Old 11-07-2011, 03:52 AM   #1636
crabboy's Avatar
Trader Rating: 58 (98%+)
Its strange to hear everyone say the car is "tail happy", mine is TO planted in the rear.
Im running the KIT setup and even running the kit oils, mine did have some mid corner over steer in the begining, so you need to see if its in the front end OR rear end that could be making the cars rear feel loose.
Generally on my Tamiya going harder in rear gear diff oil would give the car more steering and that would make the rear feel loose on that car.
I always use HPI springs on my cars and on this one im running silvers all round, i will be testing the 2.00 chassis this week end plus a couple of other things will post the results if anyone is keen to hear.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-07-2011, 04:32 AM   #1637
Gergely's Avatar
I think it mostly depends on the track you use. The standard setup works well on high(er) grip tracks but lacks some traction out of corners in low(er) grip conditions imho.
Gergely is offline   Reply With Quote
Old 11-07-2011, 04:50 AM   #1638
VexVegaz's Avatar
half through the build, still waiting on a few parts to complete. i notice the front end uses a spool rather than a diff, what benefits would i expect by putting a gear diff and a ball diff in the front?
also, should i be putting grease on the joints? cvd, pivot..etc ? if so what kind do you guys recommend?
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 11-07-2011, 04:56 AM   #1639
Can anyone please confirm the exact measurement from the top of the chassis to the bottom of the top deck
Need to double check lipo fitment!
Many Thanks
008-Racer is offline   Reply With Quote
Old 11-07-2011, 05:00 AM   #1640
VexVegaz's Avatar
27.5mm, racer
Old 11-07-2011, 05:04 AM   #1641
Originally Posted by VexVegaz View Post
27.5mm, racer
Wow you are good
Cheers bud
Old 11-07-2011, 05:08 AM   #1642
VexVegaz's Avatar
N.p i just got this new digital caliper that i really wanted to use.
Old 11-07-2011, 06:06 AM   #1643
dameetz's Avatar
I made a cut to the chassis to get some rear flex today and managed to test it. It made a huge improvement on the on power out of corners problem that I had (at least it worked at my local track). I can drive it hard out of tight corners comfortably now. I m getting to love this car. Next test will be on mid day where the track temp is higher (simulating race condition) and hopefully it will work the same as I tested it this evening when the temp was cooler. I m super happy now. I can post a pic if anybody wants to see the mod I made.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-07-2011, 06:15 AM   #1644
Let's see the pic
Old 11-07-2011, 06:30 AM   #1645
Jinjiro7's Avatar
First of all nice looking car! Very stealth.
For #3, running on outdoor parking lot for fix my rear tail swing on power. I did...
1-Orange front/white rear spring... didn't work so i changed back to Orange/Yellow
2-Added more front droop, worked a bit, but still swinging
3-Lengthened rear wheelbase to 5mm worked!
4-Changed rear suspension block spacers from 1mm down to 0.5mm. combined with #2 & #3 above made the rear planted.
Earlier in the summer I used 3000 diff oil with 2 gears diff per forum suggestion. Now on carpet I am testing the 1200 oil with 2 gear diff and it's working great.
Finished building it today and sort of mini tested it at the track before dark. First impression, as most of you guys found out, very tail happy on power out of corners. I didn't expect it to be that bad and I m really worried now, I know I will work it out and hopefully can get rid of it by end of this weekend coz I ll have a race this Sunday.
Few questions:
1. I was using basic asphalt set up (not the kit set up) that I found on petit r/c, with the exception of ride height, I was using 7mm at the rear and 6.5mm at the front (our track is very bumpy and I m also trying to save the chassis from scrapping). Now, with the usual droop of 6mm at the front and 5mm at the rear (from set up sheet) how much of chassis lift value is it actually? I just want to transfer the value with my current ride height setting.
2. My car I think is a V1, came with 2.5mm low deck and no spur gear. When I finish building it I felt the car is too stiff (compare to my other previous cars). Is this one of the reason its very tail happy on power? I have ordered the 2.25mm chassis and should be here by early next week. Having said this anybody has experimented cutting maybe some holes especially at the rear (maybe behind the motor and the batt? kind of like BD5's chassis) or will removing some top deck screws (rear)provide some flex and improve the rear grip.
3. Can you guys list me a step by step on what to do next to improve the rear grip on power. So far what I m thinking of doing are:
-to remove both the rear 1mm bracket shims
-set the front droop to get more on power weight transfer to the rear (pls provide me chassis lift value)
- softer rear spring ( I have White springs on order as well as some HPI springs which usually work with all my previous cars)
- maybe trying a thicker diff oil coz I think it unloaded easily during cornering and make the car look like it did not want to straighten up.
- wait for my 2.25mm chassis and hopefully it will improve the handling drastically.
FYI I tested my car using Much More 36 tyres with 7.5t motor mildly boosted. My local track is parking lot asphalt with medium grip.
Ryan
* Serpent S411 * M11x *
www.drcrc.ca
www.fastcats.ca
Jinjiro7 is offline   Reply With Quote
Old 11-07-2011, 06:33 AM   #1646
Jinjiro7's Avatar
Heh all I had was Tamiya ball diff grease so I used that. But any thick grease should work.
Thnks a million Jin, BTW what grease do you recommend to use for the pivot joints/shaft? and associated stealth grease ok for cvd's?
Ryan
www.drcrc.ca
www.fastcats.ca
Old 11-07-2011, 06:35 AM   #1647
Jinjiro7's Avatar
I PM'ed RC Martket and he said Mid-November...
Originally Posted by gearhead_22 View Post
anyone now where to get http://serpent.com/product/401445/
Ryan
www.drcrc.ca
www.fastcats.ca
Old 11-07-2011, 06:53 AM   #1648
dameetz's Avatar
Chassis mod pics....took from my phone's camera, the white film is chassis protector. If my 2.25mm chassis arrive this week maybe I ll try it stock first and if it doesn't work I mod it like this too. At least this cut really worked at my local track (parking lot asphalt, low - med grip).
Note: On the upper deck, I only use 4 rear screws and at the front only 2 screws.
Serpent S411-chassis-mod.jpg   Serpent S411-chassis-mod-left.jpg   Serpent S411-chassis-mod-right.jpg
Old 11-07-2011, 06:56 AM   #1649
dameetz's Avatar
Thanks for the tips, at the moment running PattoJnr set up with the mod chassis. I m getting happy now
Old 11-07-2011, 07:09 AM   #1650
BAD007SUZUKI's Avatar
Trader Rating: 95 (100%+)
Send a message via Skype™ to BAD007SUZUKI
DO YOU HAVE ANY ISSUES WITH SPURS STRIPPING WITH THE TWO SCRES REMOVED ON THE REAR UPPER DECK? I REALLY LIKE THE MOD. LOOKS LIKE THATS HOW IT CAME OUT OF THE BOX.
ARE YOU ON CARPET OR BLACKTOP WITH THE CAR?
BAD007SUZUKI is offline   Reply With Quote
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
