Old 12-06-2011, 03:46 AM   #1981
Originally Posted by DeLaSoul View Post
Hi,
Lowering the pivot block is the same as raising the ball stud on the inner link, so more mid corner, less initial bite and vice versa. I find personally that 0.5mm change in the lower roll centre gives me as noticeable a change as 1mm in the upper roll centre if that makes sense??? Basically I find it a more sensitive change when adjusting the lower roll centre. Just remember to re-adjust the droop afterwards
On the rear of the car - Anti squat is a way of slowing or controlling the rear of the car "dropping" or squatting on power as the suspension can't collapse as easily. Outcome - It gives more forward traction out of corners and more steering on power, but on the downside the car can become less stable on corner entry and worse through the bumps on power.
On the front of the car - Anti dive is a way of slowing down the weight transfer on the nose of the car off power. Car becomes more stable on the way into the corner, and you can gain some off power steering (I know, this seems like a contradiction - but remember you will also be reducing the caster angle with anti dive) but you loose some on power steering. The car also is worse through bumps with more anti-dive.
The best setup guide i have ever read is by Elvo - link below
http://users.telenet.be/elvo/
Very easy to follow and really helped me! The sections on the roll centre are very cool as they have simple animations to show the main points.
HTH
Dave
Thank you
Perfect explanations :-)
008-Racer is offline   Reply With Quote
Old 12-06-2011, 07:25 AM   #1982
dawgmeat's Avatar
I've completed my S411 build, everything went smooth EXCEPT for the shocks. IMHO they shouldnt come pre-built, i.e. blurs on the the shock piston that had to be sanded, orings had NO lube and snap irng eyelet was rubbing against the shaft.
dawgmeat is offline   Reply With Quote
Old 12-06-2011, 08:26 AM   #1983
BAD007SUZUKI's Avatar
Trader Rating: 95 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default NEW INFO.
IM GOING TO TRY THE "SWEET SPOT" ON WEDNESDAY. IM NOW BEING TOLD THAT THERE ARE MAGICAL MEASUREMENTS THAT MOST CARS WILL WORK WITH. ITS HAS TO DO WITH THE RELATION OF THE BOTTOM OF THE CHASSIS TO THE HINGE PINS. BOTH INNER AND OUTER PINS. IT ALSO HAS TO DO WITH THE HEIGHT OF THE BALL STUDS IN RELATION TO THE BOTTOM OF THE CHASSIS. SO ONCE YOU GET CLOSE TO THE IDEAL NUMBERS, IM BEING TOLD YOUR IN THE MONEY. AT THAT POINT ITS SHOCK POSITION AND OTHER MINOR VARIABLES YOU ADJUST TO GET THE LAST 5% OF THE CAR DIALED.
I WAS ALWAYS TOLD "THAT THE CAR IS A BUNCH OF LEVERS".
SIMPLY PUT, I DIDNT UNDERSTAND WHY THEY WERE USING SO MANY SHIMS. MY CAR HAS WORKED FINE THIS SEASON SINCE DAY ONE. I'VE BEEN FORTUNATE THAT I HAVE NOT LOST A TQ OR AMAIN WIN AT THE LOCAL TRACK THIS SEASON.
BAD007SUZUKI is offline   Reply With Quote
Old 12-06-2011, 09:57 AM   #1984
jetbill007's Avatar
Trader Rating: 20 (100%+)
Guys what are the main differences between the LE kit and standard?
Outside of including extra tools and colors on the anodized aluminum?
Is the v2 kit very similar? Looks like the LE kit keeps getting pushed out for release.
For those of you that have come from driving a T3 2011 do you have any feedback you could share?
Thanks!
jetbill007 is offline   Reply With Quote
Old 12-06-2011, 12:38 PM   #1985
Trader Rating: 27 (100%+)
I believe the LE version also comes with 2 gear diffs (not 1 and a spool) and the CF battery holders also. I can confirm tonight, as I'm picking up my LE today!
