Like Tree13Likes
Old 02-10-2012, 09:13 AM   #2791
Trader Rating: 14 (100%+)
Originally Posted by MCSEDanny View Post
Speaking of.... Did anyone else soak there bearing to remove the grease before running there S411?
Usually I do and then once all the grease is gone I soak them in a lubricant over night. But the Serpent bearings felt great didn't really see a need for it.
98tahoeboy is offline   Reply With Quote
Old 02-10-2012, 09:21 AM   #2792
orcadigital's Avatar
Trader Rating: 61 (100%+)
My bearings felt smooth as well, but there is definitely some binding in the drive line (it is smooth, but not as free as I would like). I also noted the steering is not smooth after putting the ball cups on the top of the c-hubs.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 02-10-2012, 12:51 PM   #2793
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Akhor View Post
What springs are and shock oil are you running?
I'm running AE 40wt all around with Serpent's yellow front and white rear springs, for our bumpy little track. For WCICS events I'd probably start with 45/40 - orange/yellow.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 02-10-2012, 06:59 PM   #2794
Benzaah's Avatar
Trader Rating: 21 (96%+)
I had some binding in my drive line to begin with. After coming from Xray and Schumacher i thought the Serpent bearings were pretty average. I soaked my bearings in shellite overnight and then used hudy bearing oil. They are ok now but i will be swapping them out for some Schumacher ceramics when funds allow. I still had a minor bind in my drive train but i felt that was due to a poor spur or pinion gear as when trying to set my gear mesh i would always find one high spot in the spur. When I changed to an Xray spur the drive train was freeer so I am now using Xray pinions and spurs with near Zero bind. I feel the last bit of bind is coming from a slighty out of round gear diff pulley. Hopefully this is going to be addressed with the upcoming team kit and a new gear diff housing.
For the steering and ball cups try using Losi foam things to get rid of some slop and smooth out the steering action. I think these are great for any touring car.
http://www.amainhobbies.com/product_...-Linkage-Rings
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 02-10-2012, 11:29 PM   #2795
rdlkgliders's Avatar
When referring to wheelbase, in specific rear wheelbase I read 4mm and 5mm as common spacing. How is that being determined? I have 4mm in front of wishbone (a 2mm and 2, 1mm spacers) and I have a single 2mm spacer behind (toward rear).
sorry If I made this confusing.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 02-10-2012, 11:44 PM   #2796
Johnny Wishbone's Avatar
You have it right. 4 at the front of the rear arm and 2 at the back.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-10-2012, 11:47 PM   #2797
Default V2 steering rack
This is what it looks like when you flip the arms.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-10-2012, 11:51 PM   #2798
Default Bumper mod
This is what I made to fix the bumper flex that can break the front of your chassis.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-11-2012, 01:59 AM   #2799
stacky150's Avatar
Trader Rating: 13 (94%+)
get some 0.2mm shims and put them in between the shock tower mount and the bulkhead both front and rear. problem solved and very free
stacky150 is offline   Reply With Quote
Old 02-11-2012, 08:10 AM   #2800
Default V2 Steering Rack
Myself and James Reilly tested this change thoroughly yesterday night during our race day to find this change to help a ton with consistency and smoothness of steering travel from left to right. We found we were not only able to pick up a little time per lap by the car being easier to drive, we were also able to hold our line with no problem. At the beginning of the race day with arms standard we noticed we were close to pace but lap times showed we weren't consistent. Showing 10.15 for top5 10.25 for top 10 and 10.38 for top 20 which usually neither have our averages spread that far apart. Once we made the change of flipping the arms we saw averages like 10.12 for top 5 10.19 for top 10 and 10.24 for top 20. We also have to contribute the faster times with us learning the new layout a little better and finding a better setup but no doubt in our minds that when you flip the arms it definitely helps when you want to smooth out steering and help with consistency. Honestly made the car a little easier to drive.
-Alston Kelso
Old 02-11-2012, 08:26 AM   #2801
BAD007SUZUKI's Avatar
Trader Rating: 96 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default ?
I ASSUME YOU ARE REFERING TO THE STEERING ARMS? IN THE CENTER WITH THE ACKERMAN PLATE?
I LIKE THE BUMPER MOD. I DESTROYED A 2MM CHASSIS BECAUSE OF BUMPER FLEX. I KEPT THE CHASSIS AND WILL CUT IT UP TO DO THIS. GOOD IDEA ON THAT DESIGN
BAD007SUZUKI is offline   Reply With Quote
Old 02-11-2012, 09:18 AM   #2802
Thanks J. W
Team Waldorf Racing
Old 02-11-2012, 09:22 AM   #2803
Correct
Old 02-11-2012, 09:33 AM   #2804
Under the aluminum mount and bulkhead raising the shock tower? or in between the CF shock tower and bulkhead? I assume the firsrt it just seems that would create some up down movement in the diff.
Team Waldorf Racing
Old 02-11-2012, 10:09 AM   #2805
You flip the arm ???
Why ?
Manu_05' is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
