Old 12-18-2011, 12:17 PM   #2116
dawgmeat's Avatar
FDR? For tekin rs 17.5 blinky Novak ballistic , thanks in advance*
dawgmeat is offline   Reply With Quote
Old 12-18-2011, 12:23 PM   #2117
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
Depends on track size.. but 3.8-4.3 is where i run mine
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 12-18-2011, 01:11 PM   #2118
Default internal gearing
Does anyone know what the internal gearing is in the 411. I have read around in this thread an on the serpent homepage. But i cant find that information anywhere. Would be nice to calculate the roolout.
In advance thanks. Speikey
speikey is offline   Reply With Quote
Old 12-18-2011, 01:13 PM   #2119
Moderator
J.Whiting's Avatar
2.0 internal gear ratio
Old 12-18-2011, 02:16 PM   #2120
todb's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to todb
Does anyone know the part numbers for the HPI silver and gold springs that seem to work everywhere? thanks
OVA Neo. HW, Motiv.
Orange is faster.
todb is online now   Reply With Quote
Old 12-18-2011, 04:21 PM   #2121
jland's Avatar
Trader Rating: 74 (100%+)
Default parts
Anyone have any idea on when the new option parts or even a good supply of replacement parts will hit the states? Amain and Stormer seem to be the only place online in the states and they don't have the option parts.
jland is offline   Reply With Quote
Old 12-18-2011, 05:00 PM   #2122
LOW ET's Avatar
Trader Rating: 96 (100%+)
http://www.serpentamerica.com/shop/home.php?cat=93
LOW ET is offline   Reply With Quote
Old 12-18-2011, 05:52 PM   #2123
Matt Howard's Avatar
pulled the trigger on an LE kit tonight, can't wait to get building. Will be my first TC since the 2008 carpet nats. What springs come with the kit? Is there a base rubber/carpet setup out there to start with or is the kit setup what most are starting with?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-18-2011, 06:05 PM   #2124
Moderator
J.Whiting's Avatar
orange and yellow..
order the 1.2 rear sway bar...
try my setup for the 17.5 blinky class. car is very good.. in two weeks i will start running mod so i should have a good starting point then.. martin will have a good setup in a few weeks also..
http://serpent.com/product/400005/setups/
jeremy
Old 12-18-2011, 06:48 PM   #2125
dawgmeat's Avatar
Originally Posted by J.Whiting View Post
orange and yellow..
jeremy
What lower chassis are you running? Also I've just ordered a front diff so what changes would you make from your set-upfor a front diff on capet
Old 12-18-2011, 07:07 PM   #2126
Moderator
J.Whiting's Avatar
stock 2.25 chassis that is in the new kits.. why would you want to run a diff in the front? the spool is just so smooth with no chatter.. does not bind the front end up either.. i have never run 2 diffs in any of my onroad cars.. i always have run a spool or a one-way.. martin might have the answer for you.. jeremy
Old 12-19-2011, 05:46 AM   #2127
RC MARKET's Avatar
New upper deck
RC MARKET is offline   Reply With Quote
Old 12-19-2011, 05:31 PM   #2128
Johnny Wishbone's Avatar
I take it you're talking a front gear diff? If your on really tight tracks and you need some more turn in this can be an advantage, when I tried this it really settled the car down and made it more driveable with less front wheel chatter. Although I did go back to a spool because I liked the pull that the spool provided. You're setup shouldn't really change much going from one to the other, its more the diffing that's letting it turn the corners easier.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-19-2011, 05:34 PM   #2129
Lots of setup here as well.
http://www.petitrc.com/reglages/serp...rpentS411.html
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-19-2011, 05:35 PM   #2130
dawgmeat's Avatar
Thanks I'll keep the spool and purchase a the DCJ shafts
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