Thanks!
stephenianjames is offline   Reply With Quote
Old 12-06-2011, 09:32 PM   #1986
Benzaah's Avatar
Trader Rating: 21 (96%+)
From my understanding it comes with a spool and 2 gear diffs. They would be stupid to not include a spool still as this is what the majority of people still use. Plus if they are not going to include a spool they have to include a suitable front gear diff oil and i dont see this listed anywhere on the kit components...
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 12-06-2011, 10:03 PM   #1987
venom54's Avatar
Default LE KITS
This is correct. Two diff kits and the spool kit but no DCJ's.
Kits are in stock.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 12-06-2011, 10:17 PM   #1988
Originally Posted by BAD007SUZUKI View Post
CAN PATTO OR ANYONE ELSE ANSWER THIS:
WHY ON ALL THE TOP 6 SETUPS I DOWNLOADED (FOR CARPET) AND PRINTED AND COMPARED, ARE FISCHER, NEILSEN, OLSEN, AND BOTZENHART RUNNING LARGE MM SHIMS ON THE INSIDE UPPER CAMBER LINKS. (ON THE UPPER CLAMPS). THIS WOULD REMOVE CAMBER RISE FROM THE CAR, RIGHT? SO AS THE CAR CORNERS AND WITH TRACTION, THE FULCRUM OF THE CAR/CAMBERLINK FORCES THE TIRES TO LOOSE TRACTION?
AM I THINKING ABOUT THIS CORRECTLY? OR BASSACKWARDS...........
IM RUNNING 1MM REAR INSIDE CAMBER LINK AND 2MM INSIDE FRONT CAMBER LINK SHIMS. THE REAR HUMBS HAVE 3MM AND THE FRONT CHUBS HAVE NOTHING. MY CAMBERLINKS ARE ANGLED DOWN TOWARD THE CENTER OF THE CAR GIVING IT HUGE CAMBER RISE. MY TIRES "CHIRP" AROUND CORNERS BUT IF I DRIVE IT OUT OF THE GROOVE OR TOO HARD ON THROTTLE, ITS A BEAST TO CONTROL.
WOULD CHANGING MY SHIMS HELP THIS?
I CAN SNAP PICS TO BETTER ILLUSTRATE.....
We have found that you need to have more camber gain in the rear than in the front. We liked the best running the front link long and relatively flat and the rear link short and with a slight angle. This translates to:
Front long, inside mounting hole with 4mm of shims, no shims on outside
Rear short, outer hole on chassis and inner hole on upright, 2mm shim on both
Camber front 0.0 - 0.5 deg neg
rear 2.0 deg neg
Also, we like the car with soft springs. We are using white springs all the way around and the shock are mounted of the inner most hole of the shock tower. Stocks bars, 2.5mm chassis, 3.5 deg of rear toe, 5mm of ride height
desotoracing is offline   Reply With Quote
Old 12-06-2011, 10:20 PM   #1989
Thanks!
LE kits arrived today. We will be shipping them out to dealers tomorrow (Wednesday)
Old 12-07-2011, 12:48 AM   #1990
crabboy's Avatar
Trader Rating: 58 (98%+)
Got mine today, looks sooo sweet, cant wait to build him now.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 12-07-2011, 02:51 AM   #1991
Got my LE today also...kit no.24, although the number will have worn off by the time I'm finished with it
Old 12-07-2011, 04:52 AM   #1992
crabboy's Avatar
Mine is #27...Casey Stoner.
Rhys
Rhys Marshall.
Old 12-07-2011, 05:03 AM   #1993
just looked at serpent's web
they have different belt than the original one
the original #401351 low friction
and the optional is #401350
can someone tell me the difference?
minilantern is offline   Reply With Quote
Old 12-07-2011, 12:07 PM   #1994
Johnny Wishbone's Avatar
rear 2.0 deg neg
Thats very similar to my setup right now........what is the wheelbase setting?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-07-2011, 12:43 PM   #1995
Default THX
PRACTICE OPENS IN AN HOUR. ILL TRY IT. THANKS
rear 2.0 deg neg
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
