Old 12-29-2011, 12:22 PM   #2326
Hi everyone,
I've just bought a second hand s411. It's my first TE. My s411 came with a 48p spur, as I'm going to run 10.5T blinky as I'm going to change to 64pwhat spurs can I use? I have some kawadas, but they don't work. Will the Xray ones work? and the K factory ones?
Regards
jimjav is offline   Reply With Quote
Old 12-29-2011, 12:26 PM   #2327
Johnny Wishbone's Avatar
Originally Posted by jimjav View Post
Hi everyone,
Regards
The Xrays will work. I think the biggest you can go is the 110, but it will be a tight fit, 96 to 104 work very well. I don't think the kawadas will work and not familiar with the K factory ones, sorry.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-29-2011, 12:29 PM   #2328
I was thinking about moving around 100-104
So many thanks
Old 12-29-2011, 01:33 PM   #2329
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Has anyone tried narrow hexes in the rear ? I know they were in the works, but do we know if they were released yet ? I made my own from some Tamiya hexes.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-29-2011, 05:11 PM   #2330
Originally Posted by JamesReilly View Post
I'm sorry but expecting a delrin part to hold up to the torque reversals that the outdrive goes thru is impossible. Even the Xray delrin ones break and they offer aluminum outdrives to stop the breakages, you however have to replace blades all the time. So there is no perfect answer.
I had Xray and no problem there, but serpent's break too easy compare to Xray's. I hope serpent's have same strength xray's. :-(
JAEHOON AHN
From Korea(Muchmore racing, Sweep racing)
KYOSHO MP9 TKI4 + OS B2101
xtaiji is offline   Reply With Quote
Old 12-29-2011, 05:28 PM   #2331
todb's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to todb
Went out today to try new setup and it was better than it used to until my car looked like it belonged to Cheech and Chong. Totally smoked up all the window with a definitive smell. Not sure what happened but my ESC went up in smoke. Thank goodness it wasn't a lipo fire !
OVA Neo. HW, Motiv.
Orange is faster.
todb is offline   Reply With Quote
Old 12-29-2011, 05:28 PM   #2332
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Johnny Wishbone View Post
Jim I thought I had this issue fixed a couple times now but the rack still seems to move every once in a while. Even after locktite the bearings they seem to work their way loose. I think Serpent should re-do the rack with a shoulder in the lower pocket for the bearing to rest on and then use a flanged bearing on the top, but since that isn't happening, here is what I did.
The spare washers that come with the Xray car for the shock build, the real thin ones that are big diameter, just slightly bigger than the bearing diameter of the steering rack bearing, I use those with a brushed motor shim washer. So its the screw, the big washer, the shim washer, and then thru the bearing. Use some blue locktite on the screw, this will prevent the rack from moving up and the lower arms should keep it from falling down. Its not perfect but it works.
Oh and I did some back to back testing of the 2.25 versus the 2.50 chassis and "Numb" is the perfect description and also the 2.50 seems to plant the car a little better, no appreciable time differences between the two. If anything the 2.5 felt a little more predictable on turn in on high speed corner.
I also took a straight edge to the 2 chassis I have, and although the 2.50 is flat, much to my dismay my 2.25 chassis seems to be wavy making it very difficult to set consistent ride height. Its about 0.04mm out in places.
Thanks for the tip on the steering rack issue Gary, seems like a good fix for now. Does the rack typically only move upward or will it also drop and cause binding?
I'll be putting a straight edge on my 2.25 chassis' tonight!
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 12-29-2011, 08:29 PM   #2333
Welcome too The Club mine 2.25 is also tweaked right out of the box ;/
MarcusEngdahl is offline   Reply With Quote
Old 12-29-2011, 09:42 PM   #2334
Benzaah's Avatar
Trader Rating: 21 (96%+)
My Le kit is tweak free until I put on the sway bars.
http://www.teamxray.com/teamxray/pro...%20%20%2810%29
Are these the washers you mean?
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 12-30-2011, 06:40 AM   #2335
Julius's Avatar
0,04mm???? That's awful! No way you could drive that
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-30-2011, 01:17 PM   #2336
The Serpent delron outdrives put too much pressure on the end tips making it really easy to break. I started to think about how I didn't like those, and how I'd rather have a pin cushion instead, but then I remembered how bad my car ran when the pin cushion broke and how the car would pull to one side. So now I think I'd rather run the stock deal and if its broke its really broke.
From everything I've seen, the rack keeps coming up. The only time its dropped is during a right turn where the servo link is pushing downwards on the rack, the arms seem to keep it from dropping down and causing any bind.
I could get the tweak set, but getting ride height was tough. it was like I had rake build into the car, where the back was higher than the rest of the car. The surface is more like a wave than a twist, with high and low spots thru the length of the chassis.
Yes those are the ones. They usually send extras to assemble the ball ends into the rod and shock ends with the Xray shocks.
Oh thats just one of many contributing factors for my less than stellar performance. LOL
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-30-2011, 03:54 PM   #2337
LOL
Yes , a tweaked chassi
Old 12-30-2011, 07:43 PM   #2338
corallyman's Avatar
Trader Rating: 98 (100%+)
I ended up with LE #198. Time to get started on it. Looks great.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 12-30-2011, 08:58 PM   #2339
I will soon join most of you as a S411 owner. Due to the lack of parts availability at our local track and LHS can anyone enlighten me on what parts are most common to break so I can carry these with me?
FastHound is offline   Reply With Quote
Old 12-31-2011, 12:26 AM   #2340
pcar951's Avatar
Do the hard suspension arms improve the overall consistency of the S411? The car isn't lose but it is inconsistent corner to corner with the kit suspension parts, it seems.
Just wondering if the stiffer arms would help as much as they do on other chassis...
Jim Chapman
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
