatar
Thanks its a 60 meters straight , its a 1/10 NITRO TRACK , usually i run 10.5 Tekin RS PRO SENSORED ESC , and the 13T ITS A controled motor in a parking lot with no more than 30 meters straight its stock esc . We run 12 MINUTES with 5000 MHA LIPO
Thanks !!!!
Thanks to My Sponsor ---------- Capricorn America -------- Capricorn RC CARS
LAB C03/TESLA ENGINES
RCTARGET
Old 03-16-2012, 02:48 AM   #3179
RC MARKET's Avatar
SERPENT released Alum. C-Hub
RC MARKET is offline   Reply With Quote
Old 03-16-2012, 12:27 PM   #3180
Thanks !!!!
I'm going to guess somewhere around 5.1 to 5.7 to start and watch the motor temps for every 3 minutes till you get a handle on where the optimum fdr is. Biggest thing is don't get fooled with a fdr number, but watch the car on the straight, is it topping out too soon, or carrying speed too far into the corner.....does it need more punch, or more top end....and still is it staying at a safe operating temp.
***All this is if you're talking about a brushless setup. Other wise the fdr may be off but the theory should still apply.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
