Like Tree16Likes
Serpent S411
Old 02-28-2012, 09:22 PM
  #3016
Martin Crisp's Avatar
Default flipped steering arms
So I decided to try flipping the steering arms that connect to the ackerman v2 plate and see what it felt like. I know that the ackerman would increase slightly and it would have an impact on the bump steering. The result was fairly expected...which was an easier car to drive due to less steering. It seem to be about the same pace as running the the normal way, but it was a little easier to drive.
Martin Crisp is offline
Old 02-28-2012, 10:44 PM
  #3017
Me and my friend tried the V2 rack and we both like it.
2mm shims for ackerman settings feel the best as more mids and exits, 1mm just feel like the old rack.
I also found less wheel chattering during corners, love it.
My friend tried the flip arms but he go a bit slower after that change.
I'm thinking to flip the arms and maybe put 1~2mm shims under knuckles to fine tune the bump steer.
DanDan is offline
Old 02-28-2012, 11:38 PM
  #3018
JamesReilly's Avatar
Trader Rating: 59 (100%+)
Race Report from the Mid West Grand Slam Race 4 at MSI
Qualified: 17.5 TC: 6th 13.5 TC: TQ
Finished: 17.5 TC: 5th 13.5 TC: 1st
Notes: I started with my recent set-up but they sprayed the track on Saturday morning this was causing a little issue finding a good balance as the corners were a little inconstant. Through out practice I keep trying different things looking for the right balance but keep coming up with too much steering or not enough. Quailifing ended up with me sitting 6th in 17.5 and TQ in 13.5 I ended up pretty much back at my original set-up with some little changes I spring rate lower all around and 0.1 thicker front sway bar. But the car was very good for the mains. The 17.5 main started out rough and I fell back to 9th or 10th and came back to 5th, I did get close to the main pack but made a few mistakes cost me. However the 13.5 main was a different story, we had a very clean start and I started to pull away and was able to build a good lead and was able to hold it to take the Win.
Thanks, Serpent, Sweep and Fantom for all the support.
James
Kelso race the same set-up with only a minor change for driving style he used a 2.6 front spring and the stock shocks same oils.
JamesReilly is offline
Old 02-29-2012, 05:01 AM
  #3019
Sorry sir, but what do you mean by "arms flipped"?
Thanks for your time.
february is offline
Old 02-29-2012, 05:31 AM
  #3020
The steering arms for the V2 steering rack.
Old 02-29-2012, 06:08 AM
  #3021
dawgmeat's Avatar
Preparing for the outdoor season big flowing track med. traction, what are your thoughts about running 2mm upper and lower chassis? Thanks in advance
dawgmeat is offline
Old 02-29-2012, 09:00 AM
  #3022
brunelli ale's Avatar
It depends...for example, we're running on outdoor track with just one tire set for qual and finals...so, i'm using the softest configuration ( 2mm chassis + 2 mm new flex topdeck) to stress tires as less as possible.
i think that you can use the 2 mm chassis and by track grip situation, you can choiche between different topdeck sizes and flex
2.25 mm is a good chassis also!
brunelli ale is offline
Old 02-29-2012, 09:44 AM
  #3023
dawgmeat's Avatar
thanks
dawgmeat is offline
Old 02-29-2012, 11:55 AM
  #3024
RC MARKET's Avatar
Serpent web site had last week S411 in TITC setup !
RC MARKET is offline
Old 02-29-2012, 03:00 PM
  #3025
Johnny Wishbone's Avatar
That should be a great starting point, the only thing I would do is the front bumper mod so you don't snap the front of the chassis off if you hard impact. Its a couple pages back with pics, myself and ? posted pics, the other guy ? has better pics than mine though. (Sorry forget who but his mod turned out nicer).
Also a chassis protector could help.
Johnny Wishbone is offline
Old 02-29-2012, 05:24 PM
  #3026
Serpent Guy's Avatar
i need alittle help
i picked up a set of Serpent DJC's for my s411, after installing them on my car i can no longer go to full lock the heat shrink is rubbing on the c hub, has anyone else had this problem, im kind of alittle lost on what to do next, currently im useing the stock 2 degree c hubs
thanks
Serpent Guy is offline
Old 02-29-2012, 05:47 PM
  #3027
Originally Posted by Serpent Guy
i need alittle help
thanks
Yes mine rub also but I haven't noticed an issue in performance they rubbed a small ring off the shrink and then that was it haven't noticed anything else by way of rubbing anymore..
NUCRPTRACER is offline
Old 02-29-2012, 05:52 PM
  #3028
LOW ET's Avatar
Trader Rating: 109 (100%+)
i'm under the impression that you have to clearance the older c hub 's so the djc doesn't rub.
LOW ET is offline
Old 02-29-2012, 05:56 PM
  #3029
You get another chassis yet?
smokefan is offline
Old 02-29-2012, 05:58 PM
  #3030
do you have a link to that info?
thank you for the help so far everyone
