Old 02-08-2012, 01:38 AM   #2761
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by NUCRPTRACER View Post
Okay I am also having issues with the diffs seeping and slinging oil?
I have tried some silicone lube on all diff seals but doesn't seem to help..
Has anyone tried or done any testing with adding 2 additional small gears and another shaft in the diff? Just wandered as I picked one up used and that's what I found inside...
Any and all help is appreciated thanks to Martin and Johnny for all there help so far!!!!
It took me about 3 or 4 goes to rebuild the diff to stop it leaking. Have to be careful with those screws and make sure the large oring isnt twisted
silvalis is offline   Reply With Quote
Old 02-08-2012, 07:39 AM   #2762
James Reilly did you run the gear diff at the slam race at the rug for more turn in or do you just prefer it over the spool? What shock oil were u running?
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 02-08-2012, 07:52 AM   #2763
DeLaSoul's Avatar
Originally Posted by Martin Crisp View Post
Marc and I looked shared setup info, but we both did our own thing. The main difference was in the springs and the diff oil. He ran yokomo springs and I ran serpent springs, but the springs felt very close given that I ran my rear shocks on the inner hole of the arm. I ended up using grey springs all around, while marc I think had yokomo pink and blue. His springs felt more linear while mine felt a little more progressive.
In terms of the diff oil, I ran 1000w and I think he ended up somewhere around 2000w.
oh yeah...he also ran 2.5 rear toe where I ran 3.0. I tried the 2.5, but with my diff oil being much lighter than his it gave the car too much off power steering.
I ran 5mm inboard spacers on the upper links. On the rear upper links I rn 4mm inboard and 3mm outboard. I think Marc ran about the same if not exactly that.
We both ran 0.5 mm spacers under the hinge pin blocks.
we both ran a spool.
Marc's car was traction rolling initially as he had the shocks layed down more than mine, but after he changed to using the 4 position in the rear and 3 in the front like mine, he stopped traction rolling.
With the exception of Alexander and Nayoto, we all ran 10.3 s laps as our fast laps in mod. Alexander and Nayato fast laps were 10.1. So it was good tight competition for positions 3 through 10 in the a main, determined by consistency instead of outright pace.
During the main, our opening lap was very clean until the last corner of the first lap where about 5 cars got together in a chain reaction. Unfortunately I got flipped by a car behind me and went to last place. I ended up 7th and marc ended up 4th.
Hi Martin,
was good to meet you and Marc at the 'birds. Thanks for all your help on the setup. Between yourself, Marc and Cory I had a great car to drive, now it's down to me to get better results next time
I ended up on a similar setup to, only real changes were 1300 cst gear oil and Xray 2.8/2.6 springs. To go from 10th B main and end up 3rd in Expert was a great result for me. Must admit though, I struggled with those Jaco tyres - maybe years of running Sorex has made me soft!
Thanks again,
Dave
Slikks Graphix - Model Cars Reading - Akula Racing - Serpent UK
DeLaSoul is offline   Reply With Quote
Old 02-08-2012, 09:02 AM   #2764
Martin Crisp's Avatar
Originally Posted by DeLaSoul View Post
Hi Martin,
Thanks again,
Dave
Hey Dave...I hope your trip back to the UK was smooth. Great to meet you. Yeah...we run those tires a lot in Canada, so I was familiar with them. They are typically about 2 to 3 tenths slower than sorex 28 on any given track, but the jaco blues stay very consistent. I like these tires for big races where the track has lots of grip, as they don't tend to make the car traction roll like a sorex 28 would on a high grip track.
Cheers
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 02-08-2012, 09:15 AM   #2765
Guys these Diffs are driving me crazy!! I can't stop the leak and I'm sure it's something I'm doing..
TEAM Black Ops.
Old 02-08-2012, 11:17 AM   #2766
mattwoodcraft's Avatar
im sure you may have checked it already but the small black o-ring make sure you do not roll it on as this will cause it to have flat spot and when your tightening it up push it down square and tighten all screws same tension.every time i pull mine apart i use a new o-ring. I have only had one issue with leaking diffs and it was when i re-used a o-ring
mattwoodcraft is offline   Reply With Quote
Old 02-08-2012, 11:40 AM   #2767
Johnny Wishbone's Avatar
When I build the diffs, I use Associated green slime, on the o-ring gasket, just a small coating all the way around. I also slime the o-rings for the out drives.
You didn't do anything like trimming the the o-rings to eliminate drag or anything like that?
