Old 01-01-2012, 04:08 PM   #2356
Martin Crisp's Avatar
Default rebound
MarcS2K - I run as little rebound as possible...0 to 3mm
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 01-01-2012, 04:22 PM   #2357
Matt Howard's Avatar
anyone have the DCJ's in stock? or know of another brand besides the serpents that will work?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-02-2012, 01:43 AM   #2358
RC MARKET's Avatar
instock !
RC MARKET is offline   Reply With Quote
Old 01-02-2012, 03:44 AM   #2359
mattwoodcraft's Avatar
i got some BD5 version 2 from spec R to put in when i get home i like the design a whole better with the clip securing the pins rather than heat shrink, they are cheaper as well. I have been informed they fit which i will see when i get home
mattwoodcraft is offline   Reply With Quote
Old 01-02-2012, 06:11 AM   #2360
please check and let us know
RCTech #361
Old 01-02-2012, 07:06 AM   #2361
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I already purchased your setup app, but what I am saying, is my experience is the opposite. That narrowing the rear track increases the forward bite. I have done some searching on the web, and have found the same math that is in your app, but I have also found some evidence to support my observations. I realize there are so many variables, after the search I am more curious which of the variables have the biggest impact while working with the track width ( I guess ).. Any thoughts ?
Originally Posted by Martin Crisp View Post
Whenever you make the track width on a car wider it will jave more lateral grip. i explain the math behind this in my RC SETUP WORKBENCH app. Yes the car will feel more twitchy especially in chicanes with the narrow rear end as the rear will roll more. as to why it might feel more stable mi cant really say without knkwing the resr of your setup.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-02-2012, 07:58 AM   #2362
Trader Rating: 36 (100%+)
When I was running the T3 2011, I tried the Spec R's and found that the pins bent in a matter of minutes. I ended up switching to the more expensive Xray version and had no problems after that.
Does anyone know if the Xray ECS work with the S411? If so, which size 50mm or 52mm?
EVILGRAFX is offline   Reply With Quote
Old 01-02-2012, 08:04 AM   #2363
XRay ECS will not fit. The ball end on the drive shafts do not fit into Serpent outdrives.
duckman996 is offline   Reply With Quote
Old 01-02-2012, 08:10 AM   #2364
Thanks, that's good to know.
I just saw that Spec R has their DCJ's listed as "Version 2", so maybe they've improved the strength of the pins.
Old 01-02-2012, 12:01 PM   #2365
haywood's Avatar
Trader Rating: 48 (100%+)
Default 411
Martin
After getting in some more time with the car how would you compare it against your Xrays? If you are faster with the 411 what do you attribute that to? Thanks
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-02-2012, 01:27 PM   #2366
Originally Posted by haywood View Post
Martin
I just got this for Xmas, haven't even put it on the track yet. This coming weekend will be first practice/race.
Old 01-02-2012, 04:14 PM   #2367
haywood's Avatar
I was asking Martin Crisp!
Old 01-02-2012, 04:31 PM   #2368
Okay
Old 01-02-2012, 05:23 PM   #2369
Jonathan's Avatar
Stills needs to go on the setup board and paint a body. Cant wait...lol. Question for everyone. What are you guys using for pinion and spur combo for 17.5 class? Coming from 1/8 onroad, I a little lost on this subject so I went with what the guys at the hobby shop recommended after they did some calcs. 108/53.( 64 pitch) Yahhh... it doesnt fit... pinion is way to big and there's not enough room to slide the motor down. lol... The biggest i can do is a 30 tooth. Martin...if you have some info on this subject in your app, I would give it another star to make it 6. lol. So back to the original question...what pinion/spur combo? or better yet, a link to some info that sheds some light on this subject. Thanks y'all. Jon
Speedworld Raceway and RC Shop. Mugen USA.
Jonathan is offline   Reply With Quote
Old 01-02-2012, 05:33 PM   #2370
Johnny Wishbone's Avatar
Blinky or boosted. Blinky you want to run anywhere from 3.8 to 4.2 fdr.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
