Like Tree12Likes
Old 11-16-2011, 03:41 AM   #1756
mingnon's Avatar
Default Shock question
Does anyone know of a good aftermarket brand shock for the S411 or where i can purchase a pair of shocks (body, shaft all the fixings)?
My wonderful and ingenious 7year old boy, decided to play with one of the shocks that was sitting on a bench ready to be worked on.
Needless to say the shock lost out in the battle with the $35 dollar 9volt remote control car and the hammer he was using to fit it.
Have had a look around and cant find complete shocks, any help appreciated
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 11-16-2011, 04:03 AM   #1757
http://rcmarket.com.hk/advanced_sear...903334&x=0&y=0
minilantern is offline   Reply With Quote
Old 11-16-2011, 04:07 AM   #1758
StevenOlsen's Avatar
http://www.t2shop.de/epages/61746328...Shops/61746328
i buy most of my parts from this site :-)
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 11-16-2011, 07:39 AM   #1759
Toughbeard's Avatar
http://www.evilhobbyshop.com/RCCX-sh...2,PR-1662.html
I buy all here since I own the shop
Drop a mail if you need anything at: [email protected]
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 11-16-2011, 08:21 AM   #1760
MichaelNilsson's Avatar
Originally Posted by 008-Racer View Post
Hi does anyone have Michael Nilsson's setup from this meeting?
ww.w redrc.net/2011/11/south-swedish-indoor-cup-rd2-report/
Hi!
If anyone can give me an editable setup sheet (PDF), I will gladly fill it out!
In short:
2.25mm chassis
Hard plastic parts
1.0-1.0 blocks front, 0.0-3.5 blocks rear (no shim under blocks in rear)
Gear diff front (500k), gear diff rear (4 gears, 150 CST (!))
Mono motormount
Shocks: 575cSt front, 425cSt rear (3-hole)
Anti-roll bars: 1.4-1.4
Short camber links front and rear, (1.5 degrees f/r)
Speed6 LW body
Sorex28
/Michael, Serpent International
MichaelNilsson is offline   Reply With Quote
Old 11-16-2011, 08:58 AM   #1761
ronsand's Avatar
Originally Posted by MichaelNilsson View Post
Hi!
Here you go: http://www.petitrc.com/reglages/serp...SetupSheet.pdf
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 11-16-2011, 09:32 AM   #1762
Originally Posted by ronsand View Post
Here you go:
Thanks man! Here it is:
rsb.se/arena/attachment.php?attachmentid=27954&d=1321461071 (copy/paste)
(Setup: Michael Nilsson, S411, Waxjo MS 2011-11-12)
/Mike
Old 11-16-2011, 12:08 PM   #1763
150cst oil
What does it change on the car if you run the different brackets at the front like Michael Nilsson's setup, as you still adjust toe with the turnbuckles at the front
S.A.W is offline   Reply With Quote
Old 11-16-2011, 12:36 PM   #1764
Jinjiro7's Avatar
At the price that they sell the DCJ for, you'd think that they would provide something stronger than heat-shrink to secure the pin! I'll wait for version 2.
Originally Posted by Pattojnr View Post
heat shrink only Matt. maybe ok for Stock. i have Major doubts for my 3.5T
i have just taken one apart cause it didnt feel smooth, then when i re shrinked it, i double shrinked wiht some super glue between the first and second layer where the pins are. so will see how they hold up. the insert for the shaft where the pin goes through, is solid, only hole is for the pin. so not even a chance to put a grub screw in.
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 11-16-2011, 12:41 PM   #1765
/Mike
Thanks bud
Looked great in the video
008-Racer is offline   Reply With Quote
Old 11-16-2011, 01:43 PM   #1766
Originally Posted by S.A.W View Post
150cst oil
It changes the width. A narrow car is more responsive, a wider car doesn't traction roll as easy.
/Mike
Old 11-16-2011, 07:10 PM   #1767
dameetz's Avatar
Can the Universal shaft drive pin be replace? (the one got driven by drive cup). I broke half side of it during race.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-17-2011, 01:27 AM   #1768
crabboy's Avatar
Trader Rating: 58 (98%+)
Welcome
Rhys
Originally Posted by Benzaah View Post
YGPM
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-17-2011, 03:00 AM   #1769
Toughbeard's Avatar
Yes. You will need a tool like the Huddy pin remover. I also suggest you heat up the drive shaft before removing pin. The pin is shrink fitted to the Shaft meaning the shaft hole is couple thousands smaller than the pin diameter. if you remove the pin without heating (therefore expanding the shaft) you may damage the shaft. then when you put the new pin in it may just fall off.
make sure you protect your hands and dont burn them.
Or you can buy a new shaft...
Serdar Aytemiz
Old 11-17-2011, 09:53 AM   #1770
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Does anyone know where I can purchase a s411 LE pre-order in america? I am pretty sure I want to get this car over the associated TC6, so I don't want to miss out on the limited edition one coming out! Thanks!
OnRDPassion is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 07:39 AM
