Old 11-29-2011, 08:43 AM   #1906
MichaelNilsson's Avatar
Originally Posted by zaraz View Post
for those that have the v2 kit, or have switched to the 2.25mm chassis, is the car alot better to drive, then before, and if anyone has owned a xray before and now has a serpent, can you please tell me the advantages for this kit thanks
2.25mm chassis makes the car easier to drive, overall. More grip everywhere. 2.25mm also feel alot better.
The Serpent 411 is much easier to drive compared to Xray. My old Xray was fast, but somewhat hard to drive. It felt like it had no grip (obviously it had grip...) My Serpent is faster, and at the same time, easier to drive.
/Michael
Team Serpent International - Xceed - Advanced Electronics - MND Bodies
www.hobbyprodukter.com
MichaelNilsson is offline   Reply With Quote
Old 11-29-2011, 09:08 AM   #1907
dawgmeat's Avatar
/Michael
How about 2mm lower or upper chassis
dawgmeat is offline   Reply With Quote
Old 11-29-2011, 11:56 AM   #1908
Trader Rating: 26 (96%+)
when is the auction
zaraz is offline   Reply With Quote
Old 11-29-2011, 03:03 PM   #1909
2mm top deck is standard. 2mm chassis would be great on asphalt, I think.
/Michael
Old 11-29-2011, 04:16 PM   #1910
danthrc's Avatar
What is the internal drive ratio of this chassis? I have looked all through the manual and other media in the kit and cannot find it noted.
Is it 2.0?
danthrc is offline   Reply With Quote
Old 11-29-2011, 04:25 PM   #1911
what is the biggest 64 pitch gear you can install in the car without any modifications, thanks
Old 11-29-2011, 05:07 PM   #1912
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Is it 2.0?
yes it is 2.0.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-29-2011, 05:26 PM   #1913
dameetz's Avatar
I think its 113T.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-30-2011, 12:03 AM   #1914
Originally Posted by dameetz View Post
I think its 113T.
To be safe for outdoor with 2.25mm chassis, 108T would be better.
DanDan is offline   Reply With Quote
Old 11-30-2011, 02:13 AM   #1915
Toughbeard's Avatar
The absolute maximum Teeth I would suggest is for 84T for 48P Gears. This is almost flush to the bottom of the chassis with the "2.5mm chassis"
The Formula:
Outside Diameter = ( Number of Teeth +2 ) / Diametral Pitch
So... with the maximum gear we know which is 48P 84T
Outside Diameter = ( 84 + 2 ) / 48 = 1.791in (This is your limit...)
This is the theoretical value. so check the diameter of a brand new gear you have and calculate. And always keep in mind the difference as that will be your error %.
also when you do not know the maximum teeth that can be used, measure the distance form the center of the drive shaft to the bottom of the chassis which is the radius of your gear then you can calculate...
Enjoy
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 11-30-2011, 03:16 AM   #1916
29TC's Avatar
Send a message via ICQ to 29TC
when is the auction
It's up on ebay already.
http://tinyurl.com/c58wduc
http://www.ebay.com/itm/150710071759...84.m1555.l2649
29TC is offline   Reply With Quote
Old 11-30-2011, 04:58 AM   #1917
"Make your highest bid on the Serpent 411 Limited Edition Number 001 kit, and at same time help the Organisation Right To Play, in their quest for a better world."
minilantern is offline   Reply With Quote
Old 11-30-2011, 05:19 AM   #1918
mattwoodcraft's Avatar
i use the 2mm chassi on asphalt, its a good chassi and very comsistant. it has not caused me a issue at all i like a whole lot better than the 2.5 i have a 2.25 but have not tried it
mattwoodcraft is offline   Reply With Quote
Old 11-30-2011, 08:22 AM   #1919
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Assembled the 411 last night. It went together as good as any kit on the market... They improved almost all aspects of the car.
BTW, Tamiya toe blocks are not compatible.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 11-30-2011, 09:08 AM   #1920
serpentamerica's Avatar
Default Serpent 411 Limited Edition kit with exclusive number - 001
The Serpent 411 Limited Edition kit with exclusive number - 001 - is now being aunctioned / sold on E-Bay.
The number 001 is engraved in the carbon chassis plate together with the Serpent logo
The number - 001 - 411 Limited Edition kit, is the first car of the exclusive serie of 300 pieces of the Serpent 411 Limited Editon ( worldwide), of which now most are pre-sold already.
The final aunction price of the 411-LE - 001- car will be donated to the good cause: Right to Play. www.righttoplay.com
So we will appreciate your help to make the donation we can make as high as possible ! Start your bidding now !
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: info@serpentamerica.com
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
SEO by vBSEO 3.5.0
