Old 02-15-2012, 02:51 PM   #2851
Johnny Wishbone's Avatar
Originally Posted by bdortch View Post
I am hearing there is a team edition that will be released. Does anyone have any insight when that might happen? I am looking to make a switch to the snake but I am contemplating on whether or not I should wait on the team edition or get it now. I am assuming the Team Edition will have items such as the new RCM shocks, V2 steering system, and possibly 2mm top/bottom chassis as standard???
http://www.redrc.net/2012/02/toy-fair-2012-serpent/
Not much info though.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-15-2012, 03:29 PM   #2852
Trader Rating: 30 (97%+)
I got another s411 le kit, it was expensive but thinking of anodizing it red or blue and just keeping as a self queen, just don,t like the orange that much, if some one has a regular brand new s411 with the gunmetal finish and wants to trade all the orange aluminum parts including the spacers let me know as I am willing to trade, except for the shocks as I sold them already, thanks
zaraz is offline   Reply With Quote
Old 02-16-2012, 02:22 AM   #2853
brunelli ale's Avatar
Hi buddies, we're working hard here in Italy, especially on stering system.
By last tests and ets 2nd round, we have found a strange feeling with s411 steer, we're testing new solutions on v.2 plate...I mean ( maybe Martin could prove me right):
Now we have 10mm between ackermann uniballs on plate, well, with that quote, steer feels like too much nervous early the corner ( when you start to push on radio stick), but loose front end from middle to exit corners.
Now we're testing a new concept plate with 8.5 mm distance, maybe better because both steer levels works more to the center of axes and steering feels more linear trought corner, from entry to exit. also we add an hole on the plate center to connect the servo's link, so the force that servo create on plate is the same for right/left sides.
It's just a test and i will update for time laps results
brunelli ale is offline   Reply With Quote
Old 02-16-2012, 03:37 AM   #2854
Sweet.. Good info keep us posted...can you post a picture would like to see the center mount?
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 02-16-2012, 03:40 AM   #2855
now plate is under cnc machine i'll have it in 2 days at least!
Old 02-16-2012, 08:46 AM   #2856
So what hardness arms are you guys running with what chassis. I am thinking about the 2mm chassis. I run on a medium grip track. I am trying to stock up spares.
bdortch is offline   Reply With Quote
Old 02-16-2012, 09:07 AM   #2857
I'm running the regular arms... The hard arms work great but I did explode one.. My fault cut it to tight and caught a wheel on the board...
TEAM Black Ops.
Old 02-16-2012, 09:18 AM   #2858
BAD007SUZUKI's Avatar
Trader Rating: 96 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default RECYCLE
HERE IS A UPPER BUMPER SUPPORT I MADE OUT OF A 2MM CHASSIS I DESTROYED. IT SUPPORTS THE UPPER BUMPER BY RESTING ON THE FRONT BULKHEAD TO PREVENT THE CHASSIS FROM CRACKING WHERE THE LOWER BUMPER MOUNTS.
ALL I USED WAS A REINFORCED CUT OFF WHEEL WITH MY DREMEL, A BENCH GRINDER, AND A DRILL.
TESTED IT OUT YESTERDAY. DINKED A WALL DUE TO THE SHEER SPEED OF THE 411, AND IT DID ITS JOB WITH MY NEW 2MM CHASSIS
BAD007SUZUKI is offline   Reply With Quote
Old 02-16-2012, 10:05 AM   #2859
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Nice job on the chassis support, It would be great if someone produced one, although its easy enough to make. I would like to se it mount to the 2 holes in the sway bar retaining bracket somehow.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 02-16-2012, 11:28 AM   #2860
Trader Rating: 14 (100%+)
I feel this will be a great update to the current steering rack. With my previous testing I have found that 8mm to 8.5mm of distance between the steering links to be the easiest to drive. With great handling around corners mid corner to exit steering gaining the most.
Alston Kelso
Destiny USA•SMC Batteries•Reilly Paint•CEFX
Detroit Racing Team
"Let's See, Open it up" -Chris Goetz
98tahoeboy is offline   Reply With Quote
Old 02-16-2012, 12:25 PM   #2861
I have to ask, why do you sell the shocks from every kit you get?
The stock ones. Never really saw a time difference between the two and the hard arms.........well they are hard and not as board forgiving.
Yes, nice looking support. I don't think tying in onto the bulkheads would be a good idea though. Any kind of impact could domino through the chassis and could effect other aspects of the handling. JMO.
The stock V2 is 8.5mm center to center, so I'm not sure they are changing anything other than putting a hole in the center to hook up the link to the servo. The bad part about that is on lock to lock it will but a really weird angle in the link to the servo, so you'd have to run a lot more spacers between the servo saver and the pivot, again JMO.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-16-2012, 12:50 PM   #2862
Hi, LOL, I sell the shocks from most kits except my tamiya and kyosho, all other kits I have be it a serpent, xray, hb etc,etc, the shocks are garbage, well I think they are garbage, so I usuall replace them with either tamiya shocks or kyosho shocks, I usually have an extra set of trf shocks or the kyosho w5302v shocks, for me they just work better and easier to built with 0 rebound, and last forever, between rebuilds, and replacement parts are cheap and easy to get, as for serpent shocks I just cannot built them, but if anyone still wants to trade for the orange aluminum let me know or on monday car is getting anodized blue to match my tamiya.
Old 02-16-2012, 01:17 PM   #2863
Sorry Johnny, but mine v.2 is 10.00mm , center to center, and...yes, with central servo linkage on plate, you must use 4/6mm spacers on servo saver, depends by saver
Old 02-16-2012, 01:23 PM   #2864
Default THX
THANKS, IT WAS SUPER EASY TO MAKE. IT ONLY TOOK ABOUT 30 MINUTES. IF I CAN GET THE TIME AND SUPPLIES, I THOUGHT ABOUT MAKING A COUPLE DOZEN AND SELLING THEM IN HERE FOR GUYS. NOT SURE YET. BUT THANKS FOR THE PROPS.
Old 02-16-2012, 01:25 PM   #2865
Martin Crisp's Avatar
Sounds interesting...look forward to hearing your results. Pictures would be good. I have been running the v2 plate with 2mm spacers with good mid corner steering, but also does experience the nervousness on initial turn-in that you talked about. I am going to experiment small increments between 1.0mm and 2.0mm this weekend.
I have also been using the medium plastics for arms, chubs and uprights for durability, but I am going to try the hard arms this weekend to see if that helps increase the preciseness of the steering. I think under extreme acceleration and steering in mod on high grip tracks the medium plastic although very durable is flexing too much and reducing the preciseness of the line I can take.
I decided to keep the medium plastics for the uprights and chubs because last time I use them I felt they were not resilient enough for our very hard boards at my local track. Also I find the axle bearings seem to have less slop when using the medium uprights than the hard uprights in the rear.
Myself, Andrew Hardman (a very fast 13 year old xray driver here in Canada.) are going to be running mod this weekend as we don't get to run mod very often and want to step up our game. Even Andrew Hardman's mechanic Corey Whiteman who has not raced in a few years, will be laying it down in mod this weekend. When Corey use to race regularly, he and I had some great battles, as I do now with Andrew
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
