Old 06-11-2011, 03:56 PM   #256
Trader Rating: 17 (100%+)
not sure if the s400 gear diff was the same but there appear to be only 2 planetary gears in the diff. never seen it before and wonder how it might perform compared to the more typical arrangement with 4 gears? less friction and smoother feeling or maybe the opposite?
m@_c is offline   Reply With Quote
Old 06-11-2011, 04:41 PM   #257
Trader Rating: 55 (100%+)
Originally Posted by RC MARKET View Post
Parts arrived !
How much for gear diff unit? I wanna try one in front.
Jamison R is offline   Reply With Quote
Old 06-12-2011, 02:18 AM   #258
Originally Posted by Isaac View Post
Sorry for the here we go again but it's a concern so I ask. I'm in the US as well and I remember my fellow racers with the S400 so I'm asking.
Search for this topic... it has been asked and answered many times over the last couple of months.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 06-12-2011, 02:20 AM   #259
JayBee's Avatar
Trader Rating: 31 (100%+)
Ditto
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-12-2011, 03:30 AM   #260
Pattojnr's Avatar
Trader Rating: 19 (100%+)
had my first run with the car today. kit setup is not ideal. but firstly, we run on a open fast track, lowish grip. i went out for maybe 3 mins first up. to get a feel for the car, out of the box, it is way nervous, too much steering, and not alot of rear grip. due to the sweeper at the end of the straight, it is banked, and the cars scrape at mod speed. so i raised ride hieght to 6.5 rear and 6 front. 2mm over ride hight droop at rear and 3mm over R/H at front. then went to the White rear spring. this change was Massive. everything started to work. tried alot of small things, and the reacts very well to the smallest change. removed shims for roll centers, removed rear bar, changed toe at front. all made differences one at a time. in the end i went back to kit settings apart from the rear springs, stood up the rear shocks to 3rd highest hole and one less at the front. lengthened rear wheelbase by 2mm, and presto. car is good. i had old tyres on, track was dusty, and i had base settings in teh Speedy (sp, 205Mod) and was a little over 1.5 tenths of my lap record with in 3 packs. as i bolt on fresher tyres, ramp up the speedy settings again (straight line speed) then we aproach the 15 sec barrier. i fialed however to crash test the car, but one VERY BIG issue is the Blades for the rear drive shafts. untill i can find something better, or serpent makes harder ones, if running MOD, be prepared to change them every 2 runs. they are cheap, and i believe 16 come in a spares packet. but this is one thing that does need to be addressed.
Overall, first run with the car, no Major issues, car is fast, car is easy to work on, reacts very well to the smallest change. Big Thumbs up from me for the 411.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-12-2011, 03:35 AM   #261
nexxus's Avatar
Trader Rating: 300 (100%+)
Looking at either one of these or converting my TA05 with an Exotek Chassis, at the moment only running VTA but may well go back into Stock with that class slowly fading. Are these a fairly robust car? Whats the parts support like? I've tried all brands, Yokomo (yuck!), X Ray (Could never get it set up right), Corally (Bank loan for parts), have had most luck with Tamiyas (Esp 415) and Associated (Had a TC5 with an Exotek and it handled like a dream, very sorry I sold it!) and looking at my options, only must is NO BALL DIFFS (over them already!)
Appreciate any input.
nexxus is offline   Reply With Quote
Old 06-12-2011, 03:36 AM   #262
Pattojnr's Avatar
Default battery retainer
here is a pic of the change i made, only one hole needs to be drilled and just makes it so much easier.
Serpent - Walter RC
Old 06-12-2011, 06:36 AM   #263
niznai's Avatar
You need more patience and perhaps some help. An Xray is a weapon, but like everything else you need to tune it right. Built out of the box an Xray (and practically most cars these days) should perform very well at stock level on any surface provided you have the right tires. If it doesn't you're doing something wrong.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 06-12-2011, 06:51 AM   #264
nexxus's Avatar
The X Ray was going back about 5-6 yrs (FK05 I think it was)
Old 06-12-2011, 12:16 PM   #265
RC MARKET's Avatar
Some customer made battery holder
RC MARKET is offline   Reply With Quote
Old 06-13-2011, 08:05 AM   #266
RC MARKET's Avatar
Thumbs up
ARENA S411 Bearing Set
Old 06-13-2011, 09:54 AM   #267
TJames987's Avatar
Trader Rating: 10 (92%+)
Default I want one!
This car looks awesome. I'm ready to sell off my T3 and 416 to get ahold of this kit. Love the gun-metal aluminum and gear diff.
Can't wait to read more user reviews as people get the car
TJames987 is offline   Reply With Quote
Old 06-13-2011, 01:27 PM   #268
RC MARKET's Avatar
this weekend will have race result !
Old 06-13-2011, 02:08 PM   #269
Hi, I've just purchased an S411 and some spares from your online store, hope to get my kit here in Italy as soon as possible
sirio76 is offline   Reply With Quote
Old 06-13-2011, 02:38 PM   #270
Akhor's Avatar
Will the X-ray Blades fit?
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
