Old 11-08-2011, 11:26 AM   #1681
RC MARKET's Avatar
Serpent released option parts !!
RC MARKET is offline   Reply With Quote
Old 11-08-2011, 01:08 PM   #1682
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is it the spec-r cvd blades for yokomo that fit?
syndr0me is offline   Reply With Quote
Old 11-08-2011, 01:25 PM   #1683
VexVegaz's Avatar
its this one...just order them myself
http://www.rc-mushroom.com/product_i...ducts_id=23244
plan to use it once the stock becomes damage or worn..
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 11-08-2011, 10:48 PM   #1684
Perfect fit.
JAEHOON AHN
From Korea(Muchmore racing, Sweep racing)
KYOSHO MP9 TKI4 + OS B2101
xtaiji is offline   Reply With Quote
Old 11-08-2011, 11:36 PM   #1685
RC MARKET's Avatar
Serpent was update Blade !
Old 11-09-2011, 12:46 AM   #1686
RC MARKET my 411 arrived today thanks but can you confirm what plastics are in your kits (ie Soft - Medium)?
Many Thanks
008-Racer is offline   Reply With Quote
Old 11-09-2011, 08:39 AM   #1687
dameetz's Avatar
Guys, I m rebuilding my car with the 2.25mm chassis that arrived today. I just noticed there's a gap between the upperdeck and the motor mount (at the upperdeck middle screw to the motor mount). I never noticed this with my 2.5mm chassis, maybe I didn't check it before. So is this normal? If I screw it in, wouldn't the upperdeck tweak?
Below is the pic I took, and that is when the front and rear part screws are all in. I untweak the chassis on the Hudy block and the chassis looks normal, all flat.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-09-2011, 12:10 PM   #1688
Send a message via ICQ to #iZzy Send a message via MSN to #iZzy Send a message via Yahoo to #iZzy
Normaly, we screw now screw in that hole...
But this "problem" also exists with 2,5mm - it isn't a 2,25mm issue
sometimes it "can" be possible that the middleshaft bearing holder is to big, so you have to cut off some material from the top - otherwise, the topdeck bends.
Team Magic Europe - HRC-Distribution - GM-Racing - LMI - MR33 - Tonisport
#iZzy is offline   Reply With Quote
Old 11-09-2011, 01:49 PM   #1689
Jinjiro7's Avatar
+1 I did the same thing. Also additional slop for me was the ID of the small bearing that's on the steering bridge was too large. So I put a little CA glue on the thread of the screw to thicken it up...
Originally Posted by BAD007SUZUKI View Post
HERE IS WHAT I DID. I USED A LITTLE LOCKTIGHT ON THE TOP SCREWS.
3MM COUNTERSINK WASHERS
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 11-09-2011, 02:13 PM   #1690
RC MARKET's Avatar
for flex
Old 11-09-2011, 02:26 PM   #1691
Johnny Wishbone's Avatar
I'll check my car when I get home, but in the mean time, I'm thinking you have the car on edge to take the pic? Is that gap there when the car sits on a chassis pad or hudy tweak blocks. Just wondering if its just plain flex.
I like the look of those cs washers but if the outer diameter of the washer rides on the outside of the bearing and you have no clearance you should get drag when you try to turn the whole rack. JMO
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-09-2011, 04:02 PM   #1692
dameetz's Avatar
Yes the gap is there even if it sits flat on the Hudy blocs,, thats where I noticed it in the first place.
Old 11-09-2011, 06:00 PM   #1693
Jinjiro7's Avatar
401445 Driveshaft Double Cardain Joint --> $74.53 USD !
Too rich for moi
Ryan
www.drcrc.ca
www.fastcats.ca
Old 11-10-2011, 02:36 AM   #1694
Many Thanks
Sorry can anyone answer the above?
Do the newer kits come as standard with Medium plastics all round?
Well its all built! Really chuffed with how it went together amazing quality lets hope it goes as good as it looks!
Old 11-10-2011, 04:04 AM   #1695
mattwoodcraft's Avatar
i have all 3 chassis 2,2.25 ,2.5 and neither of mine have a gap like that.
i really dont think they would put a gap in there for flex as this would cause tweak when screwing the down the top deck
mattwoodcraft is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
