Old 11-06-2011, 07:54 AM   #1621
Originally Posted by dameetz View Post
Finished building it today and sort of mini tested it at the track before dark. First impression, as most of you guys found out, very tail happy on power out of corners. I didn't expect it to be that bad and I m really worried now, I know I will work it out and hopefully can get rid of it by end of this weekend coz I ll have a race this Sunday.
Few questions:
1. I was using basic asphalt set up (not the kit set up) that I found on petit r/c, with the exception of ride height, I was using 7mm at the rear and 6.5mm at the front (our track is very bumpy and I m also trying to save the chassis from scrapping). Now, with the usual droop of 6mm at the front and 5mm at the rear (from set up sheet) how much of chassis lift value is it actually? I just want to transfer the value with my current ride height setting.
2. My car I think is a V1, came with 2.5mm low deck and no spur gear. When I finish building it I felt the car is too stiff (compare to my other previous cars). Is this one of the reason its very tail happy on power? I have ordered the 2.25mm chassis and should be here by early next week. Having said this anybody has experimented cutting maybe some holes especially at the rear (maybe behind the motor and the batt? kind of like BD5's chassis) or will removing some top deck screws (rear)provide some flex and improve the rear grip.
3. Can you guys list me a step by step on what to do next to improve the rear grip on power. So far what I m thinking of doing are:
-to remove both the rear 1mm bracket shims
-set the front droop to get more on power weight transfer to the rear (pls provide me chassis lift value)
- softer rear spring ( I have White springs on order as well as some HPI springs which usually work with all my previous cars)
- maybe trying a thicker diff oil coz I think it unloaded easily during cornering and make the car look like it did not want to straighten up.
- wait for my 2.25mm chassis and hopefully it will improve the handling drastically.
FYI I tested my car using Much More 36 tyres with 7.5t motor mildly boosted. My local track is parking lot asphalt with medium grip.
Mine has been tail happy on power even with the 2.25mm chassis, today I tried the 0.5mm bracket shims at the rear and also ran 5 droop at the front. Removed the two screws on the top deck behind the motor. It's helped alot but I'm still not happy with it
I tried the white springs on the rear and found it worse !
S.A.W is offline   Reply With Quote
Old 11-06-2011, 08:04 AM   #1622
Potoczak's Avatar
Trader Rating: 109 (100%+)
What site has the best deal on the s411???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-06-2011, 09:14 AM   #1623
syndr0me's Avatar
Trader Rating: 32 (100%+)
Try moving the rear arms back toward the rear of the car. Also, try no sway bar on the rear. Maybe no shims under the rear blocks, and lowering the inner camber link in the rear.
syndr0me is offline   Reply With Quote
Old 11-06-2011, 10:05 AM   #1624
Johnny Wishbone's Avatar
Also don't forget that you may have to take some front end away from the car to get the rear to grip.
Wheel base change up front.
Bigger front sway bar.
Harder front springs.
Thicker front shock oil.
Just something to consider.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-06-2011, 10:39 AM   #1625
VexVegaz's Avatar
Originally Posted by Jinjiro7 View Post
I use 400 wet/dry. Then 600. I sand it underwater. I also sand the shock towers to take the edge off.
Thnks a million Jin, BTW what grease do you recommend to use for the pivot joints/shaft? and associated stealth grease ok for cvd's?
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 11-06-2011, 11:04 AM   #1626
gearhead_22's Avatar
Send a message via AIM to gearhead_22
anyone now where to get http://serpent.com/product/401445/
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 11-06-2011, 11:10 AM   #1627
VexVegaz's Avatar
looks like borders may have it, but pretty expensive.
http://the-border.com/product.php?pr...8&bestseller=Y
Old 11-06-2011, 01:20 PM   #1628
I'll try to wait till it comes to the us
Old 11-06-2011, 02:56 PM   #1629
Gergely's Avatar
You can try this:
Originally Posted by Gergely View Post
Hello SAW,
I think the changes you made are not really effective to solve your problem. If I were I in your shoes (I was ) I would go for longer rear wheelbase (4mm in front of the rear arms), and use 4 gears with 1000cst oil in the diff. Please check if your crown gear is not moving too much on the diff outdrive when the screw is fully tightened. Also use the 3.5 rear toe block if you have.
Hope this helps!
Gergely is offline   Reply With Quote
Old 11-06-2011, 03:02 PM   #1630
dawgmeat's Avatar
102 US dollars
dawgmeat is offline   Reply With Quote
Old 11-06-2011, 03:39 PM   #1631
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by dawgmeat View Post
102 US dollars
Damn that's Xray money..
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 11-06-2011, 04:00 PM   #1632
102 US dollars
102 dollars what r they on dope or dog food
Old 11-06-2011, 04:28 PM   #1633
dameetz's Avatar
You can try this:
My current set up already put 4mm infront of the rear arms, maybe I ll try 5mm and no sway bar today. I don't have the 3.5deg RR bracket yet, I have yet to order it, but my LHS carries Tamiya blocks which I heard are also direct fit. Might want to try it if it really fits.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-06-2011, 07:52 PM   #1634
Akhor's Avatar
RC Market,
When are you getting the Aluminum Steering Block is stock?
http://www.serpent.com/product/401422/
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 11-06-2011, 08:04 PM   #1635
VexVegaz's Avatar
im waiting on that too, but you might do better sending him/her a pm
http://www.rctech.net/forum/private....=newpm&u=41625
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
