Old 03-10-2012, 06:30 PM   #3121
Originally Posted by rdlkgliders View Post
No, I bought it off someone on this forum who had flipped the arms but not installed the v2 rack, after running a couple weeks I was going through the car and cleaning and rebuilding. And I wanted to apply all the v2 mods and realized that the arms were flipped without the v2 rack. I put it back to stock per manual and that is when I noticed the play. Are others finding the tolerances tight or is the play normal ?
I will probably just by the v2 assembly and rebuild.
Some have said that however all I have found is some play in the c hubs and steering blocks..
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 03-10-2012, 06:34 PM   #3122
cwoods34's Avatar
There is play in my steering assembly (v1), mostly up and down movement. I haven't noticed it causing any issues with alignment or causing erratic behavior.
Front to rear movement of my caster blocks are more noticeable. My front right (hard, all I had at the time) has more slop at the hingepin than the left..... may be worth half a degree more than the other side, but it doesn't cause any issues, either.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-10-2012, 06:37 PM   #3123
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Thanks,
I am going to just run this weekend and see what happens.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 03-10-2012, 06:42 PM   #3124
Thanks,
If it is at the bearing u can apply super glue to the outside of the bearing and install it quickly of course and that should help alot..
TEAM Black Ops.
Old 03-10-2012, 07:03 PM   #3125
I am sure when the car is moving it will be fine. I was just surprised, no big I will still run and have fun.
do the .015 qnd .010 shims come with the v2 rack?
thanks again
Team Waldorf Racing
Old 03-10-2012, 07:05 PM   #3126
LOW ET's Avatar
Trader Rating: 93 (100%+)
the v2 rack comes with 6 .5mm shims
LOW ET is online now   Reply With Quote
Old 03-11-2012, 06:21 AM   #3127
Just FYI I didn't have any Clearence issues with the V2 even with flipping the arms...I do run my battery in the back position but not sure it would make a difference...I have full lock also...is there something I'm doing right or wrong as everyone else has mentioned removing about a mm off the tape holder..
TEAM Black Ops.
Old 03-11-2012, 09:34 AM   #3128
LOW ET's Avatar
the problem will be when running the battery in the forward position. you just have to notch the corner of the tape holder and all is good.
Old 03-11-2012, 08:05 PM   #3129
Benzaah's Avatar
Has anyone tested running the shocks in the inner positions on the suspension arms? I got a 2nd hand kit and all the outside holes in the arms have been over tightened so wont hold the grub screw. I don't want to waste the plastics so i am running the holes on the inside. I've ended up with Green/black springs running 2nd hold from all in on the front and hole 5 outside on the rear. I played with nearly all the holes on the shock tower yesterday and I really like the feel of this but i don't see any set up sheets anywhere running these holes.
According to the Hudy set up book in the front the inner hole will give you more steering and the rear arm inner hole will give you more rear traction. A couple of the local mod guys think my settings are backwards and shouldn't work.
Here's a link to my current set up sheet.
http://www.mediafire.com/?w1x3313d5lh65ix
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 03-11-2012, 08:17 PM   #3130
A few of us at our local outdoor med grip asphalt track tried the rear shocks on the inner arm mount and found it to work well. I actually went with inner on the arm and the outer most point on the shock tower (most upright shock position) and found I had very good rear grip. Couldnt tell you the logic behind it - just that it worked for me
Simon
Team_Krusty is offline   Reply With Quote
Old 03-11-2012, 09:23 PM   #3131
Originally Posted by Team_Krusty View Post
A few of us at our local outdoor med grip asphalt track tried the rear shocks on the inner arm mount and found it to work well. I actually went with inner on the arm and the outer most point on the shock tower (most upright shock position) and found I had very good rear grip. Couldn't tell you the logic behind it - just that it worked for me
Simon
Interesting, good to know.
I had my best day yet. I made minor changes through the day. and a block change from 1.0 front rear to the 2.0 front rear block. I also did a droop adjustment I increased the front droop. I placed 3rd in heat one and then did a spring change from yellow rear and orange front to Grey rear and yellow front and placed second and cut my lap times. I then left the car as is and went to the a main and placed 4th. I let the guy who placed first in the a main drive my car and it looked like a handful for him really loose, he usually drives an xray. It was kinda funny I think I have just gotten used to the loose nature of the car and learned to drive it that way. the serpent seems to really benefit from a smooth driving style even more than other Tc's I have driven....fun day thanks for all the help you guys give.
Team Waldorf Racing
Old 03-12-2012, 06:43 AM   #3132
Ran the car yesterday for the first time. I had mixed feelings, I definitely see the serpent has potential. I will be ordering some option parts to try to settle the car down a bit for my liking. One thing I really don't like is the way the ball cups attach to the steering rack. I clipped a board a couple times and it popped off way to easy for my liking. So I will be installing xray ball cups. Coming from a older xray 007 this is a big change for me. going to read the thread some more. And get suggestions from Cwoods and nucarpetracer and hopefully gets this car dialed in for me.
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 03-12-2012, 07:12 AM   #3133
We will get it dialed in.. Don't worry about that!
TEAM Black Ops.
Old 03-12-2012, 07:22 AM   #3134
Ok going to hold you too that statement
J. Barton
Associated B5M
Associated RC8B3E
Old 03-12-2012, 01:49 PM   #3135
Johnny Wishbone's Avatar
Congrats Martin Crisp on your two big wins at the CDN Nationals. Looking forward to seeing your setups.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
