Old 02-16-2012, 02:02 PM   #2866
mattwoodcraft's Avatar
Originally Posted by bdortch View Post
So what hardness arms are you guys running with what chassis. I am thinking about the 2mm chassis. I run on a medium grip track. I am trying to stock up spares.
I race apps on a asphalt track got hard arms on the front mediums on the rear hard uprites on the front and medium uprites on the repeat have never broken any arms on the car yet
mattwoodcraft is offline   Reply With Quote
Old 02-16-2012, 02:34 PM   #2867
Johnny Wishbone's Avatar
Default You are correct.
Originally Posted by brunelli ale View Post
Sorry Johnny, but mine v.2 is 10.00mm , center to center, and...yes, with central servo linkage on plate, you must use 4/6mm spacers on servo saver, depends by saver
Had to go a ways back to find my post but found that when I measured it was 9.5 center to center, still not 8.5 though, for some reason thought it was. With that 8.5 or 8 would produce a better ackerman split.
Please post some pics when you get it.
(On a side note, if the in out of the setting doesn't bother you're setup, I think one could just re-drill the original plate with a tighter spacing to see what it performs like )
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-17-2012, 08:56 AM   #2868
dameetz's Avatar
Default Shocks x-ring
Do you guys have any advice or tips on how to smoothen the shocks action? At the moment I m building my LE, my 2nd s411, i found out 3 of the pre built shocks are not that smooth, my 1st s411 also have the same problem, only 2 of them are smooth. So today I disassemble the the prebuilt part of the shocks and found out the culprit to this was the x ring. Somehow the x rings on my 3 shocks looked like it was not cleanly round cut, there were burrs left over especially at the edges. I tried to cut those burrs but it was difficult to get it perfect. I m wondering are there any x ring or o ring (from other brand) that can fit nicely into our shocks.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-17-2012, 09:18 AM   #2869
Hello guys , does somebody has order the 4x7 flanged (1310) bearings on Rc Market already ?
Its strange but i cant find this product , maybe eyes are not that good
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 02-17-2012, 12:57 PM   #2870
BAD007SUZUKI's Avatar
Trader Rating: 93 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default almost....... wait for it.........
mine is almost built. just waiting on tires form europe. i have the body posts, extra shock towers to mod, and complete car. can't wait!
http://www.facebook.com/media/set/?s...2651256&type=3
R/C Fun Park 12990 SR23 Granger, Indiana 46530
BAD007SUZUKI is offline   Reply With Quote
Old 02-17-2012, 10:57 PM   #2871
corallyman's Avatar
Trader Rating: 97 (100%+)
Dameetz,
I am not sure if they fit or not but I do believe that Kyosho uses X rings on their shocks. You may want to look into that option.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 02-17-2012, 11:05 PM   #2872
Originally Posted by corallyman View Post
Dameetz,
Steve
Tamiya makes x-rings, too. I picked up a bunch in Hong Kong.
I think speedtech has 'em. If the serpent uses standard size o-rings, they should work. They fit in my TC6.1 shocks just fine.
-Mike
Old 02-18-2012, 12:00 AM   #2873
corallyman's Avatar
I still say that is such a cool car. I may have to give that a go once funds allow it. Please let us know how it runs.
What body did you buy?
Steve
Old 02-18-2012, 03:44 AM   #2874
dameetz's Avatar
Dameetz,
Steve
-Mike
Thanks for the info guys, I ll check it out.
Old 02-18-2012, 07:38 AM   #2875
Default 220mm
its a kamtec 220mm gt body. i bought on ebay. but if you search 220mm gt or gtp you should find several. its basically a 1/10th nitro onroad body. they are also refered to as "lola".
Steve
Old 02-18-2012, 02:55 PM   #2876
My S411 will be arriving Tuesday, just in time for the Midwest Hurricane Series to visit our local track next Saturday. What hex wrench is most common to the screws on the car?
FastHound is offline   Reply With Quote
Old 02-18-2012, 03:42 PM   #2877
Default 5/64
5/64 (green integy i think) will handle 95% of the screws. i only use 3 wrenches. 5/64, 3mm, and 1.5mm. those 3 will handle 99.9% of the car.
Old 02-18-2012, 04:30 PM   #2878
5/64" is 1.98mm, so I'm guessing 2mm is the correct wrench.
I'd recommend investing in a decent 2mm. It's so common on r/c cars you'll use it more that the rest of your wrenches combined. M3 nuts also use a 5.5mm nut driver, which can be hard to find. Associated makes a flat steel wrench that's 5mm on one end and 5.5mm on the other that's really cheap and comes in handy for me on my non-serpent cars. Wheel nuts are usually 7mm, and you'll have to take wheels on and off enough that it is nice to have a good one. If you buy wrenches, get something with a grippy handle so you can hang on when you've got shock oil, diff grease, or tire sauce on your hands. The cheap plastic handle ones at your LHS are ok for the off sizes like 1/16 (robinsion pinion screws), 1.5mm (set screws and m2.5 screws), 2.5mm and 3mm.
-Mike
Old 02-18-2012, 05:44 PM   #2879
JamesReilly's Avatar
Trader Rating: 56 (100%+)
I dont know if anyone needs a good start for a RCGT class for the 411 but here one is. It has excellent corner speed and keeps the rear planted through out the race.
Best regards,
James
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint (reillypaint@gmail.com)
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 02-18-2012, 11:53 PM   #2880
the wrenches you will need are 1.5, 2 and a 3mm
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
kwakaman33
