Old 12-16-2011, 08:30 PM   #2101
JamesReilly's Avatar
Trader Rating: 54 (100%+)
Default Joining Team Serpent
I've joined with Team Serpent this year, which was a pretty easy choice after 6 batteries the S411 was right on pace with the lap times other guys have been racing on for two weeks, that was my first time on that layout, to say the least I was impressed.
Smoother, easier, more forgiving and fast seems good to me.
I'll see you at the track,
James
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint (reillypaint@gmail.com)
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 12-16-2011, 08:33 PM   #2102
Johnny Wishbone's Avatar
Default More tweak issues
If you have a tweaked chassis besides the basic things like loosening the top and bottom screws and the rotationally re-tightening them, tweak can also occur by having a slightly twisted upper bulkhead clamp. Also sometimes the shock tower takes a hit and can tweak the whole assembly, so again loosen the 4 shock tower screws front and back, while the car is on a flat surface, then re-tighten. If you do this and the tweak comes back it could very well be a upper clamp or even the lowers could be bent.
This will usually happen after a bigger crash, you'll know cause you'll feel it on the drivers stand when it happens.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 12-16-2011, 08:45 PM   #2103
Originally Posted by gpm-parts.com View Post
ya, I CA all the steering rack bearings.... it seems to fit quite loosely.... After the CA everything is nice and smooth.... for the chassis as I had a few different chassis in different thickness for testing... Almost all of them are slightly twisted even before I mount anything on it..... One of the worst one is the one that came with my kit. Before I even CA the edge I place it on my setup board with the rear end flat on the board. The Front is around 4mm twisted...... And the other 2 chassis I got when I purchase the kit were twisted too...... It got so bad I was checking my setup board and make sure it is not twisted....
three chassis tweaked with nothing mounted...I think the problem is your setup board
minilantern is offline   Reply With Quote
Old 12-16-2011, 08:48 PM   #2104
I'd have to agree, probably bust out a straight edge and do some measuring on the chassis and the board before you bake the xmas cookie chassis.
Gary Lanzer
Team VBC HK
Team R1WURKS
Old 12-17-2011, 12:53 AM   #2105
Sorry , but I have to say , look at Serpent production , 3 different drivers in Denmark with same problem , on 3 different setup boards.
HB-forever is offline   Reply With Quote
Old 12-17-2011, 04:50 AM   #2106
StevenOlsen's Avatar
i only know 2 that have had a twisted chassis and they have been given new chassis, as far as im informed.
Steven
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 12-17-2011, 05:58 AM   #2107
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
James
WOW!!!! this team keeps getting better and better. With James and Martin coming over these cars are just going to keep getting better and better.
I had the exact same results as you did when I switched to serpent. my 2nd pack in the car I already hit hotlap on the track and it was my first time back in touring car in almost a year. I'm coming from the xray to the serpent and finding it to be easier to drive. Welcome to the team.
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 12-17-2011, 08:30 AM   #2108
haywood's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Martin Crisp View Post
I wondered if that was what was going on...just like my old tamiya 416. Thanks Steve for this info and your comments above. Cheers mate.
Congrats on your new ride Martin! I spoke with you at the last Novak Race in Wisconsin Scotty had many years ago! You were running Tamiya back then. Pm me if your Xray is for sale!
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-17-2011, 09:03 AM   #2109
locked's Avatar
He sold his xrays already. This is his last weekend with them.
We both had TOPs, then he went to xray, I finally buy an xray and he switches to serpent. I'm starting to think he just doesn't want to run the same car as me
Congratulations Martin. Don't think that I won't still be bugging you for advice
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-17-2011, 12:30 PM   #2110
corallyman's Avatar
Trader Rating: 97 (100%+)
You could always switch to the Serpent, just don't tell Martin
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 12-17-2011, 12:37 PM   #2111
I tried today 2.5mm and 2.25mm chassis plates on medium grip carpet track. 2.5mm felt better on chicane and steering was sharper. 2.25 felt smoother on corners and steering response was slower. Best lap time was 0,1s faster with 2,5mm.
valtsu23 is offline   Reply With Quote
Old 12-17-2011, 01:55 PM   #2112
Default 13.5 gearing
Geting back into touring car after a long time got my self a s411 i am going to be using a 13.5 motor with a lrp stockspec esc. What sort of gearing am i look at for a indoor carpet track medium in size
jon may is offline   Reply With Quote
Old 12-17-2011, 02:51 PM   #2113
Dangerous_toys's Avatar
Trader Rating: 185 (100%+)
Thumbs up
I just bought the 2011 Serpent S411 Limited Edition kit. Also got a Tekin Redline 17.5 motor/esc combo as well. Going to be running on carpet next year and would like to get it ready to go. If anyone has any suggestions/opinions for setup, pinions, lipos, wheels etc that would help me out it would be greatly appreciated. Thanks
Dangerous_toys is offline   Reply With Quote
Old 12-17-2011, 05:54 PM   #2114
Martin Crisp's Avatar
James
Congrats James - I did not know that!!! Looking forward to working together on setups.
-DC-
Thanks DC. Can't wait to get my car and lay down some laps.
LOL!
By the way Dave L, you found me out soon I see a serpent in your future
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 12-17-2011, 11:51 PM   #2115
locked's Avatar
Well I do like the limited edition version, for some reason.
Dave Locke
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