My diffs are dry and I don't even use the big shim washers.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-08-2012, 11:48 AM   #2768
BAD007SUZUKI's Avatar
Trader Rating: 96 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default AND
I ASSUME THE LARGE ORING ISNT DIRTY OR HAS A PIECE OF DIRT KEEPING IT FROM SEALING? MAYBE THE DIFF CASE HAS A BUR ON IT? I BUILT MINE SEVERAL TIMES AND USED THE ORIGINAL SEALS AND HAVE NO LEAKS.
WHERE IS IT LEAKING FROM? THE OUTDRIVE OR AROUND THE SEAM?
IF YOU OVER FILL IT, AND BOLT IT TOGETHER IT MAY BUILD PRESSURE AND WHAT YOUR SEEING IS TOO MUCH OIL LEAKING OUT. I HAVE DONE THAT BY ACCIDENT ON MY 8TH SCALE.
REBUILD IT, CHECK THE SEALS AND CASE, AND ONLY FILL IT TO JUST UNDER THE TOP OF THE SMALL SATELLITE GEARS. I RUN MY DIFF WITH VERY LITTLE OIL. (ABOUT 12 DROPS, JUST ENOUGH TO KEEP IT LUBED) ITS IS SMOOTHER AND FREE-ER THAN A BALL DIFF.
BAD007SUZUKI is offline   Reply With Quote
Old 02-08-2012, 12:17 PM   #2769
I think it's around the big seal... I've checked for twists and debris...I filled it to just almost covering the shaft of the small gears I take it that's to much??
TEAM Black Ops.
Old 02-08-2012, 12:33 PM   #2770
Default NO
THAT LEVEL OF OIL SHOULDNT CAUSE ANY ISSUES. THAT AMOUNT IS FINE. DO YOU BY CHANCE HAVE AN EXTRA DIFF HOUSING TO TRY? I THINK AMAIN HAS THEM FOR LESS THAN 10$. THE ONLY OTHER THING I'D TRY IS A VERY SMALL AMOUNT OF GASKET SEALANT AROUND THE SEAM. I'D PUT IT OVER THE ORING.
I ALSO ASSUME THAT YOU ARE USING THE ORING THAT WAS SUPPLIED WITH THE KIT? ITS REALLY THIN DIAMETER AND ABOUT AN INCH AND A HALF AROUND. IF NOT, THEN THATS THE ISSUE.
ITS SHOWN IN THIS PICTURE: http://www.amainhobbies.com/product_...r-Differential
Old 02-08-2012, 12:36 PM   #2771
If you want more stability I would get rid of the kick-up and the anti-squat. Also I would use a moderately thick oil in the rear diff...something between 1000 and 1500.
Hi Martin,
ThX for your help !
How many gear do you have in your diff ?
And do you think that the 2.5mm chassis, will be more stable on carpet than the 2.25 ?
Manu_05' is offline   Reply With Quote
Old 02-08-2012, 03:01 PM   #2772
maybe its time to try a new diff housing if you can not stop the leak maybe the moulding its self maybe the problem
Old 02-08-2012, 05:25 PM   #2773
Trader Rating: 16 (100%+)
Evening gentlemen,
I have my 411 on the way and wanted to know if someone could point me to the best thread for setup for asphault. Meaning best tires to run diff and shock setup etc..also what's the best motor and esc to run. Thanks in advance
Serpent 811BE w/ Tekin RX8 and 1900kv
Serpent Cobra E w/Tekin RX8 and 2050kv
Serpent 411LE w/Tekin RX8 with 5700kv Castle Creations (for now)
Motonica P81 RS Electron w/Tekin RX8 and 1900kv
Motonica P81 RS.2 Electron w/Tekin RX8 and 2050kv
DanielD is offline   Reply With Quote
Old 02-08-2012, 07:07 PM   #2774
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Try this:
http://www.petitrc.com/reglages/serp...rpentS411.html
The top setup by w.y hundle is pretty close to what I tried today. The guys on here helped a lot with tips and setup.
I just ran my first practice and was pretty happy . I did tear up an 87 tooth spur, the clearance on the bottom side is very minimal. I don't know if caught a rock in it or what.
I switched to a 84t xray and raised my ride height a tad.
Maybe a piece of tape over the chassis to protect the spur ?
I can already tell that the car seems to finish the corner better than my xray, off power steering was a little less than I expected but setup tweeks should fix that. I setup my end points to max out steering over 100% pretty much to max the car can handle. It felt good, more testing will tell I really like a lot of steering.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 02-09-2012, 03:52 AM   #2775
Thanks for all the tips guys.. My new diffs seem fine.. Ordered a few new housings and gaskets..again thanks for all the help
TEAM Black Ops.
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
