Old 03-09-2012, 07:33 PM   #3106
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Johnny Wishbone View Post
Never noticed, but will check and get back to you. How much bump steer do you run? Is this with the flipped arms or normal?
Ya , I am running the arms flipoed. I will have to re check my spacer setup on the steering rack.
I will copy your rack setup, I think you gave it to me.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 03-09-2012, 08:18 PM   #3107
crabboy's Avatar
Trader Rating: 57 (98%+)
Ok Mate, will wait for your report.
Rhys
Originally Posted by Pattojnr View Post
let you know next week man. im wanting to see the difference in diffs, spoke to Ronald last night, internals are still metal, and they are working on a lighter internal option also. i would have loved to see the alloy 19t pulleys in this kit, but not to be.
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 03-09-2012, 10:39 PM   #3108
Johnny Wishbone's Avatar
I checked and I can run up to 4mm of ackerman with 1mm of rc shims with a LE (4mm turn buckles) and no bump steer and still have no binding issues. I think if you ran a lot of bump steer you could run into a problem with the 4mm turn buckles.
Rhys
This is interesting as the rumor is that Tamiya is testing metal gears in their diffs, they can't take the mod power. Guess time will tell.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 03-10-2012, 02:59 AM   #3109
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Rhys
Spoke to Serpent AU today, they say a delay with the Kits. possibly 2 weeks away now.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-10-2012, 03:02 AM   #3110
Pattojnr's Avatar
the TE will come with metal gears still , but they are working on something new and a bit lighter. always an option for the stock and blinky classes to not have to run heavy diffs.
Serpent - Walter RC
Old 03-10-2012, 08:55 AM   #3111
Originally Posted by Serpent Guy View Post
im looking for this #401464
Lipo-battery-holder carbon in stock in the usa, any luck?
Nope I got an old associated oval car battery plate and made my own!..that way i made them a little longer for added security..
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 03-10-2012, 11:38 AM   #3112
here is a couple pics of the clearance between the linkage and 2.o block.
Team Waldorf Racing
Old 03-10-2012, 12:11 PM   #3113
LOW ET's Avatar
Trader Rating: 91 (100%+)
looking at your pics it seems you have your rack arms upside down. they normally aren't flipped like that unless running the v2 setup.
LOW ET is online now   Reply With Quote
Old 03-10-2012, 01:12 PM   #3114
got it, like a moron I just went with the info I got that the le comes with the v2 and never compared it to the v1 da. I bought the car prebuilt and the rack was already installed, funny thing is that there is no anodizing on the top of the arms. Thanks for the clue in I will run the setup in the manual and order the v2. any tips on the v1 setup?
Team Waldorf Racing
Old 03-10-2012, 01:39 PM   #3115
LOW ET's Avatar
v1 is v1, there is no adjustment. v2 has an adjustment.
Old 03-10-2012, 02:18 PM   #3116
Serpent Guy's Avatar
thanks, i guess im going to look for something to make them from
Serpent Guy is offline   Reply With Quote
Old 03-10-2012, 02:20 PM   #3117
LOW ET's Avatar
http://www.serpentamerica.com/shop/p...2&cat=0&page=1
Old 03-10-2012, 06:00 PM   #3118
I never realized how bad and sloppy the steering assembly is, really bad.
after taking the rack apart and re assembling I was dissapointed.
Team Waldorf Racing
Old 03-10-2012, 06:13 PM   #3119
dawgmeat's Avatar
Didn't you build your steering rack A$$ backwards
dawgmeat is offline   Reply With Quote
Old 03-10-2012, 06:23 PM   #3120
No, I bought it off someone on this forum who had flipped the arms but not installed the v2 rack, after running a couple weeks I was going through the car and cleaning and rebuilding. And I wanted to apply all the v2 mods and realized that the arms were flipped without the v2 rack. I put it back to stock per manual and that is when I noticed the play. Are others finding the tolerances tight or is the play normal ?
I will probably just by the v2 assembly and rebuild.
Other than the arms being flipped it had spacers added that put the rack at pretty much the same place it sets now, I am not sure it had any effect other than lowering the arms.
Team Waldorf Racing
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
