Old 06-15-2011, 02:38 PM   #286
RC MARKET's Avatar
RC MARKET is offline   Reply With Quote
Old 06-15-2011, 03:49 PM   #287
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by jdogger1 View Post
Check out this story on Scott Kimbrough...
http://rcinsider.com/?p=12637
www.rcinsider.com
Scott has already been running for Serpent in 1/8 and 1/10 nitro for more almost two years. It would be obvious that he would leave whatever other electric gig he had as soon as Serpent made their comeback to 1/10 electric TC.
Defcone - I don't think Scott is related to the gear company of the same name. That person is Jay Kimbrough.
YR4Dude is offline   Reply With Quote
Old 06-15-2011, 03:51 PM   #288
YR4Dude's Avatar
Originally Posted by RC MARKET View Post
Serpent will later release Carbon Graphite battery holder !
Great! I'll wait for that before picking up the S411. Just got another Orion battery 6500mah 90C and its got a smooth bottom. Would like to use that on the S411 but I'll wait.
Old 06-15-2011, 05:31 PM   #289
RC MARKET's Avatar
Orion 90C = 45C only !
Old 06-15-2011, 05:40 PM   #290
YR4Dude's Avatar
So what does Orion 45C = ?
Old 06-15-2011, 05:53 PM   #291
RC MARKET's Avatar
lower !
Old 06-15-2011, 06:07 PM   #292
YR4Dude's Avatar
lower !
Ok great, because the new battery is an upgrade from an Orion 45C pack. Regardless of actual numbers the change is positive and I also gained another 1000mah in capacity as well. Unless you are also saying that Orion 6500mah is actually less.
To keep it on topic, how soon will the diff kit be available?
Old 06-15-2011, 10:57 PM   #293
RC MARKET's Avatar
later because option parts !
Old 06-15-2011, 11:22 PM   #294
Originally Posted by gearhead_22 View Post
chickey from serpent emailed me and said stormer and a-main will be gittin it soon
yeah ryt
civiceg is offline   Reply With Quote
Old 06-16-2011, 02:30 AM   #295
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 06-16-2011, 03:08 AM   #296
Trader Rating: 55 (100%+)
Originally Posted by P.I.M.P View Post
hi dose any one no of a o ring that fits the s411 shocks the x ring is very poor and binding the shocks up
Great...
Jamison R is offline   Reply With Quote
Old 06-16-2011, 03:20 AM   #297
Pattojnr's Avatar
Trader Rating: 19 (100%+)
sometimes the Clip at the bottom sits out too far and rubs on the shaft. make sure its not scratching on the shaft, and causing your issues. if not, take the seals out and have a look nothing is caught up in there. maybe on one shock only, as mine i have replaced the seals, and all is good.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-16-2011, 06:24 AM   #298
Scott Kimbrow's Avatar
Thank you very much for this clarification, it is spot on. My name is actually Kimbrow, so therefore it would be easy to see I am not related to Jay....however, those are fabulous Kimbrough people
The switch to the S411 is a very obvious one for me as stated above, but I must say that I wouldn't even have ever had an exposure to EP touring car racing if it wasn't for the great support of T.O.P. and in particular E.J. Evans. I enjoyed racing for them and appreciate all of their support. Thanks E.J.!
Now back to your regularly scheduled program...... the Serpent S411
Serpent / Serpent America / Novarossi / Spektrum / Xceed Tires / Tornado Fuel / Empire Racing / Protoform / Thunder Power / Avid Bearings / A-main Hobbies / Dynamite
Scott Kimbrow is offline   Reply With Quote
Old 06-16-2011, 08:09 AM   #299
wee
Default spur
may i ask what spur brand you guys r using?
the spur i am using now is a bit thin and i need to grind of the
screw off a bit.
well over all love the kit and is so pro!!!!!
10+ for serpent design team
SERPENT S733 , S966 , S811 , S400 , S411 TE & S747 SOON.......
POWERED BY NOVAROSSI ( GP )
POWERED BY HOBBY WING V3, SPEED PASSION AND LRP (EP)
wee is offline   Reply With Quote
Old 06-16-2011, 04:19 PM   #300
Pattojnr's Avatar
screw off a bit.
i have been using the Xray 84t 48p spur, and place a 1mm shim on the screws before they go in.
Serpent - Walter RC
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
