Old 01-14-2012, 01:43 AM   #2461
Toughbeard's Avatar
Originally Posted by mattwoodcraft View Post
What is V2 steering has it changed from the original kit
the stud screw in position is ratated 90 degrees so its looking forward now. It enables you to adjust your ackerman. Still uses the same bearings that comes with the old steering rack.
Looked like a nifty part... hope to receive ours soon..
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 01-14-2012, 08:12 AM   #2462
just put the steeringrack V2 on the car
nb576uk2004 is offline   Reply With Quote
Old 01-14-2012, 08:23 AM   #2463
dameetz's Avatar
Is this new part available already?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-14-2012, 08:33 AM   #2464
available in Hong Kong already
Old 01-14-2012, 09:07 AM   #2465
mattwoodcraft's Avatar
what's the part number and what shop in honk kong ?
thanks
mattwoodcraft is offline   Reply With Quote
Old 01-14-2012, 01:47 PM   #2466
musti72's Avatar
part number is SER401465
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 01-14-2012, 04:11 PM   #2467
jekyll08's Avatar
hello,
is there an eta on the v2 steering rack for serpent america?
jekyll08 is offline   Reply With Quote
Old 01-14-2012, 04:30 PM   #2468
crabboy's Avatar
Trader Rating: 57 (98%+)
Hi Guys,
For the new rear sway bar that is able to mount the the front of the rear arm, could some please post a pic of it mounted so i can see what i need to do this, or could some one please tell me the parts that i will need, thanks.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 01-14-2012, 04:46 PM   #2469
mingnon's Avatar
thanks
Matt if you can find this part can you drop me a msg (im in Oz)
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 01-14-2012, 06:18 PM   #2470
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
Originally Posted by crabboy View Post
Hi Guys,
Rhys
Hey Rhys.
I just used a Tamiya 415 1.2mm sway bar on the rear and used tamiya ball cups to mount it as my serpent ones wernt moving as freely as I like.
mild seven is offline   Reply With Quote
Old 01-15-2012, 03:43 AM   #2471
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Hi Guys,
Rhys
just use a shock ball and end and a set screw. its easier to adjust the swaybar as it is std, than with the set screw. unless you use a small turnbuckle .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-15-2012, 03:57 AM   #2472
Hay Patto thanks for the assistance with sway bars today on my car the car hooked up wicked and also the advise on the rear camber link length when you get a chance could you tell me what you did again with the shocks when you were winding the collar up and down
Old 01-15-2012, 04:26 AM   #2473
Pattojnr's Avatar
no dramas, next time ill go through it with you. just got a bit rushed today with all the testing with tyres, and software. lol, crazy software.
Serpent - Walter RC
Old 01-15-2012, 04:41 AM   #2474
Thanks I will be putting on the medium arms for next time
I was way hing what you were doing but dam you were doing fast
Thanks again
Old 01-15-2012, 07:48 AM   #2475
Looking for a servo saver for a ko prop 2413 to fit the 411 any ideas .
http://www.facebook.com/VancouverRRR
http://joshuasouthoaks.blogspot.com for blog, pictures and video of race events
fasteddie d is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
