Old 01-06-2012, 09:37 PM   #2401
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Dangerous_toys View Post
I am in Huron, South Dakota
so that is in US ? Look at Serpent America, kamakaze, or A mains.
other guys from the US may be able to let you know too.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-07-2012, 08:21 AM   #2402
damage's Avatar
Default Recommend a carpet setup?
Looking for a recommendation on a carpet setup for a tight somewhat technical layout. This is our layout.
http://youtu.be/2gpQC61hEbo
Thanks.
http://tinyurl.com/Wiocr
Tamiya Hornet, Airtronics XL2P, Novak 4, 1200 SC Stage III batteries,
Navcom 10 peak, 12 volt lead acid power source
damage is offline   Reply With Quote
Old 01-07-2012, 09:08 AM   #2403
Thanks.
I would probably start with the kit setup on that layout
008-Racer is offline   Reply With Quote
Old 01-07-2012, 09:52 AM   #2404
Thanks.
Try This
http://www.petitrc.com/reglages/serp...112/index.html
MarcusEngdahl is offline   Reply With Quote
Old 01-07-2012, 10:25 AM   #2405
Matt Howard's Avatar
Thanks.
+1, the kit setup is a great place to start, maybe go with the 1.2mm swaybar on the rear, but the kit setup is money
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-07-2012, 11:04 AM   #2406
dawgmeat's Avatar
Anybody running their gear diff without the large washer? I really don't like the feel of the gear diff with them?
dawgmeat is offline   Reply With Quote
Old 01-07-2012, 01:25 PM   #2407
Rouge711's Avatar
Guys, it seems we have a new issue.
In last few weeks we had the opportunity to built up 2 or more kits for 13.5T no timing. We followed basic setup running in a hight grip carpet track. We run others 2 cars one in 13.5T no timing and one in mod, they follow setups similar to basic and they are fast and easy to drive.
The common issue in that cars is that they feel excessively agressive when they hit the track for first batteries. They are very difficult to drive and setups are likely the same of the other cars but they're very nasty.
Maybe rear diff needs to be break-in... Did you have the same feelings?
Thank you
Team Associated
Team Trinity
Thunder Tiger Europe
Rouge711 is offline   Reply With Quote
Old 01-07-2012, 01:26 PM   #2408
Rouge711's Avatar
Yep! We tried it! No particular problems, but or will have short life...
Team Associated
Team Trinity
Old 01-07-2012, 09:03 PM   #2409
pcar951's Avatar
It's true, not that the car is hard to drive it's just very direct feeling. To settle my S411's down on carpet, I installed the 2.0 F/R suspension mount eliminating the front arm sweep. I know that others have done the same but, for me it was a big improvement.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-09-2012, 01:18 PM   #2410
I found an orange Yeah Racing fan while browsing rcmarket, looks pretty sweet on the S411 LE if you ask me
RCTech #361
Old 01-09-2012, 01:59 PM   #2411
Johnny Wishbone's Avatar
So are you still testing or did you run it at one of the club races? If so which class, stock or ss?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-09-2012, 02:41 PM   #2412
jekyll08's Avatar
Default servo saver
hello,
just wondering what people are doing for a servo saver and how can you make it fit without hitting the bottom of the saver on the chassis?
jekyll08 is offline   Reply With Quote
Old 01-09-2012, 05:03 PM   #2413
mattwoodcraft's Avatar
You can get servo savers that are quiet low and will protrude past the servo , I haven't used a servo saver on onroad for a long time and have not had a issue with servos stripping
mattwoodcraft is offline   Reply With Quote
Old 01-09-2012, 06:57 PM   #2414
dameetz's Avatar
I m using Xray servo saver, but you have to file some material on the servo plate to clear the servo saver. So far its been working very well.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-09-2012, 10:12 PM   #2415
Tekinpro's Avatar
Hi.i'm just bought serpent s411 limited edition.now the problem is my car was going right side when i push full throtel.can somebody help me.
tr417+orca mk2.1+rx2+futaba 4pk+huge 70c..main depan rumah jer
Tekinpro is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
