Old 11-27-2011, 07:52 PM   #1876
Send a message via AIM to Profoxcg
Default question about gears and shocks
guys I am ordering one of these cars and I am curious about two things:
1) what pitch are the gears included in the kit?
2) In a S710 (nitro) you were able to pull the shaft of the shock down until it locked onto something internal and then twist. This would rotate the piston inside and open or close additional holes. So you went form 2-3-4 holes with a simple twist. Is serpent still doing this? if not, why did they stop?
Thanks,
Profoxcg is offline   Reply With Quote
Old 11-27-2011, 10:03 PM   #1877
Thanks,
To help you out...
1) The car comes with a 48 pitch spur gear. I believe it is a 84 tooth. I switched mine out for a 64 pitch since I had more pinions for 64 pitch.
2) No - the shocks do not have that option any longer. I believe the Xray still has that option with it's shocks but most people do not use it. The shocks on the S411 are actually very easy to work on - switching pistons takes very little time and the action on the shocks are pretty smooth.
duckman996 is offline   Reply With Quote
Old 11-27-2011, 10:06 PM   #1878
thank you ^
Old 11-27-2011, 10:51 PM   #1879
Originally Posted by Julius View Post
We did away with the system, because it proved too difficult for many to get 4 shock exactly the same. We are not considering implementing the system in the RCC shocks.
minilantern is offline   Reply With Quote
Old 11-27-2011, 10:52 PM   #1880
StevenOlsen's Avatar
Originally Posted by duckman996 View Post
What problems are you referring to?
Curious as to why you would want a carbon front stay? The plastic is just fine... If anything a little more forgiving in a crash.
Originally Posted by minilantern View Post
Is it about the un-anodized rear suspension?
you should look at serpent's web
it is fixed :-)
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 11-27-2011, 10:54 PM   #1881
Hi where did you get the quote from?
what is RCC ? thank you.
BTW any tips to things to look out for when building?
I noticed that serpent leaves the top of the ball-cup links open to expose the ball below. I see several people making this modification to their cars (non serpent) by dremeling. What is the advantage of this?
Old 11-27-2011, 11:00 PM   #1882
RCC X is serpent's new shock
http://serpent.com/product/903334/
I got the quote from S720's thread
Serpent 720
Old 11-27-2011, 11:10 PM   #1883
building tips from salven
http://www.youtube.com/watch?v=dJdTt...eature=related
Old 11-27-2011, 11:21 PM   #1884
RC MARKET's Avatar
this is STD Shock !
RC MARKET is offline   Reply With Quote
Old 11-28-2011, 12:45 AM   #1885
thanks
Old 11-28-2011, 05:38 AM   #1886
the LE kit number 001 should be auctioned today
but why can't I find it on ebay?
the auction postponed?
Old 11-28-2011, 06:09 AM   #1887
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Trimming the ballcup allows you to get the 2mm wrench in there without pulling the ball cup off. Since it is press fit plastic, the more you remove a ball cup, the more play you get. I t
So you can make changes without removing it.... It can also help with clearance in some instances.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 11-28-2011, 06:54 AM   #1888
dawgmeat's Avatar
Rebuilding my shocks and I damage 1 of the shocks spring washer/snap ring, will this work because the instruction parts lists parts as 903332 but I cant find it anywhere one the net.
http://www.amainhobbies.com/product_...-Seger-Clip-10
I read the entire instruction and this is the only time when the spring washer/snap ring is used and Amain has a different part# but list as being used the s411. Can someone confirm this is the right snap for the shocks, thanks in advance.
dawgmeat is online now   Reply With Quote
Old 11-28-2011, 07:03 AM   #1889
Thanks Tim.
Old 11-28-2011, 07:04 AM   #1890
903332 is shocks revision kit
I don't know what you broke, e-clip? or circlip?
I believe you can get what you are looking for in here
http://www.amainhobbies.com/product_...k-Revision-Set
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
