Old 01-25-2012, 11:50 AM   #2596
Matt Howard's Avatar
Originally Posted by rdlkgliders View Post
Is the le lacking anything that the standard edition offers? Do both kits come with a front spool?
The LE includes the tool set, extra gear diff, C/F lipo holders, and number of kit engraved on bottom. Besides these items and orange anodizing on the LE kit they're the same car. Yes, both include a front spool.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-25-2012, 02:23 PM   #2597
Please verify that the standard S411 kit does not come with lipo holders.
FastHound is offline   Reply With Quote
Old 01-25-2012, 02:25 PM   #2598
That Kit is freakin sick man.....
TEAM Black Ops.
NUCRPTRACER is offline   Reply With Quote
Old 01-25-2012, 02:28 PM   #2599
Martin thanks for the quick response....Maybe you could do me a favor and give Ken Miller a little push into the wall at the birds...I assume you'll be there..Or maybe Riley could do it...
TEAM Black Ops.
Old 01-25-2012, 03:17 PM   #2600
mattwoodcraft's Avatar
The standard kit has no lipo holders.
mattwoodcraft is offline   Reply With Quote
Old 01-25-2012, 03:26 PM   #2601
Right now I have an LE and the standard edition. I think I like the looks of the standard edition better, so I might switch to running two standard editions. I do however think the LE is fantastic deal, with having the tools and the extra gear diff.
I like the look of the standard kit also, It looks stealth and neat with its gun metallic coloring
Old 01-25-2012, 04:38 PM   #2602
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
what cassis protector are you guys running outdoors? (palstic protective film)
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 01-25-2012, 04:50 PM   #2603
I love the deep Orange anodizing of the LE kit, except when people accuse me of running an Xray
RCTech #361
Old 01-26-2012, 04:48 AM   #2604
I am reading through this thread to follow the progression and confirm my decission to pick the serpent as my next TC. I have a couple questions first and more importantly do the cvd's and or the djc's use blades to protect the outdrives? Less important how quiet is the 411 in compaarison to other TC's
Oh how about N.A parts availability
Team Waldorf Racing
Old 01-26-2012, 05:32 AM   #2605
The car uses blades in the rear, regular pin in the front. Car seems just as quiet as any other belt car out there. Amain and Stormers are two places that I know of in the states that carry parts, there may be others but I've personally ordered from those two.
RCTech #361
Old 01-26-2012, 06:02 AM   #2606
If you opt to use a front gear diff you can them use the blades, you find the car very durable also
Old 01-26-2012, 06:23 AM   #2607
Thanks guys,
You would think that the spool would use the blades.
Are you finding excessive wear in the outdrives of the spool?
Team Waldorf Racing
Old 01-26-2012, 07:41 AM   #2608
Thanks guys,
None or very low wear.
The outdrives are made of steel. The outdrives are open to get the weight as low as possible. I've put a shrinking foil above the outdrives. As they now are closed, I can fill in some black grease in the slots. It will not fly out. I do every second or third raceday a maintenance of the outdrives. I still use the first foil and outdrives.
We race modified on carpets and after 5 month the outdrives are as good as new ones.
Don't use the delrin outdrives (option parts) for carpet racing. They aren't designed for it / not durable enough. You can use them on tarmac tracks outside.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 01-26-2012, 07:44 AM   #2609
Thanks guys,
I believe S411 has strongest outdrive in the world!
JAEHOON AHN
From Korea(Muchmore racing, Sweep racing)
KYOSHO MP9 TKI4 + OS B2101
xtaiji is offline   Reply With Quote
Old 01-26-2012, 07:45 AM   #2610
BAD007SUZUKI's Avatar
Trader Rating: 96 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default MOTOR SCREW MOD
I TRIED THE MOD FOR THE MOTOR SCREW ON THE TOP DECK.I USED A BUTTON HEAD THAT WAS LONG AND WOULD ALLOW BOTTOMING OUT IN THE HOLE. I GROUND THE SCREW SO THAT IT HAD JUST ENOUGH HEIGHT STICKING OUT OF THE TOP DECK TO ALLOW A RUBBER ORING FROM A SHOCK. I ONLY USED ONE O-RING IN BETWEEN THE HEAD OF THE SCREW AND THE TOP DECK. WOW.
I NOTICED A TON OF EXTRA TRACTION. JUST WITH THAT SIMPLE MOD. VERY HAPPY.
BAD007SUZUKI is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
