Old 11-10-2011, 06:33 AM   #1696
can I use the s733 front bumper to replace the stock?
minilantern is offline   Reply With Quote
Old 11-10-2011, 07:18 AM   #1697
Pattojnr's Avatar
Trader Rating: 19 (100%+)
no cause its 2 piece bumper
, there is nothing wrong with the 411 bumper. i have had some real big hits, and its survived really well
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-10-2011, 07:26 AM   #1698
Jinjiro7's Avatar
I used Parma bumper and cut it a little wider to better protect the front end suspension.
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 11-10-2011, 08:57 AM   #1699
yea, nothing is wrong. just want to know if I can interchange the bumper plate and use the 733's two piece bumper.
love the split design
Old 11-10-2011, 09:42 AM   #1700
Johnny Wishbone's Avatar
Originally Posted by dameetz View Post
Yes the gap is there even if it sits flat on the Hudy blocs,, thats where I noticed it in the first place.
Checked mine last night and have nowhere near that much of a gap, virtually none at all. Maybe check that the standoffs for the idler gear assembly doesn't have a screw in the bottom thats pushing the assembly up. Try flipping your top deck over just to see if you get the same gap. Maybe the top deck is the bent piece?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-10-2011, 09:52 AM   #1701
Chassis mod pics....took from my phone's camera, the white film is chassis protector. If my 2.25mm chassis arrive this week maybe I ll try it stock first and if it doesn't work I mod it like this too. At least this cut really worked at my local track (parking lot asphalt, low - med grip).
Note: On the upper deck, I only use 4 rear screws and at the front only 2 screws.
Are these cuts to mimic the front design of the car or are they more or less deeper that that?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-10-2011, 09:56 AM   #1702
I run the stock foam bumper and stock plastics, but I have trimmed off that built in buffer zone on the lower plastic part. Seems like its just something waiting to bend down and drag when you don"t want it to. Looks cleaner to me this way as well.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-10-2011, 09:42 PM   #1703
gwhiz's Avatar
Eerily accurate prediction. Behold:
Attachment 832268
gwhiz is offline   Reply With Quote
Old 11-11-2011, 02:18 AM   #1704
I want to buy the brass weight
but it is too tall I think
would it be okay or should I use the aftermarket lead weight?
Old 11-11-2011, 03:26 AM   #1705
Gergely's Avatar
Mine also bent down after a bigger crash, but after cutting out the most outer "connectors" it jumped back to the original shape and I don't have any problems since that.
Gergely is offline   Reply With Quote
Old 11-11-2011, 03:45 AM   #1706
dameetz's Avatar
I solved it already, apparently the spur gear bearing holder's alum case (the one that screws to the mid block mount) is a tad taller than the block, causing the upperdeck to bend a bit. I shaved it up a bit and now the upperdeck sits flush on the motor mount block.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-11-2011, 04:04 AM   #1707
dameetz's Avatar
I did that to get more flex at the rear, which really work at my local track. But yesterday and today I tested my new 2.25mm (stock no cut), it worked exactly like my modded 2.5mm chassis. The rear end is super planted now, the on power problem that I had earlier has gone completely, I m very happy with this car, steering is aggressive and the rear is still planted.
BTW I also mod the servo plate to accept a servo saver (I m using Xray's) , I dremel the carbon plate a bit, just enough to fit the saver. So far its working very well. I just like the assurance of using the servo saver compare to not using it.
Any of you guys have used the delrin spool cup? Mine just broke after 2 runs yesterday. When I use it, the vibration when having steering input (spool) reduced a bit, which I like, but durability is not that good. Now I m back to the stock steel cup, hopefully I can get the DCJ soon.
This Sunday will be my first race with this car, hopefully everything will be ok.
Old 11-11-2011, 04:07 AM   #1708
Send a message via ICQ to #iZzy Send a message via MSN to #iZzy Send a message via Yahoo to #iZzy
So, you read my post ? ... Seems that some others here haven't read it... but i gave already the solution
Team Magic Europe - HRC-Distribution - GM-Racing - LMI - MR33 - Tonisport
#iZzy is offline   Reply With Quote
Old 11-11-2011, 05:12 AM   #1709
dameetz's Avatar
Yes i did, thanks for the tip mate
Old 11-11-2011, 06:53 AM   #1710
Jinjiro7's Avatar
I meant "lower bumper". ( Curse you iphone kyb)
Lol that happened to my power bumper as well.
Attachment 832268
Ryan
www.drcrc.ca
www.fastcats.ca
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
