Serpent S411
#2266
for those that have the new kits le version, is the c hub now beveled so it will accept the double joint, or do you still have to shave the inside, and is there a cheaper double joint on the market other then the serpent one, as the price on the serpent double joint universal is so high, thanks
#2269
#2274
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
#2275
Can someone confirm if there is a way to get the X-ray ecs to fit as I have 2sets of 52mm ones here I could use. Regards Benzaah
#2276
I read the posts and just assumed that djc was a good upgrade to have, why would the front spool not act like any other front spool, aren,t all front spools basically the same, a solid piece attached to the gear, so how is the s411 different, every front spool car i have had has chatter, maybe martin or others with the car already can chime in, my car will not be here for another 2 weeks
#2277
Super Moderator
#2278
I planned on changing my car as well. But after my 1st run with the car on carpet I decided not to and decided to spend my money on other things for the car.
-DC-
#2279
#2280
I used the long link in the front...sorry about missing that on the setup sheet.
Yes, I did use 300 oil in the rear diff. I started with 1200, then 800 then 300 and found the 300 had the most mid corner rotation and the smoothest corner exit. I think as the diff breaks in more I might end up at 500 or 700.
