Old 01-26-2012, 08:23 AM   #2611
Originally Posted by BAD007SUZUKI View Post
I TRIED THE MOD FOR THE MOTOR SCREW ON THE TOP DECK.I USED A BUTTON HEAD THAT WAS LONG AND WOULD ALLOW BOTTOMING OUT IN THE HOLE. I GROUND THE SCREW SO THAT IT HAD JUST ENOUGH HEIGHT STICKING OUT OF THE TOP DECK TO ALLOW A RUBBER ORING FROM A SHOCK. I ONLY USED ONE O-RING IN BETWEEN THE HEAD OF THE SCREW AND THE TOP DECK. WOW.
I NOTICED A TON OF EXTRA TRACTION. JUST WITH THAT SIMPLE MOD. VERY HAPPY.
nice mod, but photos will be better than words for our understand....
mos-leung is offline   Reply With Quote
Old 01-26-2012, 08:33 AM   #2612
BAD007SUZUKI's Avatar
Trader Rating: 95 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default ok
BAD007SUZUKI is offline   Reply With Quote
Old 01-26-2012, 10:07 AM   #2613
JamesReilly's Avatar
Trader Rating: 56 (100%+)
Nice, I'm glad that you felt the improvement in rear grip that I felt as well.
I like the addtion on the oring just a little more dampned.
James
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint (reillypaint@gmail.com)
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 01-26-2012, 10:14 AM   #2614
Default COOL
THANKS JAMES.
Old 01-26-2012, 10:21 AM   #2615
I will have to try this mod this weekend and it is so very simple. I recently purchased an S411 and put a Thunderpower Motor in it with the blue rotor and this has got a ton of torque in it. Enough that it would break the tail end loose coming out of the corners. I am hoping that this will help with the grip problem I am experiencing. I had tried laying the rear shocks down a bit more nut that didn't solve it. I will also try lowering the inside camber link on the rears to make them equal to the outside. Oh, yeah this has a gear diff in front also. Love the car!!! It is awesome!! Parts are alot less than the Xrays I used to drive. Thank you Serpent!!!!
Aquaracer is offline   Reply With Quote
Old 01-26-2012, 10:30 AM   #2616
Default COOL
MAKE SURE YOU USE A SMALL AMOUNT OF LOCKTIGHT IF YOU USE THE BUTTON HEAD SCREW LIKE I DID. BECAUSE YOU CANT REALLY TORQUE IT DOWN, YOU DONT WANT IT BACKING OUT WHILE RUNNING.
Old 01-26-2012, 12:33 PM   #2617
BAD007SUZUKI, Thank You for the advice about the loctite on the screw. This may have slipped my mind. I'll let you know how it helped out after some Friday Night Racing at RCAR here in INDY. Is it Friday yet?? I wanna go racing!!!
Old 01-26-2012, 02:15 PM   #2618
Martin Crisp's Avatar
Originally Posted by NUCRPTRACER View Post
Martin thanks for the quick response....Maybe you could do me a favor and give Ken Miller a little push into the wall at the birds...I assume you'll be there..Or maybe Riley could do it...
Thanks for your interest in my app.....do you want me to push ken or his car into the wall ?
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 01-26-2012, 02:31 PM   #2619
mattwoodcraft's Avatar
Good idea with the mod I'm keen to give this a shot for sure, I have been using the 2mm chassis are you using the 2.5 or 2.25
mattwoodcraft is offline   Reply With Quote
Old 01-26-2012, 02:40 PM   #2620
Default 2.5
2.5MM CHASSIS. I DESTROYED MY 2MM. DINKED A WALL AND BROKE RIGHT INFRONT OF THE FRONT TOE BLOCK. ITS A WEAK SPOT ON THE CHASSIS BECAUSE OF HOW THE BUMPER IS MOUNTED.
WITH MY SETUP AND THIS MOD, MY CAR IS ON RAILS ON A LOW TRACION CARPET TRACK. THANKS TO JAMES REILLY FOR THE IDEA.
Old 01-26-2012, 02:46 PM   #2621
Johnny Wishbone's Avatar
Ran the topdeck screw mod yesterday, although I just use a 10mm setscrew, no head, and had no gear issues. I use the setscrew and a nylock nut so its locked and I can run it as tight or loose as needed.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-26-2012, 03:09 PM   #2622
cwoods34's Avatar
I have two things to say. You also have my thanks for the great app, and push Ken WITH his car into the wall..... 2 for 1.........
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 01-26-2012, 03:12 PM   #2623
miller tyme's Avatar
Sure seems like the Indy guys are scared of something!!!!
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Pro Level RC - Sanwa - TQ Wire - ProOne Racing Tires -
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-26-2012, 03:15 PM   #2624
Default ?
GETTING A SNAKE BITE?
Old 01-26-2012, 03:38 PM   #2625
Trader Rating: 30 (97%+)
i,ll try the screw mod as well looking for more rear grip so seems this works
zaraz is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
